R44 Performance
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > BMW M3 (F80) and BMW M4 (F82) General Forum
      01-12-2022, 11:27 AM   #1
Tymula_81
Tymula_81's Avatar
87
Drives: F10 528 xdrive
F80 acceleration noise
Question for you guys. I have a 2018 f80 and for some reason while I'm driving i get this whine noise from the inside of the car. It kinda sounds like when you put a music system in your car and you get that feedback noise. Has anyone else had this problem. Only when I step on the gas tho. Thanks in advance
      01-12-2022, 12:28 PM   #2
F80_Kbo
24
Drives: 2018 F80 M3 ZCP
Could be the active sound
      01-12-2022, 01:18 PM   #3
spidy512
502
Drives: 2015 f80 M3
2015 BMW M3  [0.00]
Yo!
Is the sound system on or off? Does it go away when you are coasting or holding speed? Does it correlate to RPM or road speed? DCT or manual?
It could be a few things really. But these cars make all sorts of noises so maybe if you can help us drill down with some more info we can help ya get close or send you in the right direction.
josh
      01-12-2022, 01:25 PM   #4
Tymula_81
Tymula_81's Avatar
87
Hey
Yo!
josh
It's a dct transmission. The noise only accurs when accelerating. Let say I'm driving in manual mode I get to 3k rpm,let go of the gas then switch, the in between when I let the gas go and switch is when u can clearly hear it the most. The car has 40k mikes on it. I turned off the active sound to see if that was it but it wasn't.
      01-12-2022, 03:08 PM   #5
spidy512
502
Drives: 2015 f80 M3
2015 BMW M3  [0.00]
Thanks for the info,
Hmm. That is odd. As when you are shifting I would think any driveline whine would go numb as you let off the gas and the gears have less force on them.
Does it come from one spot or direction? Like behind you or right next you or in front of you?
I am sure others will chime in soon.
josh
      01-12-2022, 03:15 PM   #6
Tymula_81
Tymula_81's Avatar
87
Hey
josh
As I let off the gas when switching gear u can hear it whining down. I hear it on my passenger side front. I left my phone under the hood to see if it was coming from there but that wasn't it either. I feel like it's coming from the speakers but idk
      01-12-2022, 03:49 PM   #7
StanislavK82
87
Drives: 2016 BMW M3
Do you have anything plugged into the aux. input on the car? I only bring this up because I used to get a whine in my VW golf. I found out this was noise from my phone plugged in and charging. The charger was a cheap one that resulted in feedback through the output jack. When I got a better charger this went away. It's a stretch I know but worth asking.
      01-12-2022, 03:52 PM   #8
Tymula_81
Tymula_81's Avatar
87
Hey
Yea I have my BlackVue plugged into the passenger footwell, and I have 2 charger plugged in one in the front and one in the back. I will try that out thanks
      01-12-2022, 04:05 PM   #9
BzsBimmer
BzsBimmer's Avatar
3293
Drives: '23 G80 FO M3, M3 & MY Tezzy's
If you want to isolate audio (ground loop) you can try unplugging the amps (audio and active) and see if the hum goes away.
Could be driveline noise from axle/ rear diff. You can search as I believe this has been discussed prior. A lot of rabbit holes you can go down though lol.
spidy512502.00
      01-13-2022, 06:38 PM   #10
dezzracer
1189
Drives: 2018 M3 CS
Pull the fuses that run the audio (if possible) and test.
      06-13-2022, 03:14 PM   #11
bee500
bee500's Avatar
36
Drives: 2018 M2 LCI BSM
2018 M2  [0.00]
Any updates? I have the same buzzing noise you described.
IG: jmw_m2
      07-25-2023, 05:50 AM   #12
Tymula_81
Tymula_81's Avatar
87
Nope still can’t figure it out. Did you
      07-25-2023, 10:24 AM   #13
MethodRR
88
Drives: 2018 F80 M3
Is this happening at freeway speeds? At 70mph under light/med acceleration I can also hear what sounds like speaker whine coming from the rear.
My guess is that it's a loose ground somewhere in the speaker system. Haven't yet had a chance to dig in.
      07-25-2023, 12:32 PM   #14
Tymula_81
Tymula_81's Avatar
87
Me either I just ignored it with my music
      04-30-2024, 03:33 AM   #15
CeglA
33
Drives: BMW M4
Anyone resolved similar problem? I have the same sound since two months. Very annoying...
      04-30-2024, 10:51 AM   #16
Pewtinn
112
Drives: 2018 M3
Same noise here in my dct. I think it's normal lol
      05-03-2024, 03:40 PM   #17
Tymula_81
Tymula_81's Avatar
87
I hope so lol
      05-03-2024, 03:58 PM   #18
Pauldunlop13
425
Drives: M4 Convertible
I just hit 40k miles in my 2019 DCT - I don't have this noise
in a previous car, it was Alternator Whine - which when I turned up the sound, you couldn't hear it
so every time I drove my FIL somewhere, he would say - Man that is annoying - how do you stand it??
I would reply - it only happens when you are in the car..... because the sound level was sooooo low
2019 YMB ZCP convertible with Dinan Exhaust
2011 Ducati Diavel Carbon Edition
2015 BSM M4 Convertible - 2018-2019
2016 228Xi - 2017-2018
2003 Acura RSX Type S 2003-2017
f80post
