02-19-2020, 02:45 PM | #1 |
Extruding Elements
514
Rep 539
Drives: 2016 BMW M5 Comp
MirrorTap and V1
Hardwired my V1 with the mirrortap wire harness....isnt the V1 supposed to turn off after x amount of time? Maybe I tapped into different power than whats needed to turn off...?
02-19-2020, 07:22 PM | #2 |
252
Rep 631
Drives: 2014 M6 Grand Coupe CP
V1 turns off as soon as power is cut. Does it turn off after the car goes to sleep? My camera is tapped in to a "wake state" supply so it comes on as soon as I touch the door handle as does the V1.
F06 M6 Grand Coupe CP
Sapphire Black Metallic The drive is the destination |
02-20-2020, 07:21 AM | #3 |
Extruding Elements
514
Rep 539
Stays on until I turn the V1 off manually. Need to open it back up and see where I tapped into...as apparently it was the wrong power source. Does the attached look proper? Not mine, an image I just found online.
02-20-2020, 12:27 PM | #4 |
252
Rep 631
The color coding you are using is correct. The 12V supply (Green /Brown) is switched on and off by the car access system. As soon as you unlock the door it switches on and it stays active for a while after you lock it. Have a look at this: https://www.newtis.info/tisv2/a/en/f06-650i-cou/s4MNsTV
Connector A60*1B pin 3 for 12V and pin 10 for ground.
Sapphire Black Metallic The drive is the destination Last edited by arucano; 02-20-2020 at 12:34 PM.. |
Fast.F10513.50 |
02-29-2020, 08:35 AM | #6 |
Extruding Elements
514
Rep 539
So getting tired of turning on/off so back at this. The above images do not looks as mine is on my 2016 CP F10 M5. Here is this link that I should be referencing...but cant seem to locate a similar diagram: https://www.newtis.info/tisv2/a/en/f10-m5-lim/
Here is what I am looking at: |
02-29-2020, 08:59 AM | #7 |
Extruding Elements
514
Rep 539
I think I have figured it out...https://www.newtis.info/tisv2/a/en/f...f22/1VnXvXgTJk
Now to figure out to pull that front trim off. |
02-29-2020, 09:24 AM | #8 |
Extruding Elements
514
Rep 539
BINGO! You do not tap into the connectors on the top trim panel...rather the connector on the "arm" for the mirror.
/closed |
02-29-2020, 09:45 AM | #9 |
252
Rep 631
I have the same hookup as detector cudakid30. With Pins 3(+)and 6(-) the detector works with the ignition status. With the pin 3 and pin 10 connection, the detector will have to be switched on and off manually. (my pictures do not match the clarity of the others above)
02-29-2020, 11:06 AM | #10 | |
Extruding Elements
514
Rep 539
02-29-2020, 04:03 PM | #11 |
Extruding Elements
514
Rep 539
...and now Passenger Restraint System Malfunction LOL.
02-29-2020, 04:24 PM | #12 |
Extruding Elements
514
Rep 539
...seems to be a common occurrence due to the roof panel: disconnecting and then powering on the car with leaving those noted above 5 plugs disconnected...to test rear view mirror tap test. Will stop off at dealership on Monday to have them clear unless there is a DIY.
05-03-2020, 10:19 AM | #13 |
832
Rep 1,254
Thanks for blazing the trail on this @Fast.F10. I just bought a uniden R7 and Blendmount w/ the mirror tap setup. going to be installing it today/tomorrow I think.
2009 E92 M3 build thread: https://www.m3post.com/forums/showthread.php?t=1754875
Follow me on IG - www.instagram.com/the_driven_enthusiast |
05-25-2020, 03:19 PM | #14 |
832
Rep 1,254
Following up on this post - I installed my Uniden R7 and blend mount today using the mirror top. Although I couldn't get that darn plug out and had to just wing it by pressing the wire taps by hand, it was a pretty easy job thanks to this thread and everyone's input. Thanks guys!
