11-06-2022, 08:41 PM | #1 |
Rep 4
Timing Corrections
Hey everyone, i'm new to the BMW world as i just transition from a Q50 VR30 car, so im very big on how my car is running.
I was logging with MHD on Stage 2 93 and i was getting around -8 degrees of timing corrections on nearly all cylinders when I was logging, And that seems very off to me. I took 2 logs, one only pulled around -2 to -4 degrees of timing and the other one was around -8. Could anyone give me some advice? https://datazap.me/u/bestofj/log-166...og=0&data=3-18 https://datazap.me/u/bestofj/stage-2...og=0&data=3-18 |
11-07-2022, 02:02 AM | #2 |
1890
Rep 3,877
Advice #1: There is a dedicated Log review thread.... --> https://f30.bimmerpost.com/forums/sh....php?t=1648722
Advice #2: You are making bad timing. Likely cause: Your fuel quality (octane) is insufficient for the selected map (common issue). Increase fuel octane or go to a less demanding map (e.g. Stage 2 91). Do not drive like that - you are eating up the engine' safety net and possibly making less power than on Stage 2 91. Advice #3: Enable logging of "Timing delta for knock adaptation" in your future logs. Advice #4: Use the thread ref. Advice #1 in the future Welcome to the forum and BMW!!
"Large increases in cost with questionable increases in performance can be tolerated only in cars and women."
11-07-2022, 04:25 AM | #3 | |
DisplacementReplacement
409
Rep 1,102
#5) start log at a lower rpm say 2800-3000 add to #2) on these cars when we/i see corrections or poor timing across all cylinders the number one culprit is fuel quality and these cars seem to love ethanol. gen 1's have relatively high static compression so octane and ethanol if available play a huge role in what you can do... i'm using boostane and 2-3 gallons of ethanol and have achieved nice timing logs on stage 2+ 95oct maps... my car does better on this map then the E40 map, not sure why... corrections on one or two cylinders are normal for any car, repeated could mean plug/coil/injector/or a problem... good luck...
2020 X3M /// MHD Tune
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 Last edited by Jnat; 11-07-2022 at 04:56 PM.. |
Skyhigh1889.50 |
11-08-2022, 04:03 PM | #4 |
810
Rep 1,454
Enable timing correction parameters in your log. Use the log review thread. Try the stage 2 91 map and re-log.
2022 CT4-V Blackwing 6-speed
SOLD: 2016 340i xDrive 6-speed DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2 |
11-09-2022, 01:11 AM | #5 |
2JZ-GTE
3045
Rep 3,996
A few things can cause timing corrections.
– Bad plugs. – bad fuel, consider e30 – high intake, temperatures. – any combination of a above |
11-09-2022, 06:22 AM | #6 | |
23
Rep 12
I was reading -3 to-7 across the board with stg2 93 using costco pump gas. It cleared with around 2-3 gallons of e85 per tank. I switched to stg2 91 and it is much better with -1 and occasional -3 on some cylinders but it clears after 5kish rpm (straight 93 pump gas). It was pulling so much timing on stg2_93 that it felt slower than stg2_91 |
11-09-2022, 07:53 AM | #7 |
BimmerPost Supporting Vendor
24199
Rep 190,807
+1 try the 91 map OP
11-09-2022, 08:41 AM | #8 | |
53
Rep 106
11-09-2022, 08:58 AM | #9 | |
254
Rep 558
I, almost exclusively, use Costco 93 oct. and Shell 93 when not near a Costco. I run the stg2/93 OTS map. I haven't logged because I thought that would be fine. I guess that was an incorrect assumption. Lesson learned. I guess I should log and post here. Then, if corrections are too high, use the stg2/91 or add 2 gallons of e85 if I want to use the 93 oct. map.
My 2017 M240i: MHD, xHP, Modded OE Intake, AA GESi 400 CPSI Cat DP, Dinan Mid-pipe, M Performance LSD & Rear Diffuser, BMS Exhaust Tips, Apex EC-7 Wheels, M-Tech Front Lip, iND Painted Mirror Caps, Smoked Reflectors
11-09-2022, 09:35 AM | #10 |
53
Rep 106
I haven’t had my MHD tune long, but I haven’t logged either. Since I live in the Midwest we have pretty good gas to begin with, plus I add 2 gallons of E85 too just because its readily available and cheap. I assume that theoretical 94.5 octane should be more than sufficient for a 93 tune. If they sell it as a 93 tune and everyone has bad timing corrections, that’s on MHD or BM3, right? You shouldn’t offer a tune based on theoretical perfect fuel coming from every pump around the world, right? Do they have no factor of safety in these tunes?
11-09-2022, 12:10 PM | #11 |
48
Rep 190
Weird problem here, I just installed multi map with flex fuel sensor on BM3 stage 1 map
So the tune is adjusting itself by reading ethanol content from sensor. Since this setup I’m experiencing lot of timing correction, especially in the lower rpm. Up to -6 (across all cylinders) Was running perfectly on regular stage 1 93 on pump RON 98… Considering I can’t add more ethanol to clear correction on FF enabled multi map, I’m stuck… Any advice welcome |
11-09-2022, 08:32 PM | #12 | |
Rep 4
I was able to log some more, it turns out it was the fuel quality, My timing corrections went from -8 to around max of -3 this is with 1.5 gallons of E85 as well, it seems that 1 log only cyl 1 had timing corrections, but another log Cyl 1 AND 5 were having up to -3 degrees of timing corrections https://datazap.me/u/bestofj/15-gall...29-30-31-32-33 https://datazap.me/u/bestofj/stage-2...og=0&data=3-18 Both logs are taken with Shell 93 and 1.5 gallons of E85 in the tank |
11-10-2022, 06:10 AM | #13 | ||
23
Rep 12
If it come to the corrections then 93 with a splash of corn juice produced the cleanest logs. Quote:
PeterWT253.50 |
11-10-2022, 03:48 PM | #14 | |
810
Rep 1,454
And for everyone adding E85 to their pump gas tunes, just run the E30 maps. Less timing corrections, cooler combustion temps, and more power/torque.
PeterWT253.50 |
11-10-2022, 03:58 PM | #15 | |
48
Rep 190
I have this problem actually, and I’m stuck… No response yet from BM3. |
11-11-2022, 01:23 PM | #16 | |
43
Rep 82
The premium gas I am running is 91 octane, the E sensors don't read octane just E content. Maybe their E maps are set with 93 octane gas as the mixer with whatever E you are running. That could be why I and others get timing pull on the correct map and E content. I think their maps are a little aggressive but I am not sure how much timing pull or rail pressure drop is acceptable. If you log a stock map, I have seen 3-4 degrees of pull in hot weather. We might all be ok I guess, fingers crossed |
11-11-2022, 01:38 PM | #17 | |
810
Rep 1,454
