12-01-2014, 09:06 AM | #1 |
23
Rep 78
Rigid Collar for 1M
Anyone tried this on their 1M? Wonder how are the results.
It is made my Spoon https://www.flickr.com/photos/rla044...7633273470912/ |
12-01-2014, 10:50 AM | #2 |
Moderator
29430
Rep 13,108
///M is art ↔ Artemis
12-01-2014, 12:53 PM | #4 | |
27
Rep 231
Drives: 1M VO - #161 US
12-01-2014, 02:23 PM | #6 | |
292
Rep 2,898
They substantially increase NVH. Neil |
12-01-2014, 03:07 PM | #7 |
27
Rep 231
Totally different issue. Solid motor/tranny/suspension mounts replace rubber bushings with hard material. This simply makes an already solid attachment-point better.
(Maybe.) AFAIC, the jury is out on this one - a lot of positive reviews, but there are a lot of positive reviews for the $60 Turbo Intake Fan, too... |
12-01-2014, 06:15 PM | #8 |
Kind of a big deal
300
Rep 1,674
Drives: an 1M not often enough
solid connection is replaced with marginally softer but still non compliant material, so i'm skeptical on this product doing anything more than what a regular torquing or alignment would do, assuming something was misaligned or loose to begin with.
12-01-2014, 06:49 PM | #9 |
1518
Rep 4,744
Drives: S65 1M Clone & E92 M3 4.6L
12-01-2014, 09:13 PM | #10 |
83
Rep 562
Drives: 2011 1M VO
Too me this appears not to be a change to solid mounts, but rather substituting a more sturdy solid mount for a less sturdy/sloppy one. At no point in the film, at least, did they show a rubber mount being tossed. Looks like it would have no downside other than time and money; hard to know how much upside!
12-01-2014, 10:51 PM | #12 |
37
Rep 381
To me the point of the collars is two fold:
1) to make sure the subframe is centered up under the mounting bosses and 2) to make sure the subframe does not shift leading to suspension alignment changes. Neither one is a big concern since I don't know of any cases of movement with the subframe properly torqued in place. The examples shown don't show any movement, only slight misalignment which would be dialed out by a proper alignment job. And the rubber bushings will compress laterally no matter how sturdily the subframe is located. In my mind the key advantage of the solid SFB is the decrease in vertical compliance which affects the effective spring rate especially with stiffer springs. The collars won't have any effect on this.
12-02-2014, 02:39 AM | #13 |
127
Rep 1,054
Well, here is my two cents. Other than lining things up right the first time things are bolted up, to my logic there are negatives. For eg:
You're adding a some thickness between each bolt head the mounting point. By doing so, you would effectively be losing a thread or two in bolt depth into the hole. Given that the bolt is now sitting a few threads further out, you would need to over-toque all the bolts where a collar is placed to make up for it. You're adding a material that is soft enough to 'fill in' the gaps from just torquing , I am sure they would elongate from driving about under load. Like the others said, torque all your shit properly and dial out the variations with an alignment. The flex in the rubber bushings are better tackled instead. I recommend solid subframe bushings, adjustable rear toe arms (rogue/dinan) and some nice dinan monoball front control arm bushings. |
12-02-2014, 09:28 AM | #14 |
H O O N
86
Rep 694
IMO dialing out the variations with an alignment is just a band-aid that doesn't address how alignment changes as the suspension compresses; Static wheel alignment square to the body but with a subframe that isn't square would result in a wheel motion that isn't the same on both sides.
I think there is some merit to the mod, though not as much as Spoon makes it out to be. http://www.rigidcollar.com/bmw-bmw-1...e88-front.html http://www.rigidcollar.com/bmw-bmw-1...-e88-rear.html Cheaper option here : http://bit.ly/1tIkYPn anyone wanna be a guinea pig?
U WOT M8? Last edited by Snertz; 12-02-2014 at 09:55 AM.. |
12-02-2014, 12:11 PM | #15 | |
Kind of a big deal
300
Rep 1,674
And if factory misalignment could be noticeable, wouldn't car manufacturers want to fit these collars on press cars? |
