03-26-2021, 05:41 PM | #48 |
373
Rep 464
Have you tried ECSTuning? Shipping costs to Canada may be expensive though...
https://www.ecstuning.com/b-genuine-...e/34112450161/
2020 Black Sapphire M340iX
2014 Estoril Blue 435iX - sold |
04-07-2021, 07:20 PM | #49 | |
33
Rep 38
I went from base brakes to M Performance red and it's night and day stopping power and pedal feel. It looks sexy af too how it fulls the entire 19" wheel with the big calipers |
Two3Series85833.00 |
04-08-2021, 12:54 PM | #50 |
346
Rep 429
Did you have to change out the brake booster and master cylinder?
2020 MG 330i xDrive M Sport
2023 AR M3 Competition M xDrive |
04-11-2021, 07:52 AM | #52 |
1154
Rep 624
04-19-2021, 03:03 PM | #53 | |
33
Rep 38
Yeah pretty bad pedal feel There are 2 versions of the M Performance Red Big Brake Kit. The ones that need the new Booster/Master assembly are Euro Spec G20s Everything is explained clearly in this post: https://g20.bimmerpost.com/forums/sh...7&postcount=42 |
05-03-2021, 08:59 PM | #54 |
Rep 33
Sorry to go off topic here but I've got a burning question. I just ordered my 2021 m340i but opted for the stock blue calipers. Are the red M sport any different than the blues? I assumed not b/c it was a 0$ to "upgrade" to the red.... Did I just screw it up big time? TIA
11-09-2022, 08:25 PM | #56 | |
Rep 3
Just to clarify on few things: 1. M Sport calipers come in both RED and BLUE, hence the upgrade for $0 2. M Performance calipers are WAY BIGGER and also the rotors and pads are MUCH different 3. M Performance calipers according to Brembo are their high performance calipers, you WILL feel and GET that difference at high speed driving under harsh conditions, if just street regular driving under 140km/h, M Sport should be enough 4. 320i owners, you need to upgrade the brake booster in order to truly appreciate both the M Sport or M Performance calipers, you can still change from the stock silver brakes to M sport and get that 10~20% difference To conclude on the M Performance brake kit: 1. MUCH BETTER stopping power 2. with MUCH BETTER stopping power, you don't have to worry about the brake kit feeling TOO aggressive, it FEELS aggressive when you get aggressive with the pedal 3. rest assured, on daily driving street basis, feels very linear and also the nodding is gone! (remember to get coded along with the M Performance brake kit) |
11-22-2022, 02:47 AM | #57 |
1154
Rep 624
It’s still worth reminding that if you have a M340i with either the M Technology Package or Track Handling Package, you will already have 374mm front rotors and in that case - the M Performance brake kit will literally change your brake calipers and replace them with identical ones. The only difference would be that the M Perf kit comes with dimpled and slotted rotors.
The M Performance kit is only an upgrade on cars with the 348mm M Sport brakes, or on cars with the stock brakes. The best upgrade for G20 remains fitting G30 spec 395mm 4 pot calipers and rotors. You can even fit the X3 ///M specific drilled discs with the 395mm calipers for an even bigger upgrade. |
Chubbiejones892.50 |
11-22-2022, 01:35 PM | #58 | |
893
Rep 1,515
Additionally, the 6 pot calipers from a G80 M3 or F90 M5 are the same as the G05 X5M competition. All that is required is to purchase the adapter bracket. I will conducting this upgrade in the near future; once complete I will draft a full install thread |
1WickedE90199.00 |
11-22-2022, 01:43 PM | #59 | |
1154
Rep 624
The adapter bracket from the F95 brakes is not sold separately sadly - so I’m assuming you mean an aftermarket bracket for the F90 / G80 calipers? I’ll look out for your progress pics! |
11-22-2022, 01:48 PM | #60 | ||
893
Rep 1,515
https://www.ebay.com/itm/29490122856...#38;media=COPY I was able to purchase a set of gently used calipers from a M5 for an extremely low price. I have read quite a few of your posts on other threads; appreciate all the information you have provided! |
11-25-2022, 07:56 AM | #61 | |
149
Rep 237
2024 G87 Zandvoort Blue M2 w/ Buckets - Stock 93| 0-60 TBD | 1/4 TBD | 60-130 TBD
2020 G20 Tanzanite Blue II M340 xDrive - E30 BM3| 0-60 3.28 | 1/4 11.39@123 | 60-130 9.56 Past: 2017 W205 Black C43 AMG - E40 FBO No Turbo | 0-60 3.21 | 1/4 11.18@124 | 60-130 9.17 |
11-25-2022, 10:55 AM | #62 | ||
893
Rep 1,515
blau3er do you have any insight as to the requirements for the rear? |
12-28-2022, 08:59 AM | #63 |
Professor
2328
Rep 1,861
Drives: '23 M2 & '22 X3 M Competition
Looking to add the M Performance brake kit to my 330e. Through getbmwparts it's $2,800 shipped to me (shipping, tax, etc.) which ends up about $500 cheaper than ordering from my local dealer. Has anyone had these installed by the dealer & what was the cost? The installation sheet says 3.0 hours for dealer installation & then coding.
01-03-2023, 03:36 PM | #64 | |
1154
Rep 624
Yes - the X3M fits onto the rear of the G20 without issue. I have a photo showing them working perfectly. You need X3M rear calipers (complete units) and X3M discs. You need to trim and modify the electronic parking brake plug (on the caliper side) to work with the G20 parking brake plug. Hope this helps! |
01-04-2023, 12:11 PM | #65 | |
893
Rep 1,515
01-13-2023, 10:34 AM | #66 |
Rep 3
Hi Guys,
I know the F97 X3M brake upgrade for the M340i is "plug & play", but what is the minimum wheel size required? I am running standard 19s, and I know the X3M runs 21s. Do 19s provide sufficient clearance for the X3M discs/calipers? Thanks Andy |
