HELP PLEASE -- PROS and CONS of Xi OVER i
08-27-2008, 02:56 AM | #67 |
Night Sh1ft
460
Rep 3,079
Drives: F95 X5MC LCI
I'll throw it out there for you, I have an i, Ive driven multiple xi's:
335i is much more...nimble 335xi is much more of a safety net for the avg driver When it comes to adding a chip, I realize some people see the traction light blinking all day...but I say, learn to drive, learn to slip the clutch properly, and get some legit tires so you can grip the road, and you wont have any issues with traction. Turn the DTC/DSC "off" by holding it down until it gives you the *WARNING EXCLAMATION!* telling you that you're driving at your own risk. The xi might get a better launch for most drivers, but I'll say that in the i, even with a tune, a great launch is entirely possible if you really learn the car. The xi just makes it easier for the avg driver to do it, theres little effort involved. Learn the car well, and the i will treat you right. In the winter, throw some snows on there and take it easy. The i with good snows is pretty much as good as the xi with all seasons if not better. The true sport suspension makes a big difference in handling feel Unless you live in a mountainous area, hit up the i, and you wont regret the fuel savings or the fun factor. If you get an xi, its just an extra safety blanket for poor conditions outside, personally, Id rather have a car thats 200 lbs lighter and just learn to drive better/safer in more dangerous conditions. I dont care about cornering forces when its wet outside, who's running hotlaps in the rain?
"Your first 10,000 photographs are your worst.” ― Henri Cartier-Bresson |
08-27-2008, 04:55 AM | #68 |
Rep 1,035
I'm not sure you meant to imply this, but I just wanted to make sure everyone is clear that xDrive is not an "on-demand" AWD system, which would be a fundamentally 2WD system. xDrive is a full-time AWD system that continuously shifts torque between the front and rear axles as needed. There are very few instances where the F/R torque split is maintained at 0:100 or 100:0.
May 3, '07European Delivery, Redelivered on 6/11/07 - Monaco Blue/Beige, Steptronic, ZPP, ZCW, PDC, iDrive/Navi with RTTI, Logic 7, Xenons, HD Radio
08-27-2008, 11:15 AM | #69 | |
Rep 80
08-27-2008, 04:14 PM | #70 |
196
Rep 4,163
i have a 330xi. ive also driven a 328i loaner. a very simple difference i can feel is that i love to make sharp turns all the time without slowing down at all. in my 330xi it takes the corner sweet. with the 328i it plows a little and the tire squeaks in the front. i thought i was giving it too much gas but then in my 330xi i never had this issue no matter how much gas i gave.
'06 bsm e90 330xi : 18" VMR CSL : KW V3 : GruppeM Rep Intake : UUC/Corsa Catback : Hartge Lip : ACS Roof Spoiler
OEM CF Trunk Spoiler : CF Emblems. Pillars. Mirror. Grille : LUXER12 led plate : V1 Hardwired : OG.longtran e90post sticker! circa 2005 |
08-27-2008, 04:26 PM | #71 | |
Rep 4
Power is indeed apply to all 4 wheels. The purpose of an open differential is to evenly distribute power to both axles while allowing it to rotate at different speeds. |
08-27-2008, 05:20 PM | #72 | |
Rep 33
08 E90 335xi, Sport, Step
08-27-2008, 05:35 PM | #73 | |
Rep 1,035
An open differential always sends the same amount of torque to each wheel on a driven axle. If both wheels on the axle have full traction, the L/R torque split is 50:50. If one wheel slips, the torque split is still 50:50, but all of the force coming in from the engine will be blown off on the spinning wheel (which requires very little torque to spin real fast). When DSC applies the brakes to slow the spinning wheel, resistance to wheelspin on the slipping wheel increases, and the differential will send more torque to BOTH wheels.
