06-19-2017, 10:05 AM | #1 |
16
Rep 97
B58 Downpipe Install issues
So yesterday my buddy and I tried to install the VRSF catless DP on my '17 340xi. This was so much easier then the N55! So much more room to get to top bolt and sensors.
Once we finally had the stock DP out we started to install the VRSF one. We were able to get it to connect to the turbo just fine but we could not get the bottom to slide into my stock midpipe to clamp it. We then took it back off and tried to make sure we could slide it in off the car to no avail. We tried using WD-40 and still no luck. We had to just put the stock one back on the car because I needed to drive it today but was wondering if anyone else has had this issue? We measured the inside and it seemed to be the exact same size as stock DP but we did notice the walls were slightly wider on the VRSF one. |
06-19-2017, 07:08 PM | #3 |
BimmerPost Supporting Vendor
24279
Rep 190,975
Did you check with VRSF that the downpipe fits Xi models?
As far as i know , it has only been tested on RWD
eksigned139.00 |
06-19-2017, 08:37 PM | #4 |
112
Rep 969
06-19-2017, 08:57 PM | #5 |
16
Rep 97
06-19-2017, 11:26 PM | #6 |
24279
Rep 190,975
Reason why im mentioning it is because 1) ER RWD DP is different then XI DP 2) VRSF website mentions RWD only not the Xdrive
06-20-2017, 05:32 AM | #7 |
16
Rep 97
I just double checked and the email receipt I received when ordered lists that it fits xdrive and non xdrive vehicles. Thanks for the input though.
06-20-2017, 11:43 AM | #8 | |
282
Rep 775
2016 340i xDrive 6MT (regretfully sold)
2020 M340i xDrive |
06-20-2017, 11:54 AM | #9 |
16
Rep 97
06-20-2017, 03:35 PM | #10 |
282
Rep 775
I had the install done at a shop, I didn't do it myself so I would assume mine fit without issue. The shop never said anything to me about it not fitting
2020 M340i xDrive |
06-20-2017, 09:54 PM | #11 |
Cheapskate
4450
Rep 4,995
how far off was it? could you have pried out the edges of the pipe flange to get it to fit over, then clamp it down?
06-21-2017, 12:09 PM | #12 | |
16
Rep 97
I saw that people have mentioned heating up the end of the midpipe to expand it to get it to fit. My only concern with that is would it ever be able to slide back out? |
06-21-2017, 03:16 PM | #13 |
Cheapskate
4450
Rep 4,995
heating it up doesn't make sense to me. idk what was meant by that comment.
but i've had to use channel locks on my exhaust to pry out the flange slightly, slip it over, then clamp it down. you'd rather it be tight than loose so it seals properly. it's just metal so not really "fabbing" anything. |
06-24-2017, 06:34 AM | #14 | |
126
Rep 484
Drives: 440 xi MPPSK JB4
Location: Socialist People's State of NY - Long Island, NY
Heat only the part that is the outer pipe ... (I'm not familiar with down pipes so I can't comment which one to heat ). Don't heat the inner pipe since the tell expand and will not fit..
Heat causes metal to expand... its a common technique to get two pipes that are close to fit. But once it cools with the pipes connected it will not come off for sure unless it's reheated. I vote for heat... blow torch hot..$12.99 at Home Depot ... Quote:
06-30-2017, 12:35 PM | #15 |
24
Rep 106
Installed (reluctantly) my VRSF catless downpipe on my 340xi today. What a nightmare. It should have been super easy with all the room this thing has, but as I knew going into it...getting the downpipe on the stock exhaust was near impossible. I had to bang a supersized socket that graduated to a diameter larger than the pipe, essentially flaring it. Even then, it was a struggle. I'll back up and say it took me a frikkin' hour to find the nut from the Vband clamp that dropped into the black hole of an engine bay. It took me an hour and a half to get the downpipe on the stock exhaust. All said and done, it was about four hours. I used a lift. I can appreciate the sound and performance. I have to say, I am truly surprised at the smell from it. It's super strong when at idle with the windows down. No, I do not have an exhaust leak. I started it up on the lift and checked everything. In retrospect, I probably would not do it again. Now that it is on though...it's staying.
On edit: The VRSF DP fits the Xi models without clearance issues or need for spacers. The distinction from the ER, is the retention tab that bolts up like the stock one does. Since the VRSF doesn't have this, you can manipulate it as needed to fit. Last edited by Montego92; 06-30-2017 at 12:44 PM.. |
06-30-2017, 01:10 PM | #16 | |
16
Rep 97
06-30-2017, 02:56 PM | #17 | |
24
Rep 106
I don't see you getting them together, unless you are able to flare the stock exhaust portion. I was lucky to be at a place that had a massive socket. You might want to peruse Autozone or something similar for something you can smack with a hammer to flare the pipe. Once I got them both together, I was able to smack the tabbed portion of the stock exhaust back-to-front to complete the rest of the insertion. Best of luck hahaha. |
07-01-2017, 09:49 PM | #19 |
16
Rep 97
Yes the DP is now installed. We were able to heat the end of the midpipe with a torch and then slip the VRSF dp in. Hardest part then was just getting it lined up perfectly on turbo but it only took us about 3 hours to install with breaks. Sound is much better now. Thanks for everyone's advice here as it was all useful.
07-08-2017, 12:00 PM | #20 |
16
Rep 97
So after having dp installed for a week I wanted to point out some things.
1. Sound is much better. It sounds more raw and is much louder. 2. Burbles are louder which is great but still not as loud as my 335 with DP and mpe. 3. Smell isn't as bad as 335 or my old Mazdaspeed with catless dp. Very surprised by this. In start up u can smell it and when u first stop at a light but then it goes away. Again can only smell it with Windows down. 4. O2 sensor spacer is working like a charm. No CEL yet. |
