04-30-2024, 08:06 AM | #1 |
912
Rep 818
[DIY] Created an inline fuel filter - Will that solve the injector issue?
Hi. I just finished installing an inline fuel filter for the E92 M3.
That's an attempt to address the injector sticking open problem. In case you would like to do it too, check out the video I made. Any questions, feel free to ask. 10-micron paper filter: EPMAN EP-ZZOF01-BK 40-micron washable filter: ADDCO ADF09901 You'll also need: 05x Metallic lock quick release fuel fitting FEMALE 7.89mm or 5/16" - MALE AN6 05x Male quick release fuel fitting 7.89mm or 5/16" - MALE AN6 01x Triple display for air pressure for air suspension kit 0-220 psi with 03 1/8" NPT sensors 01x Adapter Female M10 X 1.0 - Male 1/8 NPT 02x 90º angle fitting female an6 - female an6 3,0m of fuel injection hose 8mm or 5/16" ID, 13mm OD, 10 bar pressure 08x hose clamp 11-13mm 03x tee AN6 male - AN6 female - 1/8 NPT 03x adapter male an6 - male an6 04x 45º angle fitting female an6 - female an6 01x tap-a-fuse kit (mini or standard, I'm waiting for it to arrive to know) 01x 5 amp fuse (mini or standard, matching the tap-a-fuse kit) 02x adapter male AN6 - male 1/4 NPT 02x adapter female AN6 - male 1/4 NPT 01x electrical wiring harness tape 9mm x 15,0m 02x hose adapter fitting female an6 - 8mm or 5/16" barb fitting 02x hose adapter fitting male an6 - 8mm or 5/16" barb fitting Variety of zipties I bought everything from Aliexpress (except for fuel hose, that was promptly available here in local shops). Cost less than 200 usd. Ps.: when doing an air pressure test, do it without the filter media, to avoid damaging the media if things go wrong, or even because of any moisture build up, that could damage the paper media. ps2.: before connecting filtering system outlet to the rail, let it pump a little gas to a container, hence washing the new items you're about to put in the system. don't need to crank the engine, just turning ignition on will start the pump for a couple of seconds (you'll need to repeat it for several times until you achieve one or two liters of gas washing the system) Last edited by jvictormp; 05-02-2024 at 01:44 PM.. |
05-02-2024, 02:14 PM | #2 |
912
Rep 818
Would like to add some information.
About heat absorption, in my solution, that places filters in the front of the engine, I can confirm they get hot, but doesn't get hotter than hoses and lines got earlier. Only difference is when you compare by touching them, because rubber hoses have lower "thermal conductivity coefficient" than aluminum, so that they don't seem to be so hot when you touch. And when you touch aluminum, it seems pretty hot. But all of them are staying about 50/122 ºC/ºF or 60/140 ºC/ºF. I don't see a problem there. Sure you can wrap in a reflexive tape, but after a while of engine running, everything will come to a thermal equilibrium and sit at the same 50 ~ 60 ºC. About pressure drop, in my solution, that uses a 42mm diameter (like NRW and EuroPowerMotorsport products) and 43mm lenght filter (that's half the lenght of NRW's), I faced a 4 psi pressure drop at max load engine redline. About filter span, can't say, because I didn't run a significant mileage yet. But will soon. I'm willing to monitor that by the pressure drop increasing over time. I heard people talking that the root cause of injector sticking is the pump strainer getting old and desintegrating. Would prevent that replacing the entire pump. Okay, no problem with that, but there's no certainty on it too. One certainty is, if you have a 10-micron filter, you'll be protected from that. |
Harryc99.00 Assimilator1595.50 |
05-02-2024, 02:18 PM | #3 |
912
Rep 818
Also, the original pressure sensor relocation:
NRW took a good step relocating the pressure sensor to after the filter. EuroPowerMotorsport is offering a filter too, but doesn't relocate the pressure sensor. I think that may be dangerous, because if the pressure drop in the filter gets too high, ECU will be blind and may have trouble regulating mixture or even protecting the engine against lean mixture scenario. |
05-02-2024, 02:20 PM | #4 |
912
Rep 818
NRW:
https://www.nrw-design.com/products/...uel-filter-kit EuroPowerMotorsport: https://europowermotorsports.com/pro...t-bmw-s65-s85/ |
05-06-2024, 06:48 AM | #5 |
596
Rep 1,042
Drives: BMW M3 e92 08 & 330d e90 10
Haven't see the videos yet, but good write up.
