6MT High HP Misfire issue solved
12-14-2012, 04:36 PM | #89 |
38
Rep 864
Drives: '08 E92 335i
Dang, ya'll cry when Shiv doesn't give info and say he's hiding info, now ya'll cry when he does give info and say he's talking out of turn because it's not 100% proven.
Take your pick! |
12-14-2012, 04:38 PM | #90 |
1748
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
12-14-2012, 04:43 PM | #91 | |
19
Rep 650
What I suspected with the phantom misfire guys is that they were against the limit and then the misfire occurred as the torque fell off a bit and they started to bounce away from the movement limit. But if that's also what's happening to you, I wonder why you don't see phantom misfires at 3k or wherever you start to come off the movement limiter? My guess is that if people really want to use the DMFW in extreme power situations they will want to put stronger springs in them to keep them in the normal functioning zone. I'd like to see someone try making a lightened DMFW and do that with it. |
12-14-2012, 05:27 PM | #92 |
2020 Z4 M40i - 2022 M4C Convt
3131
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
Has anyone looked at the Harmonic Damper to see if its design parameters have been exceeded due to the increased power & twisting force. BMW uses a tuned rubber damper which is much more important is managing crankshaft harmonics than the dual mass flywheel is.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
12-14-2012, 05:32 PM | #93 |
76
Rep 1,883
To be fair, I highly doubt ANYONE thought the DMFW would be an issue. People are still saying that it is a long shot, so it's not really fair to expect any kind of forseeability if it is indeed the cause.
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
12-14-2012, 05:41 PM | #94 | |
1748
Rep 17,960
Drives: A Lot
A DMFW is something completely different and will behave differently based upon applied torque and RPM. Both elements are coupled to something heavy and metal. What happens to the coupling mechanism (springs) and it's effect of the two masses that are spinning semi-dependantly with each other, and the effect this racket has on the toothed wheel as it passes the magnetic pick-up is the real question here. shiv |
12-14-2012, 05:44 PM | #95 |
48
Rep 1,290
along those lines... lol.. there was an uproar a ways back about how changing the pulley was a bad idea due to potential harmonic imbalances. Has anyone changed a pulley to a light weight one and then experienced "phantom" misfires?
not neccesarily speaking about the ST guys but any one in general with higher HP/TQ and tuned
- Proven Power Tampa Built 6466 ST N54 6AT WR 711whp 637wtq -
12-14-2012, 05:44 PM | #96 |
3131
Rep 5,264
To be fair nothing has changed.....you cannot run the ST's at claimed WHP/WTQ on stock components. Does not really matter if the flavor of the week is the flywheel or shalfshafts
Kevin
12-14-2012, 06:02 PM | #97 | |
16
Rep 227
My thoughts were so what? At this level of modification, it can be said that the car isn't really stock in a lot of places - and why should it be? Best bang for the buck - tune and DCI and call it a day.
Vishnu/FFTEC Single Turbo (58mm) 6AT ... 60-130 in 6.881 seconds
Vishnu Procede Rev.3, Vishnu PWM Meth Kit, AE Exhaust, Helix IC, Forge DVs, Wavetrac LSD #### IT'S FOR SALE ### |
12-14-2012, 06:03 PM | #98 | |
17
Rep 283
I think I get it nextweek,I want put it and procede togther,because I think the vishnu PWM kit work very very good. |
12-14-2012, 06:06 PM | #100 |
52
Rep 748
This video was helpful for me to understand how a DMFW works, especially under heavy load.
Is there any way to upgrade the springs in the DMFW? Why would a light SMFW have any more chatter than a heavy SMFW? Is there anyway to sound proof the bell housing lol...
2008 335I E92, AW, VFF700, 18" Forgestar F14, M3 front/side, M-tech rear, AMS IC, H&R Touring Cup Kit suspension, HID AE, ER Charge Pipe & Synapse BOV, CIC Retrofit, Quafie, DSS, Defiv Lockdown, SPEC 2+/Steel SMFW, Walbro 450
12-14-2012, 06:07 PM | #101 |
76
Rep 1,883
A piggyback can't turn it off, as it is part of the code within the DME. But, Vishnu has the capability of turning it off with a flash.
12-14-2012, 06:50 PM | #102 |
125
Rep 3,004
I think if you put in a spring that's too stiff, it will remove the dampening properties, so you might as well just have a SMFW. There would need to be a lot of guess and checking on this one.
2007 E92 6MT SGM: MusicarNW Level 2, Procede Rev 2.5, FFTEC/Vishnu LPFP with Flexfuel Sensor and Flash, M3 Offset V701's, WaveTrac LSD, Michelin PSS, Downpipes, M3 Control Arms, TCKline D/A Suspension, LCI Tail lights, Lux AE's, ER Charge Pipe, DCI's, Mtech Front and Rear, M3 Sideskirts, HPF Stage 1 Clutch
12-14-2012, 07:46 PM | #103 | |
76
Rep 1,883
I think when I replace the DMFW, I will try to analyze it and figure out what the resonance frequency is. It might take a refresher course in system dynamics, but could be a fun exercise.
12-14-2012, 07:57 PM | #104 | |
3131
Rep 5,264
Its interesting to note that every day thousands of 335’s run up through the full rpm range without misfiring but the ones with the extra power are having issues & only some of those according to your post. The damper could be an issue here because its common practice in racing applications that the crank damper is changed from the stock one to one suited the characteristics of the new higher powered engine modifications. At least its worth looking at because harmonic balancers fail at different rates based on how fast the specific batch of rubber starts to deteriorate. What flywheel are you running & are you misfiring? If I read it correctly you did not have the problem only a few did. If that's the case why are you so sure its the flywheel to declare the problem solved in your headline & not something else? BTW you might want to check your facts on the "Magnetic Pickup". The CPS is actually 'hall effect' & pretty much vibration proof.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT Last edited by BEAR-AvHistory; 12-14-2012 at 09:05 PM.. |
12-14-2012, 08:07 PM | #105 | |
3131
Rep 5,264
It would appear so far no one has achieved a fully successful implementation of this system regardless of what they have spent.
Kevin
12-14-2012, 08:27 PM | #106 | |
Rep 538
Let's be clear; you need to seperate the cost of the single turbo kit from the cost of modifying the whole car. Those are two seperate things. Most owners who get the single turbo kit already have supporting mods, and if they don't they take responsibility for choosing whatever supporting mods they want on their car. It's their car and their choice. |
12-14-2012, 08:37 PM | #107 | |
Rep 538
My personal theory is that the DME applies different levels of filtering to the RPM signal to keep the signal clean and reliable. Naturally there is less time between ticks at high rpm so the filtering has to be reduced to maintain high resolution. |
12-14-2012, 09:13 PM | #108 | |
3131
Rep 5,264
Kevin
12-14-2012, 09:22 PM | #109 | |
1748
Rep 17,960
Drives: A Lot
