07-09-2021, 09:23 PM | #1 |
Rep 19
Found my unicorn
Found a car on Monday, put a deposit on it that night, without even seeing it. Picked it up today, drove 1k kms to get it. 2012 135i, 34,000kms, 1 owner, Artic White, Coral Red leather, manual, brand new rear tires, original run flats on the front. Was told it was the Premium package, but has manual seat, no garage door opener, or digital compass.
One question I have is I did manage to get my Samsung S9 connected by bluetooth, and the phone connected through iDrive, but I was getting complaints about my voice cutting out with multiple people. Has anyone experienced this before? I bought a Scosche bluetooth adapter that I may try, to see if it works better, but I would prefer to use the built in if possible. Last edited by mrmarkfr; 07-09-2021 at 09:29 PM.. |
07-09-2021, 10:50 PM | #2 |
34
Rep 175
Congratulations on the find!
Try the obligatory - remove the car from the phone and the phone from the car. Turn off the phone, turn off the car. Then start both up and try a fresh bluetooth pairing. |
07-09-2021, 11:22 PM | #3 |
Rep 19
Thanks. Will try that tomorrow. Just realized, it seemed to work fine for a while, just the last 2 hours of the trip was an issue.
07-09-2021, 11:31 PM | #4 |
512
Rep 570
Congratulations. An impressive find, let alone within driving range (and not, say, across a currently impassable national border).
You can look up the VIN on mdecoder.com to see exactly what it came with. |
07-09-2021, 11:40 PM | #5 |
34
Rep 175
Its a weird issue, also check if the phone is overheating while it is happening. Or if Nav is trying to take over audio through bluetooth.
Just some ideas for ya. Pics of the car forthcoming? |
07-10-2021, 04:51 AM | #6 | |
Rep 19
Edit, Just saw the links below allowing me to post, here you go. |
07-10-2021, 04:56 AM | #7 |
Rep 19
I tried to use mdecoder, and I get stuck in a loop of captcha. I used Bimmerworks, but the options generated don't match exactly with codes I see on some sites, but seems to work if I google the codes
07-10-2021, 05:07 AM | #8 |
Rep 19
I got VERY lucky with it. I had found a similar, but vert, with double the mileage, and was planning to go see that next week. The next day, this one was posted. I sent the deposit that night, and the seller was fantastic. It was only up for 2 hours, and the seller pulled the ad when i sent the deposit.
Almuliman511.50 |
07-10-2021, 07:29 AM | #9 |
512
Rep 570
07-10-2021, 01:58 PM | #10 | |
Rep 19
Tried my phone again today, without doing anything, and it was better today. Not sure what the difference is, but working for now |
Almuliman511.50 |
07-11-2021, 10:17 PM | #11 |
34
Rep 175
Car looks great! Alas I just swapped mine for an M2 so my adventure ends with the 1 series whiles yours begins!
Amazing car with the truly unicorn spec. Super nice find - now it just needs a set of Apex rims on it ;-). |
10-17-2021, 02:34 PM | #13 |
191
Rep 506
Drives: 2010 128i 6MT Sport Pkg. 18"
Good for you. That's what you have to do for the right car - nail in down with a deposit and be willing to travel to wherever it's at. Clean, low klicks, manual trans. - perfect. Now just put it away come winter and you'll be smiling for years to come.
10-21-2021, 09:13 PM | #15 |
Rep 19
It's getting an oil change next week, then getting parked with a Noco charger on it for the winter.
10-22-2021, 11:16 AM | #16 |
851
Rep 2,281
Congrats, nice car, you struck fast-that's the way to do it. Few more things to do for winter storage: read here: https://www.1addicts.com/forums/show...winter+storage
10-22-2021, 06:39 PM | #17 |
Rep 19
Thanks, I had a 96 Miata for 7 years before this, and have had bikes for many more years that that.
My normal procedure is change the oil, have a battery tender (Noco), inflate tires to about 40psi, and cover the inside, trunk and engine bay with Bounce sheets (to keep out mice). Good idea on raising the wipers off the glass. I also put in non-ethanol fuel with Stabil, and will park it only after the engine is hot. |
Olgeezer1190.50 |
10-23-2021, 07:11 AM | #18 |
BMW Owner Since 1971
2276
Rep 1,422
Drives: 1964 700 Sport Cabriolet
Without your build or VIN, looks to be non-Sport or non-M-sport. Does it have sport seats? Happy to check the VIN for you, if I can. Just need last 7-digits.
10-23-2021, 03:03 PM | #19 | |
851
Rep 2,281
10-31-2021, 01:14 PM | #20 | |
191
Rep 506
