      06-29-2012, 04:06 AM   #1
///Chase
///Chase's Avatar
Australia
115
Drives: 16' m4
[BNE] kerscher front lip help !
Hey guys picked up my kerscher from lip the other day (thanks stu at BMR!) Just wondering if anyone has any tips on installing it? Im not overly keen on doing it myself so if anyone could help a case of beer is yours! ha ha. I assume its not super hard but if anyone has any info that would be killer!
thanks heaps
Chase.
      06-29-2012, 06:39 PM   #2
UR25IO
UR25IO's Avatar
Australia
97
Drives: 2011 BMW 135i M-SPORT DCT
hey Chaseyo
does the Kerscher lip have any indication where to drills holes through them?
      06-29-2012, 08:11 PM   #3
Superdaws
Australia
114
Drives: 2020 F87 BSM M2C
Originally Posted by UR25IO View Post
hey Chaseyo
Yes, small indentations where you are supposed to drill....
I didnt use all of them though, theres a hell of alot, i think 6 at the rear and 3 at the front was what i used, only needed to drill through my OEM bumper in the 3 spots then.
2020 MY21 BMW M2 Competition 6MT | Black Sapphire
OLD 2010 BMW 135i M Sport 6MT | Le Mans Blue
2016 BMW F15 X5 30D | Sapphire Black | Black Leather
      06-29-2012, 09:08 PM   #4
UR25IO
UR25IO's Avatar
Australia
97
OK. sweet..
first you must remove the mud flappy things in front of the font wheel and of the splash guard/plate between the front bumper and the center splash plate
just drill those holes out on the Kerscher lip - line the lip up with the lower bumper from tip to tip and just drill holes in the bumper
lastly just nut and bolt them up..
      07-01-2012, 04:33 AM   #5
///Chase
///Chase's Avatar
Australia
115
Drives: 16' m4
So you guys think its pretty simple? i should be able to do it myself?
      07-01-2012, 05:53 AM   #6
UR25IO
UR25IO's Avatar
Australia
97
sure man ... cant see why not... it takes less than 30 mins... the front end must be up higher than the resting point.. in other words jack the front of the car up! lol
      08-26-2012, 07:06 AM   #7
Harlequin
Harlequin's Avatar
Australia
334
Drives: F32 Coupé
Haven't been around in a while but notice on FB that you've got it installed. Would have been happy to help...
I ended up removing the front end and doing it properly - with about a dozen bolts...
      08-26-2012, 07:27 AM   #8
1_dez
Australia
Drives: 1er
i took my front bar off also.. best part of 2-4 hours to install the lip =]
      10-31-2012, 07:44 AM   #9
skeeler
skeeler's Avatar
Drives: 2012 135i Black
I just got one of these yesterday, and after holding it up there and looking underneath there, it sparked a few questions. So I thought i would do a search and see if I could find some information on it.
A couple questions if you guys don't mind?
1) I am assuming you have to remove all of the factory bolts in the front part of the spoiler?
2) Does the splitter use some of these existing factory holes to mount to then?
3) I noticed you mentioned that you need to remove the front splash shield from the center splash shield and finally from the vehicle, but when reinstalling the front splash shield, how does it attach if you have used the factory mounting holes for the splitter?
Thanks in advance for the help! Can not wait to get this thing on!
Shawn
OK. sweet..
      10-31-2012, 08:16 AM   #10
Harlequin
Harlequin's Avatar
Australia
334
Drives: F32 Coupé
Yes. But there's only 6 or so of them.
Yeah but you want to use more than just those. You'll notice that the splitter has some "circles" etched into it. Drill a hole for each of those. Some of them will line up with the pre-existing holes on the bumper, some you will need to create new ones.
Mine's basically just resting on top of the trailing edge of the bottom of the bumper - tucked in, so to speak.
Hope that helps.
      10-31-2012, 08:32 AM   #11
skeeler
skeeler's Avatar
That helps tremendously!!
I assumed I would have to drill new holes for the majority of them. I have already pre-drilled the splitter.
The part that was throwing me, was how do you fasten that front splash shield after the splitter is installed, but I understand now that you in stall it with just the rear bolts and tuck it in there in the front.
Thanks again! - Shawn
Hope that helps.
      12-03-2012, 07:47 PM   #12
skeeler
skeeler's Avatar
Hope that helps.
Getting ready to install this sometime over the weekend, and was wondering. In addition to the bolts, did you use any 3M tape as well? Thanks!
1addicts
