02-12-2024, 02:04 PM | #1 |
164
Rep 427
Drives: F87 M2 DCT, F15 X5
18x10 ET25 Fitment Question
Hello! I am considering buying some wheels and tires from an M4 racing buddy. He is selling 18 x 10 ET 25 Apex EC-7 with 275/35, RE-71RS tires. I am concerned they might not fit in the rear. I am on stock suspension with 3° camber upfront and 2° camber in the rear. What do you think? Thanks! I did search this already, but couldn’t find a clear answer with the stock suspension.
‘18 F87 M2 DCT
'17 F15 X5 xDrive35i M-Sport Sold in 2023 '12 F30 335i 8AT Sport Line Sold in 2020 '08 E92 335xi 6MT Sold in 2016 '08 E90 335i 6MT - FBO |
02-12-2024, 02:26 PM | #2 |
738
Rep 586
Calculator says the outer rim will poke out 6.3mm more than my current setup (18x11 +44) which seems like it would contact because my setup is at the limit to my eye.
I run that exact wheel/tire you mention up front, so I can test mount it in the rear and see but uh… not feeling confident. That said, with -2.5* or more of neg camber in the rear maaaybe it’s possible? I know the Team Schirmer E88s are more aggressive than what I run in the rear and they make it work so maybe you just need to want it Lol. |
02-12-2024, 02:30 PM | #3 |
164
Rep 427
I just walked out an eye-balled my stock wheels and 265 width winter tread on the back... it would be an extra 15mm over stock... really close.
‘18 F87 M2 DCT
02-23-2024, 11:24 AM | #4 |
4024
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
Yeah, it'll be close. I sometimes run 10.5 ET36 with a 285/35r18 and that looked like it poked at normal ride height (but never rubbed under compression with -2deg camber). 10 ET25 will be another 5mm poke.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
03-05-2024, 07:29 PM | #5 |
Rep 9
10" +25 is at the absolute limit with stock upper arms. And you'll need to run the max camber with slightly stretched tire setup to clear. But it is possible.
If you get adjustable upper arms, you can make it clear no problem. |
projekt-47.50 |
03-05-2024, 08:07 PM | #6 |
164
Rep 427
I ended up with 18x10 +40 square, and a 15mm spacer up front. Thanks everyone.
‘18 F87 M2 DCT
projekt-47.50 |
03-06-2024, 08:42 AM | #8 | |
Rep 9
Also depends if you're running all seasons vs 200tw track tires. |
