TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X6 Forums > X6 Photo/Video/Audio Gallery
      06-27-2015, 09:44 AM   #67
igorbmwx6
igorbmwx6's Avatar
162
Drives: 2016 BMW 328i F30
Originally Posted by Sim-Sima View Post
Can you please provide link for the wiring harness. I am doing this retrofit on my 2007 E70 4.8I. I already knew about the FRM3 module but didnt know about the LED module. Does that replace amother module, or is that new addition, if so should there be a harness pre-wired? Thanks
Not very clear as to what you are asking, but yes, you will need to replace your FRM3 module to the latest version as well as add an additional wiring harness to your existing headlight harness (they will run in parallel).
      06-27-2015, 12:56 PM   #68
gixxerboy63
Tanzanite Blue II X5M Pilot
gixxerboy63's Avatar
1059
Drives: M3, M4, X3 M40i, X5M
2017 m4  [0.00]
2010 BMW X5M  [10.00]
Originally Posted by X5_MSPORT View Post
Does anyone have an idea what color temp the LED headlights are?
I have Googled this question myself and have yet to find a definitive answer. The DOT allows a maximum of 6000k. I believe that factory Xenons are 4300k, yet the LEDs are quite a bit less yellow when broadcasting against a white wall.
My guess would be 6000k?
2020 X5M - Tanzanite II
2012 M3 - Alpine White
      06-27-2015, 04:17 PM   #69
UnicornM
UnicornM's Avatar
391
Drives: M
Could be onto something there. I've seen countless BMW 4 Series with LEDs and those certainly have a much greater blue look to them.
      07-03-2015, 05:34 AM   #70
UnicornM
UnicornM's Avatar
391
Drives: M
Just got my FRM3 and wiring harness from http://e-acca.com/ Took 14 days to get it. They come recommended from me if anyones looking for a speedy service.
Just waiting for my LED head lights to arrive but in the meantime i'm going to run the harness so its ready for final connections etc..
      07-05-2015, 12:42 PM   #71
igorbmwx6
igorbmwx6's Avatar
162
That is a very good idea. Running harness inside (may be a good idea to run it behind your CIC unit - center console), making necessary connections inside the fuse box (right hand side), making necessary connections to the FRM3 module (left hand side) may take one-day's work if you are doing this for the first time.
      07-24-2015, 01:42 PM   #72
Gatoferoz25
BeastM3r
Gatoferoz25's Avatar
1286
Drives: M3 COMP
I have a 2012 X5 M-Sport can i do this Type of MOD RETROFIT ?
Thanks for ur Help Brother
MORR WHEELS - VORSTEINER HOOD - FRONT LIP-CF REAR DIFFUSER - LED HEADLIGHTS - BREMBO BRAKES - Kw SUSPENSION - EISENMMAN - JB4 - SPORT STEERING WHEEL..!
      07-27-2015, 10:20 PM   #73
gixxerboy63
1059
2017 m4  [0.00]
I think your headlights are shaped differently: they are more rounded at the fender.
The only LEDs I have seen are for the E70/E71 X6, X6M and X5M only.... these headlights come to a point at the fender.
      07-28-2015, 01:24 PM   #74
Gatoferoz25
BeastM3r
1286
Drives: M3 COMP
Yeah I know that I'm doing fenders and bumper most likely M conversion just need to know about wiring and stuff
      07-31-2015, 11:22 AM   #75
PARTS@STBMW
PARTS@STBMW's Avatar
2713
Drives: BMW
Well done!
      08-24-2015, 01:51 PM   #76
E92M77
E92M77's Avatar
Drives: E92M, AM V8V, W212 E63
Looks AMAZING!!
      08-28-2015, 12:48 PM   #77
x6mlover
Drives: BMW X6M
Man this is great work right here. I have a quick question so is the 2013-2014 headlights (minus the 2015+) interchangeable with the 2010 x6m?
      09-02-2015, 08:39 PM   #78
Gatoferoz25
BeastM3r
1286
Drives: M3 COMP
Hey brother did u had to get this connectors to Finnish ur headlights retrofit ?
( D , E , K ) thanks
      09-05-2015, 09:44 AM   #79
igorbmwx6
igorbmwx6's Avatar
162
Hey, these connectors were all together in the same package with wiring harness. I did not have to get them separately, but they are required. You can also purchase them just about from any electronics store or maybe even home depot.
      09-05-2015, 09:45 AM   #80
igorbmwx6
igorbmwx6's Avatar
162
That is correct. 2013-2014 headlights will fit in to your 2010 X6M.
      09-16-2015, 11:59 PM   #81
xpl0sive
28
Drives: bmw
Do you have any instructions for the coding procedure?
      09-17-2015, 04:52 PM   #82
Cattivo
FDNY Engine 55
Cattivo's Avatar
681
Drives: X5M, X5 50i Msport, EscaHoe
http://www.ebay.com/itm/BMW-OEM-13-1...3D151449662062
      09-17-2015, 08:28 PM   #83
Gatoferoz25
BeastM3r
1286
Drives: M3 COMP
Do u have urs already ?
      09-17-2015, 10:57 PM   #84
igorbmwx6
igorbmwx6's Avatar
162
Below are the coding instructions. Nothing too complicated:
LED Lights: I just modified my VO String in NCS Expert to add option $552 and delete $522, $524 to my CAS and FRM module
Change production date to #0412
Remove $522 and $524 (AHL if you have) and add $552 to CAS & FRM and code car.
If you are not comfortable coding the whole car then just code CAS, KOMBI and FRM with expert profile.
REMOVE:
$522 - FRM//Xenon light
$524 - FRM//Adaptive Headlights
ADD:
$552 – FRM//Adaptive LED headlights with Anti-Glare High-Beam Assist, incl. variable light distribution and cornering lights
Installing new FRM module:
coding FRM module step by step:
A:
1.open NCS expert
2.File-Load profile
3.select EXPERMODE
4.press F1
5.press F3
6.select E70<for E71>
7.press BACK
8.press F3<CHOOSE ECU>
9.select NFRM
10.select FA_WRITE from CHANGE JOB
11.press F3<EXECUTE JOB>
B:
1.open NCS expert
2.File-Load profile
3.select EXPERMODE
4.press F1
5.press F3
7.press BACK
9.select NFRM
10.select SG_CODIEREN from CHANGE JOB
Appreciate 2
boneca2028.00
      09-18-2015, 01:39 AM   #85
m5 guy
m5 guy's Avatar
1743
Drives: 2020 M5 Comp
That's some good info right there. Thanks for posting the coding stuff, I'm sure it will help many of us out!
Btw do you do remote coding by chance if we provided the obd cable?
2020 F90 M5 Comp Oxford Green Metallic II-Aragon JOURNAL
2016 F10 M5 Space Gray-Black SOLD
2012 E70 X5M Monte Carlo Blue-Silverstone SOLD
2001 E46 M3 Oxford Green Metallic II-Cinnamon SOLD
      09-18-2015, 04:55 AM   #86
Cattivo
FDNY Engine 55
Cattivo's Avatar
681
Not yet
      09-18-2015, 08:32 AM   #87
Gatoferoz25
BeastM3r
1286
Drives: M3 COMP
Not yet
Those right there they're not complete set tho !!!
They will work with x5M and x6M plus x6 correct ??
      09-18-2015, 12:25 PM   #88
Cattivo
FDNY Engine 55
Cattivo's Avatar
681
That's my problem, I can't seem to find a complete set. They'll fit X5/6 M, X6
Tags
headlights, led, tail lights, x6m
xbimmers
