11-15-2012, 05:23 PM | #1 |
Usofstance
81
Rep 671
328i 6spd Downpipe Install And Video!!
So i should be installing it tm, just wondering i know i will have a check engine light. The big problem is i dont want to have the light come on and go to the dealership. So should i get the bms check engine light fix? How do you install the bms engine light fix. Let me know i am a little confused.
With the downpipe the car shouldn't have problems rite? Lolz. :confused0068 UPDATE Update after doing 25miles! Inside view Update 11/20/12
2013 328i 6MT Bagged
IG Stu_UnitedStatesOfStance United States Of Stance Last edited by slmdgee; 11-20-2012 at 02:39 PM.. |
11-15-2012, 08:52 PM | #2 |
45
Rep 202
So the way the two O2 sensors work is that one reads before and one reads after the catalyst. Removing it causes the car to think it has a bad cat so most cars will throw a light but it should not result in limp mode or anything like that.
I personally wouldn't take a car with a downpipe into the dealership because it's really obvious looking unless you already know your service guy is cool but he probably isn't because you haven't shared enough ale with him. I have basically a fancy o2 sensor with its own computer that sends a fake value back to the ecu based on what it reads that I've used on a 2010 Porsche most recently so I know you can lie to the ECU to avoid the code all together but I'm not sure if a simple $25 O2 simulator can lie to the newer cars but that is the route I would look for. |
11-15-2012, 09:31 PM | #3 |
Usofstance
81
Rep 671
Thanks for the reply i just wasn't sure how it works on a turbo car... I had a g37 with full bolt ons and never had a issue. So i got 200 miles on the car i might just wait till 500 and do the down pipe? What you guys think? I really hate the autostart button it really annoys me! Hahha
IG Stu_UnitedStatesOfStance United States Of Stance |
11-15-2012, 10:49 PM | #4 |
45
Rep 202
aFe says "A check engine light will emitt and aFe recommends using a programmer but it is not necessary" in the product docs so they are saying the car will not go into limp mode or anything crazy but the light will be on.
I don't really believe in break-in but I never plan on keeping a car more than 20k miles so I personally would install the downpipe and everything you plan on having the first day you drive it :P Enjoy the car As for autostart, my dealer won't disable it but there is supposed to be a BMW instruction to the service departments to be able to do it if you check with them and get lucky. Short of that, coding for $20 was effective for me because autostart is annoying. |
11-16-2012, 06:49 AM | #6 |
Usofstance
81
Rep 671
Alright guys i think ill do it today than as soon as i get out of college. I cant wait for my coil overs to come in!!! They said about 3 weeks
11-16-2012, 07:34 AM | #7 |
35
Rep 356
11-16-2012, 07:53 AM | #8 |
Rep 74
You may be able to avoid a CEL by using a "mini cat O2 sensor CEL fix", from Big Daddies Garage (easy to find with Google). You would use this with the second (rear) O2 sensor. It's an O2 sensor adapter that has a built-in miniature catalytic converter. I haven't tried this on my F30, but I have used one for track days with my Exige, and it worked fine. This may be a cheaper and simpler solution than patching the ECU.
(no affiliation with Big Daddies Garage, just a satisfied customer) HTH,
-Ed
2013 F30 328i M Sport 2008 Lotus Exige S240 |
11-16-2012, 07:58 AM | #9 |
Usofstance
81
Rep 671
Okay ill try to do it today, just a little hard since the hurricane wiped my house. Ill try my best.
11-16-2012, 08:27 AM | #11 |
Usofstance
81
Rep 671
It wasn't man, i actually owned a g37s 6spd with all bolt ons it got flooded :X. So i found this one in va and i got it ordered to me. My car is the one with the bluetooth and usb removal :X
11-16-2012, 04:07 PM | #12 |
Usofstance
81
Rep 671
Well here's how the exhaust sounds stock Check out this video on YouTube:<br/><br/>
I didn't have time to do it today. Maybe next week now since my whole weeknd I am busy
11-17-2012, 03:54 PM | #16 |
Usofstance
81
Rep 671
Everything is stock!! No smell! It's getting colder so it deff back pops alot more when in first gear. Also pull harder but i have like 300 miles now. I dont really like to beat on my car and i am going to break it in properly.
11-17-2012, 08:05 PM | #18 |
Usofstance
81
Rep 671
Yes it does, the install was fairly easy.. I sprayed pb blaster on all the nuts and everything came off easy. I got pictures which i will post when i charge my phone. I tried doing a little diy hahah
11-18-2012, 07:26 AM | #20 |
Usofstance
81
Rep 671
It's really not that loud. Literally inside no drone. Sounds how it should of sounded from the factory.
