11-23-2020, 07:45 PM | #1 |
20
Rep 245
Rod bearing replacement
I have an 09' M that has 133k on the odometer, but haven't done the rod bearings. Does anyone have a recommendation for a shop to do rod bearing replacement? or if someone was willing to tackle it, I'd obviously entertain that as well. What would the expected range in cost for a project like this be? Thanks for the help.
11-25-2020, 07:47 AM | #2 |
24
Rep 79
Drives: 11 E92 m3 6mt
Check out FlimFlamSpeed in Richmond. Single guy shop that does amazing quality work. I’ve had him do my rod bearings, engine mounts, and spark plugs good pricing and good work.
Was roughly ~2800 for everything which pretty reasonable compared to other shops again the quality and trustworthiness too goes along way with these cars. http://www.flimflamspeed.com/ Last edited by Macpsi; 11-25-2020 at 10:55 AM.. |
11-25-2020, 08:42 AM | #3 | |
282
Rep 397
Drives: BMW TBD (Future Purchase)
My car has 80k miles, so I am looking to replace my RB at some point in 2021. From my research, here are the options for me locally in Washington DC area, and one up in NJ:
AutoCouture Motoring, Fair Lawn, NJ (link to RB work and pictures): https://www.m3post.com/forums/showth...arings&page=21 GT Peace, Chantilly, VA (recommend by forum member) https://gtpeaceauto.com/ Road Race Technologies (RRT), Sterling, VA (recommended by forum member): http://www.rrtautomotive.com/ Prices vary from $2500 on up, depending on if you get motor mounts replaced at the same time, which is highly recommended since normally they are shot and you are already there from a labor perspective. Quote:
BMW TBD Previous: 2011 E90 M3 | LMB | DCT -- 2006 E90 330i | 6MT -- 2001 E39 540i | 6MT -- 1997 E36 M3 | Techno Violet | 5MT |
11-25-2020, 02:54 PM | #4 |
I even mod my cereal
247
Rep 3,441
Drives: 11 ZCP DCT M3 14 328d 21 GT4
another vote for GTP. Great shop and good guys
2011 Mineral White M3 ZCP - Opticoat, Ventureshield, some CF, B&B exhaust, AFE Intake Vorsteiner VFF 101s Ohlins
2014 Mineral White 328d Xdrive Wagon - Opticoat, Ventureshield, B8s, H&R, Apex SM-10s Hawk Pads 2021 718 Cayman GT4 - Fire extinguiser |
11-25-2020, 03:36 PM | #5 | ||
20
Rep 245
11-25-2020, 04:28 PM | #6 |
282
Rep 397
With 133k miles, you could gamble and keep driving it, but if you spin a bearing, that is $15k MINIMUM to replace the engine with one from the junkyard.
Ironic Note: You most likely will have to do the RB service on the junkyard engine before you put it in your car since you don't have maintenance history for the car/engine So I would argue "preventative maintenance" is kind of understating the issue. My preference would be to call it "Catastrophic Engine Failure Insurance" Replacing the motor mounts you will probably see/feel an immediate difference because with 133k miles, the engine has dropped down and is essentially riding directly on the subframe. Turnaround time for the RB service and motor mounts from the shops I contacted is two days, some would prefer 3 days. I also may schedule mine around the time my car is due for an oil change since they'll need to do that anyhow as part of the service.
SYT_Shadow11500.00 |
11-29-2020, 07:55 AM | #8 |
282
Rep 397
Good to get another recommendation for RRT; how much was it, and what brand RB and bolts? Did you get the motor mounts replaced? If you replaced the MM, were they OEM or a different brand?
11-29-2020, 09:56 AM | #9 | |
128
Rep 127
I will check, but I believe it was right at three grand. |
br2wdc281.50 |
11-30-2020, 02:27 PM | #11 |
282
Rep 397
Excellent always good to get another recommendation; any additional details? Cost? Timeframe? Type of RB/bolts? OEM or other brand of MM?
ha998193.50 |
12-01-2020, 05:42 AM | #12 |
98
Rep 68
12-03-2020, 07:46 AM | #13 |
Rep 17
Another vote for RRT. I had my RB's done on September of last year. BE bearings with BE spec ARP studs were used. The job on my car was finished by the end of following day. If they don't run to any surprises with your car I'd expect them to take just as long.
br2wdc281.50 |
12-03-2020, 08:38 AM | #14 |
282
Rep 397
Appreciate your recommendation and confirming RRT did a good job for you, and the timeframe.
12-03-2020, 02:20 PM | #15 |
815
Rep 7,752
I agree that RRT is a great place to have RB done; I've sent quite a few people there b/c of their experience. Getting motor mounts done is also a good idea.
For this engine unfortunately, RB are just ongoing maintenance so just plan for it
Paul Seto - BMW Car Club of America
President, National Capital Chapter (MD/DC/NoVA) Director, National Events ///M Chapter Become a BMW CCA member; Click HERE to join and use my member #339225 for a referral Join our NCC Facebook Page |
12-03-2020, 03:25 PM | #16 |
282
Rep 397
Thanks Paul for another recommendation/confirmation for RRT. I also see you are the President of the local chapter of the BMW CCA, and I hope in 2021 to come to an event once COVID-19 has been "vaccinated" into submission
I'm driving my M3 a bit more then I thought mainly because I like to smile , so it will probably be sooner in 2021 then I anticipated to get the RB/MM service done.
12-08-2020, 10:14 AM | #18 |
282
Rep 397
Thanks for the recommendation
01-06-2021, 12:31 PM | #19 | |
815
Rep 7,752
br2wdc281.50 |
01-24-2021, 06:02 PM | #20 |
Rep 7
Airpark Auto Service in Gaithersburg. Ask for Nelson. Did mine and 3 other friends of mind. You can provide your own bearings or you can discuss with him what you would like. I used BE bearings and ARP bolts. My friends have used VAC and OEM bearings. So it depends on you. I think it was right under 3k for me. (With oem MM)
02-02-2021, 07:59 PM | #21 |
687
Rep 973
Drives: 2012 E92 M3 DCT ZCP
Maybe a bit farther from you, but Bavarian Specialties in King of Prussia, PA (about 30 minutes west of Philly) did my RB's 2.5 years ago and did a great job. They've been racing and wrenching BMW's for many years, and have done many RB replacements on these cars.
I went with BE bearings and ARP bolts and also did motor mounts at the same time. Cost me about $2,800 with oil change, new pan gasket, etc. and she's been running like a dream ever since. I think the car was there about 1.5-2 days.
2012 E92 M3 | ZCP | DCT | Space Grey Metallic | Black Novillo | BE/ARP | MPE V2 | AA green filter |BMW CF Rear Spoiler, RW Carbon Diffuser, CF Front Splitters | DTEC 160W Angel Eyes
br2wdc281.50 |
02-02-2021, 08:11 PM | #22 | ||
282
Rep 397
Thanks gentleman for the recommendations and providing the details; always good to have additional options
PACarGuy686.50 |