08-28-2008, 10:28 AM | #74 |
Rep 80
Addmittedly my statements were an oversimplification, however, when there is an imbalance of traction, the open diff sends power to the WRONG wheel, namely, the one that is already slipping. Further, the design of the open differential is such that it sends power to the wheel with less resistance, which, when you need traction, is the exact OPPOSITE of what you want/need. The reason why open diffs have single-wheel burnouts is because the diff keeps sending power to the axle with less resistance. Once one wheel looses traction, you are sunk (unless power is reduced).
The x-drive system tries to counter this by creating resistance through the ABS system to shift the power over to the other side. In contrast, mechanical LSDs are biased toward sending power where there IS traction and then proportioning it if slippage occurs. The open diff cannot do this, it just spirals downward. Here is a great link explaining how the systems work: http://www.houseofthud.com/differentials.htm The operation of the open diffs is evident when you drive an xi w/wo the DTC on. The car has greater cornering capabilities with the DTC on not only because you have computer intervention, but because the mechanical limitations of the diffs are MITIGATED by the tc. However, this is still a band-aid approach as compared to mechanical/hydraulic LSD units. The system's flaw is that it has to REDUCE power to overcome the open diff, rather than proportioning the power. So can the xi actually send power to 4 wheels, YES, under full-traction conditions. However, once traction is lost at a wheel, the power shifts to that side unless it is reduced to below the threshold of traction. My statements were relative to the extreme traction conditions (>10/10ths). |
08-28-2008, 12:07 PM | #75 | |||
Rep 1,035
Also, whether you consider DSC/DTC to be a band-aid approach depends on why you want an LSD. If you want it for performance purposes, then yes, DSC/DTC is suboptimal. If safety is your primary concern, then DSC/DTC is better because its interventions tend to keep the car within its handling limits. An LSD will not prevent you from losing control of your car, but DSC can.
08-28-2008, 02:06 PM | #76 |
3189
Rep 10,509
People consider a xi BMW should try a WRX/STi/EVO or perspective before making the purchase decision.
front and rear LSD combined with Subaru/Mitsubishi experience at fine tuning the handling balance of AWD car is far superior to BMW IMHO. I think BMW's core competency is RWD NA vehicles |
08-28-2008, 02:50 PM | #77 |
Rep 4
Suburu, Mitsubishi, and Audi definitely have more experience in the AWD game and have more sophisticated systems.
Roamer you're explaination is still technically incorrect. Power isn't sent to the 1 wheel that loses traction. Cars doing 1 wheel burnouts still manage to move forward right? Because torque is still equally applied to the wheel that has traction. What really happens is that overall torque is limited by the slipping wheel with an open differential. You still get individual wheel spin even with mechanical LSDs, although to a much lesser extent. The purpose of an LSD is to limit the rotational difference between the 2 axles thus allowing them to spin at different rates during turns, but locking up once the rotational difference surpasses a specific ratio. Even in this case torque is STILL equally applied side-to-side. xDrive emulates the LSDs effect by litterally limiting the rotational difference between two wheels with the brake system. Mercedes' 4matic system is even more simple. Their center differential is open and they control front/rear torque bias by modulating the front/rear brakes. When a system has the ability to vary torque split side-to-side that's called torque vectoring. The only current production system that's capable of this that I'm aware of is Honda's SH-AWD. However all players in the AWD market are now putting R&D into this technology. |
08-28-2008, 03:44 PM | #78 | ||
Rep 1,035
Ditto with Audi, but it depends on what you want AWD to do for you. From a performance standpoint (i.e., grip around the corners and performance in slippery conditions), Torsen is definitely the way to go, but if my primary concern was being able to get moving from a standstill on ice, an electornic center clutch pack like xDrive (or Subie's VTD system), probably has a slight edge. Quote:
08-28-2008, 04:10 PM | #79 | |
3189
Rep 10,509
IMHO, there are few cars that easy to balance at the traction limit. Throw a mid corner bump into the mix while cornering at that traction limit and I'm pretty sure you'll be a believer. Most people get thrown off by the body roll but the wheel control is fantastic and the long travel suspension is awesome for straightening out an unfamiliar and imperfect back road I believe the Evolution with AYC can vector the rear torque from side to side Personally, I find that Subaru's tuning is biased towards loose/imperfect surfaces and a 'finish all rotation at turn in/big throttle way before the apex' driving style while Mitsubishi is biased for smooth tarmac and feels more like a RWD car |
08-28-2008, 04:22 PM | #80 | |
Rep 1,035
08-28-2008, 08:08 PM | #81 |
313
Rep 2,576
The Subaru STi is an amazing car. It is a painful daily driver though. I had one for three years. Before that I had an '03 WRX for 2 years. They are great cars, just not so comfortable on a daily basis. If pure performance and AWD are the criteria, the STI or the EVO are the cars of choice.
