      09-17-2011, 03:51 PM   #1
Dackelone
European Editor
Dackelone's Avatar
Germany
10616
Drives: N54 e82
Exclamation 135i air filter replacement DIY...
I just wanted to change out my air filter after 35K miles on my 135i N54. It was really a piece of cake. You just unclip the five spring clips around the air filter box with a flat blade screw driver, pull the lid up and out - and replace the paper filter element. There were a lot of small stones and sand inside my air filter housing. Just think if I had some K&N gauze type air filter that was more pourous and let the sand and rocks into the engine! wow. I used a small shop vac to clean up my filter housing. Then I installed a new filter. I used an OEM Mahle filter - I believe they make the filters for BMW AG. Same quality as BMW's filters for a 1/3 of the cost.
sand, dirt, small rocks were just some of the things I found inside my filter box...
would you look at all the junk that gets push up to the air filter!!
Name:  IMG_9104 - Copy.jpg
      09-17-2011, 08:11 PM   #2
sonicbimmer19
72
Drives: E88 and F32
Air filter change is like 2 times easier on 135i than 128i.
      09-17-2011, 08:50 PM   #3
wolfe
wolfe's Avatar
135
Drives: e82 / e70 / r56 / r60
Seriously, this is a much nicer setup.
      09-17-2011, 10:08 PM   #4
jkoral
1025
Drives: 2017 M2 LBB 6MT
Are they really that expensive in Germany?
FWIW, in the US, I see the Mahle LX 1564 for ~$37, but the BMW OE one (13-71-7-556-961) for ~$24.
Cheap enough that I'll probably throw a new OE one in every 10-15K.
      09-17-2011, 10:28 PM   #5
BMW86
Australia
398
Drives: RS3 Sedan / Macan S
Great write up Dackel.
I recommend taking the filter out every 5-10k and tapping any dirt loose and vacuuming out the airbox at the same time. Clean filter is more efficient.
Also be careful when unclipping the clips form the lid that they don't come off the box and fall into the engine bay. It happened to me once and it was a pain to find it.
      09-17-2011, 11:02 PM   #6
delta-9-ginseng
OG Tray Deee
delta-9-ginseng's Avatar
82
Drives: BMW 135i & F36 435i
So placing a K&N air filter instead of the OEM BMW one would result in a possibility of inducing engine damage via sand and stones getting in? I thought the K&N air filters increase air flow ever so slightly...
      09-17-2011, 11:41 PM   #7
Dackelone
European Editor
Dackelone's Avatar
Germany
10616
Drives: N54 e82
Any K&N tyoe filter uses gauze for the filtering element. You have to oil them so the oil wicks up any dust or debrie. IF the filter isn't oil'd then you run teh risk of less filtration. Why do you think these tyoes of filters flow more air? because they are more pourous - ie bogger holes in the filtering element.
      09-17-2011, 11:48 PM   #8
Dackelone
European Editor
Dackelone's Avatar
Germany
10616
Drives: N54 e82
I paid 15 euros for my Mahle air filter here. I think the dealer wanted 36 euros for the BMW one. Since mahle makes the filters for BMW... that was a no brainer. Its the same story with other filters like oil and fuel filters. The BMW ones just cost more.
For now I am using BMW oil filters - bc teh difference its only three euros. But later I will switch to Mahle ones too.
Here is a comparison of oil filters... The middle one was an early Mahle design, now they only produce the right one - looks just like the BMW oil filter.
      10-15-2011, 10:08 PM   #9
TimMc
TimMc's Avatar
Australia
44
Drives: E90 M3
Yeah, I do this nearly every-time I open the bonnet. So easy to do.
      09-18-2014, 03:17 AM   #10
DrGadget
DrGadget's Avatar
Australia
46
Drives: M140i F20 LCI-2
2018 BMW M140i  [0.00]
K&N
Dackel: Are you saying that K&N filters allow crud into the turbos? OK, I don't have spark plugs (piezo) which led me to this forum, but I do run a K&N filter in the standard housing. Your comments have worried me no end.
I find the 123d is a different car with the K&N installed. Much nicer to drive.
Current: Alpine White M140i F20 LCI-2, 250kW/335hp, 2018.
Sold: Melbourne Red 340i F30 LCI Luxury Line MMPK - 265kW/355hp, 2016.
Sold: Alpine White 123d e82, 2010, 150kW/204hp.
      09-18-2014, 03:27 AM   #11
Dackelone
European Editor
Dackelone's Avatar
Germany
10616
Drives: N54 e82
Yes. I do not believe that an oiled air filter is the way to go. Others may have a different view point though. When I saw all that sand and small stones up inside my air box... if the OE paper element wasn't there, I am sure some of it would get past a K&N type filter. I'm sticking with my OE filter.
      09-18-2014, 06:01 AM   #12
DrGadget
DrGadget's Avatar
Australia
46
With the Mann air filter all I ever saw on the INWARD side was dust and bug remains. But the filter is there to stop that going further and so when the filter gets a bit old it drops into the box on the INWARD side from the suction hood.
That is a far cry from saying that any filter (OEM or K&N) allows it through to the turbos. I respect what you are saying greatly, but I'd need evidence to be convinced. It's somewhat like the diesel timing chain failures ... Lots of talk but no evidence as to whether it is crap oil; stop-start; manuals vs SSG and so on.
You're still No. 1 advisor in my eyes ... But evidence is what we all need.
Dackelone10615.50
      09-19-2014, 04:31 AM   #13
DrGadget
DrGadget's Avatar
Australia
46
@Dackelone This research would tend to support your comments:http://www.nicoclub.com/archives/kn-vs-oem-filter.html except for the fact that is biased and paid for by AC Delco.
By the way, K&N filters do not use gauze. They use a pleated multi-layered oil impregnated surgical cotton fabric. A K&N facts sheet is shown here.
The Latin for what I am reading is 'argumentum ad populum', which translates as just because a lot of people say the same thing, it doesn't make it true.
Cheers
      09-20-2014, 11:59 AM   #14
lastMleft
lastMleft's Avatar
30
Drives: e92 M3
AFE has a drop in pro dry s filter.
      11-10-2022, 10:08 AM   #15
jkirk454
Drives: 2012 BMW 135i
I'm about to do this today. I assumed it would be easy enough, but this is a great write up to avoid any suprises. Thanks!
1addicts
