03-19-2024, 04:22 PM | #331 |
2309
Rep 5,755
Are they off cambered? There’s little you can do to improve grip/feel thru an off cambered corner. South Bend at VIR is that way plus it’s a blind downhill left hander so you hope your on the correct line and won’t runout of track on corner exit!
03-19-2024, 05:00 PM | #332 |
420
Rep 519
T9 on Thunderhill east is cambered such that you get extra grip and you can really make an aggressive turn in. But occasionally even with the extra track camber the front will just let go a bit mid corner.
03-25-2024, 10:46 PM | #333 |
420
Rep 519
I have 72mm Bimmerworld studs, and they seem to be too short with the 15mm spacer when using the TA5R Flow Form Wheel, 18x10.5 ET36 wheel. Do people use 82 or 92 studs?
03-25-2024, 11:43 PM | #334 | |
154
Rep 135
IG - shaddyy
03-26-2024, 12:10 AM | #335 |
7605
Rep 3,605
I use BW 92mm studs and a 25mm spacer
Current: F80
Prior: F82, F32 |
SYT_Shadow11500.00 drroc420.00 |
03-26-2024, 10:26 AM | #336 | |
420
Rep 519
03-26-2024, 09:25 PM | #337 | |
154
Rep 135
But a stud extractor is always good to have on hand depending on the type of break it was.
IG - shaddyy
03-27-2024, 12:16 AM | #338 | |
420
Rep 519
03-31-2024, 01:41 PM | #340 |
420
Rep 519
I found that 73mm bimmerworld stud is a bit too short when using the bimmerworld 15mm spacer. 82mm studs work quite well though. I also took a picture that shows three weels with NT01 on them. Apex EC7 275 NT01 on a 9.5 inch wheel, TA5R with 275 NT01, and the Apex EC7 11 inch wheel with a 305 NT01. It's interesting to see how much extra width the TA5R has over the 9.5 Apex.
04-05-2024, 01:32 PM | #341 |
52
Rep 46
18x11 GT4 wheels, 295/35 re71rs squared
04-06-2024, 08:49 PM | #342 |
52
Rep 46
Needed to trim the fender due to rubbing. Bought some abs plastic from home depot. Trimmed the fender, and inserted abs plastic. Did a quick test drive and rubbing seems to be gone. Real test will be track day next week.
04-06-2024, 09:36 PM | #343 |
///M Powered for Life
11500
Rep 10,333
You can also use a heat gun to push the fender out of the way
04-07-2024, 10:55 AM | #344 |
416
Rep 545
D_SheerDrivingPleasure1097.00 drroc420.00 |
04-15-2024, 02:28 PM | #345 |
420
Rep 519
So I had a chance to run 275 NT01 square setup at Laguna yesterday on 10.5 TA5R wheels. I would say that braking and turn in is better compared to running 275 on a 9.5 wheel. The rear felt less planted compared to a 305 NT01 on an 11inch wide rim. I saw a lot of people with F8x cars running 295 square setups. Yokohama ADVAN 295/35R/18 might be an interesting option to get a bit more meat in the rear while maintaining the benefit of the square setup.
SYT_Shadow11500.00 |
04-15-2024, 04:29 PM | #346 | |
11500
Rep 10,333
drroc420.00 |