08-29-2008, 09:09 AM | #82 |
Rep 80
Silo and Lassaxi-
You guys are getting caught up in your own technicalities. Someone wrote that while one wheel is spinning the other might get some torque. Great, so while you are trying to get power down, 90% (or whatever proportion) ends up turning the slipping wheel and 10% might get shifted to the wheel with traction. How is this an effective means for getting power down? However, Lasssaxi's statement that the DTC system is subobtimal for performance driving is my entire point. The DTC-open diff systems on the 335 are subobtimal, which was my reason for stating that the 335xi is superior from a traction standpoint to an i, but the difference lessens when a LSD is added to an i. Add to that the i's weight advantage and better suspension and the i ends up being the better performance platform. On a somewhat related note, does anyone have concerns about lowering an xi? It seems odd to me that bmw chose not to. Is there a potential for bad driveline angles or too much stress on the front seals? |
08-29-2008, 10:07 AM | #83 | |
313
Rep 2,576
I also still hear a ton of speculation with regards to the performance difference between the i and xi. Has there been any proof yet to date? or is everyone still in speculation mode? I know this was argued in the past between the infiniti G35S and the G35X until it was actually tested and to everyone's surprise, the X outperformed the S in handling and lap times. I'm not saying the xi is faster than the i, I'm just looking for some real world comparison that actually shows an i can outhandle an xi. |
08-29-2008, 10:12 AM | #84 | ||
Rep 1,035
All we're trying to tell you is that an open diff sends the same amount of torque to both wheels on a driven axle. You're right that the practical effect of that is that when one wheel spins, the other wheel doesn't get as much power as it needs. But that does not mean, as you wrote earlier, that "the xi system is incapable of proportiong power to more than 2 wheels (1 at each axle) at a time." That's all we're saying. Otherwise, I think we're all in agreement here. Quote:
08-29-2008, 10:38 AM | #85 |
///M Uber Alles
332
Rep 1,601
You can get along just fine in the winter with the RWD i and a good set of snows. You can also get along fine in the summer with a Honda Civic and a good set of summers.
If you want to do more than just get along fine but would also like to have FUN, and four seasons of it, the xi is your ride. |
08-29-2008, 10:47 AM | #86 |
///M Uber Alles
332
Rep 1,601
Btw, I'm picking up my modestly lowered (KW var. 3) 335xi from the shop today
I think the xi one-size-fits-all stock suspension is simply a product of economics and (as much as us xi aficionados hate to admit it) BMW SUV pedigree. |
08-29-2008, 11:07 AM | #87 |
534
Rep 4,021
Drives: 2008 335xi Coupe
Just get the XI, it has one more letter so it must therefore be better
"Aerodynamics are for people who cannot build engines"......Enzo Ferrari
08-29-2008, 11:07 AM | #88 | |
Rep 4
If you live where it snows then you might want to consider an XI. You can make do with good snow tires with RWD but if you've ever driven in the snow with AWD it's totally different. From a performance standpoint xDrive definitely isn't a performance AWD system like Mitsu's. However I was sold on AWD when I first took out my Eclipse GSX in 15 inches of snow. |
