Modern cars, pollution and mpgs
02-16-2016, 08:38 AM | #1 |
283
Rep 2,343
Just went out for lunch. Came back to my office where there's a round about. A guy in an Audi decided to go when he should have waited and put his foot down to keep ahead of me.
I think it was an A4 Avant, similar to the BMW tourers. The fuel was just pouring out of the exhaust all over the road. Not a light stream but like a hose. That can't be good for the mpgs! I also wonder what impact poring diesel all over the road has on the environment? For one it must be dangerous due to causing skids. Can't help but think though putting out diesel all over the place is far worse than CO2, water and soot. I wish now I'd told the guy but I imagine alot of cars are tuned rich like this.
GC Turbos, FBO, JB4, DCT, Port Meth injection, BMS Charge Pipe, NGK plugs. EBC brakes and pads, LED Angel lights, LED foglights, LCI rears OCC, Braided brake lines. Custom Diff Lockdown Kit, VTT inlets, TMAP, stage 2+ fuel pump
11.79@119mph (stock turbos) 11.74@129mph (GC Turbos) |
02-16-2016, 10:02 AM | #3 |
680
Rep 2,445
Drives: 2018 630iGT sport
It's just condensation/water. Usually get loads build up if you only do short journeys, so it never really gets hot enough to evaporate it all.
02-16-2016, 11:06 AM | #4 |
283
Rep 2,343
The amount that was pouring out, it's hard to imagine it's water but I do wonder how it could get through the cats etc. Maybe it was a petrol. There was no smoke tbh.
02-16-2016, 11:45 AM | #5 |
146
Rep 2,337
The amount of petrol you actually use when driving along is tiny. You'd be flooding the engine with fluid and it would just not run if you were leaking a lot of petrol.
02-16-2016, 11:59 AM | #6 |
481
Rep 1,268
Spotted the same thing coming out of a 2014/newer shape 3 series, 320d i believe. I did manage to let the chap know though..
I'll try dig up the dashcam footage if anyone fancies a look. |
02-16-2016, 05:23 PM | #7 | |
680
Rep 2,445
Liquid coming out of an exhaust is water vapour produced from combustion/condensation build up. That much fuel would never pass through an engine, mainly because the engine simply wouldn't be running if that were the case. The Mazda rotary engines were renowned for many engine quirks/ faults, one of which was the passing of unburnt fuel into the exhaust and cat due to dying ignition coils. The cat would glow red hot due to the fuel then burning in the exhaust, eventually needing cat replacement. Even when that happened, no fuel "poured" out of the exhaust. |
02-16-2016, 06:00 PM | #8 |
39
Rep 133
water / condensation for sure. As already mentioned, any unburnt fuel entering the exhaust would ignite the minute it touched the hot exhaust manifold popping and banging, or if it made it that far the cats would do the same, eventually killing them.
My 335i pops a bit on over-run, or if you tip the throttle a tiny bit and back off. Interesting, as I thought direct injection engines would be more precise that that. Not complaining though, I wish it did it more often like the N55's, together with that duramax-style engine and turbo sound |
02-17-2016, 11:54 AM | #9 | |
283
Rep 2,343
Now I know this guy didn't have water injection (or at least assume it's very unlikely) but the amount of liquid that can pass through an engine is quite amazing. At 4000 rpm, a speed it wouldnt take long to achieve in 1st gear, the engine is doing nearly 67 revolutions a second. These cars have water injection and may well be decatted but look how much liquid they can pass through the engine without hydrolocking. I suspect the guys car could have been cold as he's just come from an office car park. So I don't know if fuel could pass through a cat in a cold state. Yes he could have driven in and driven out with a warm car. Anyway I'll assume it's water vapour then that settled in the exhaust. Thanks
02-17-2016, 05:05 PM | #11 |
146
Rep 2,337
Liquids don't compress (not in an engine anyway). The valves are relatively tiny too. You'd never get that much fluid through them. The water is just sat in the backbox or wherever. |
02-18-2016, 03:28 AM | #12 |
39
Rep 133
Surely it would hydrolock (https://en.wikipedia.org/wiki/Hydrolock) the engine if that much water even came close to the cylinders...
Squirted it up the exhaust pipes, seems to be a big thing on youtube for some reason... |
02-18-2016, 05:11 AM | #13 | |
283
Rep 2,343
On my water\meth kit the pump can flow 4.9 litres a minute. The dual nozzles limit flow to 1.26 litres a minute. That's actually not that much. Next time I'll hold a lighter under that Audi and confirm water or not.
02-19-2016, 02:54 AM | #14 |
136
Rep 5,050
Quantities of neat petrol entering the CAT would destroy it fairly quickly and there'd probably be flames shooting out of the exhaust when it ignited.
