M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > 18" Winter Wheels Now Available From Tire Rack!
Closed Thread
      10-04-2016, 02:14 PM   #1
Rudy@tirerack
Moderator
123
Drives: rudy@tirerack.com
Looking to run a 18" square setup this winter?
Finding a 18" wheel that clears the large brakes on the M2 can be difficult. Tire Rack now has several options available that are designed to fit the M2 properly.
To find the 18" wheels, follow these steps:
1. Click this link http://www.tirerack.com/snow/WinterP...ModClar=&a=BS4
2. Select build your own 18" package
3. It will first bring up the tires. Select the tire of your choice, click "add to package". (if you do not want to purchase tires, just select any one of them and then later remove from your cart)
4. Now it will bring up the 18" wheels. There are about 20 model to choose from. Once you select a wheel, add to cart.
5. Next it will ask you if you would like to add TPMS sensor and mount & balance.
6. Finally, you will be in the cart with your selections. (This is where you can delete the tires if you do not need tires)
If you have any questions, please contact me directly. Email to Keith@tirerack.com for fastest response.
Thanks!
As always, If you do order online, when checking out please be sure to reference "Keith/F87Post" as your previous contact. This is the only way the forum receives credit.
Appreciate 4
Closed Thread
m2
