Ground Control Suspension
07-16-2014, 03:32 PM | #1 |
Rep 277
I've done a bit of searching and found relatively nothing in relation to this suspension. My shop that I go to for all my work recommended this suspension to me. This would be for springs, shocks, camber plates, bump stops, Control arms, and mounts. Wondering if anyone here has installed it or been in a car with ground control stuff?
The owner of the shop uses it on his M5 and says he loves it. Said he got his custom made so that he can use it at the track and then for street driving he can raise the car up a bit so its not so low. Mind you he is a mechanic and this would be relatively easy for him but still. He said the street setup would most likely be best for me considering that's majority of my driving. Anyways, let me know your thoughts.
Stacked BMS Flash & JB4, Dinan CAI, ER Chargepipe, 7" VRSF Intercooler, VRSF Catless DP's, ER Sport Oil Cooler w/Steel lines, Gunmetal 19" VMR V710's, 335is clutch |
07-16-2014, 03:36 PM | #2 |
1567
Rep 4,110
Drives: BMW M3
GC uses custom valved Koni dampers; good but limited tech. TC Kline also uses customized Koni tech.
KW's street-oriented dampers offer a more comfortable ride on the E9x platform, IMO; Koni is a little harsh by comparison. Look at KW Street Comfort. There are a couple of great reviews around here.
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT |
07-16-2014, 03:40 PM | #3 | |
Rep 277
07-16-2014, 10:28 PM | #4 | |
146
Rep 1,160
HERE - excellent result - grip w/o end |
07-17-2014, 02:02 AM | #5 | |
164
Rep 2,556
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
07-17-2014, 11:08 AM | #6 | |
Rep 277
07-17-2014, 11:11 AM | #7 | ||
45
Rep 345
Drives: Many BMW's & Porsche's
This is the first time we've heard the word 'Koni' and 'harsh' in the same sentence before...... In fact, we have done 2 installs in the recent past where the customer had us take off KW to install our TC Kline kits. Koni uses a 'no pressure' or 'low pressure' gas system just for that reason, to create a softer ride on the street. Just our .02..... |
07-18-2014, 12:18 AM | #8 |
99
Rep 198
Big fan on the Ground Control/Koni Based systems personally. Had great experiences. TCKline seems to have equally as quality reviews. Should be very happy with either.