Is their good evidence now that it is dirt that is jamming the injectors up? Last I looked into it, it was just a theory. Re heat into the fuel pipes/metal filters. Like you said the fuel filter will feel hotter even where the temp is the same, but don't forget that the higher thermal conductivity of the metal filters means more of the heat will be transferred to the fuel. Although perhaps the impact is minimal, I think it would be worth insulating the filters to be safe, remember that the incoming fuel will be cooler than the under bonnet air, so temps won't equilibrise, but will stay lower with sufficient insulation. Btw, any idea what micron size the standard filter is?
Oil analysis for finding wearing rod bearings?. Collation of oil analysis reports with some rod bearing photos for the M3's S65. My categorisation of pulled rod bearings in the rod bearing condition thread. My updated 'Blown engines' list. Last edited by Assimilator1; 05-06-2024 at 06:57 AM.. |
05-06-2024, 07:06 AM | #6 | |
912
Rep 818
I think you're right about temperature not equilibrising. I'll wrap the filter in reflexive tape. About the standard filter, I don't know. But I know it's not restrictive, because it would disturb the pump suction pressure, as well as saturate soon, not being able to be considered by BMW as life-time part. People say that the practice in the racing/automotive world is to use 100-micron filter in pump suction. |
05-06-2024, 07:26 AM | #7 |
133
Rep 208
I believe there is a 20-25 micron filter built in the injectors..
From my research, for those who prefer to keep things OEM, I’d replace injectors every 50-60,000 miles & in tank fuel pump every 70-75,000 miles.. of course this is just my opinion, not evidence based.. Also if dirt is already partially clogging the injectors, adding an additional filter would not make a difference but will definitely help keeping them clean going forwards. |
05-06-2024, 07:30 AM | #8 |
596
Rep 1,042
Most modern petrol cars (here in the UK & Europe at least) haven't had a separate fuel filter since about the mid 2000s, in tank non-replaceable filter has been the norm for 20 odd years, yet injector failure is rare in general (not to say their aren't specific cars which have injector failures though).
I don't see that the filtration by the standard filter is insufficient as it would cause problems much earlier on otherwise, but maybe they're breaking up now?? But don't the injectors have built in filters to stop that? (should it happen).
Oil analysis for finding wearing rod bearings?. Collation of oil analysis reports with some rod bearing photos for the M3's S65. My categorisation of pulled rod bearings in the rod bearing condition thread. My updated 'Blown engines' list. |
05-06-2024, 08:24 AM | #9 | |
912
Rep 818
I'm not expert in injectors, but I have the impression of having read here some saying that E9X M3 injectors don't have that screen. Also, I think it's a huge gain having a serviceable filter instead of servicing the injectors. And, it's known that servicing injectors (not replacing for new ones) don't avoid the sticking problem. And I'm with you about the initial state of the injectors at the moment of implementation of the filter. In my case, my injectors have run less than 15,000 miles, only with top tier fuel, having ran a can of fuel cleaner after my old injectors had gotten stuck. |
05-06-2024, 09:01 AM | #10 | |
912
Rep 818
The filter before pump being insufficient, I think there's no argument against that. I can only think that problems don't happen more often because the fuels are clean enough for the system to hold on for years. Otherwise, an adequate pre-pump filter would rapidly saturate. But you can find injectors sticking open cases with low mileage E9X M3s and E6X M5/6. Take a look at that article: https://www.holley.com/blog/post/how...a_fuel_filter/ |
05-06-2024, 09:47 AM | #11 |
596
Rep 1,042
In which case the filter is sufficient , it seems that (more) failures have been occurring in more recent years, so perhaps it's more time related than mileage related? So a degrading pre-filter goes with that.
