Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > 330i wont start?
      08-11-2014, 05:31 PM   #1
TheTal0n
TheTal0n's Avatar
51
Drives: 2006 330i
330i wont start?
So yesterday I disconnected the battery to put a new relay in, I reconnected the battery and all was fine. I drove to get groceries and back with no problems. then today I went to drive to work and It just wouldnt turn over..? The battery is a year old from BMW. All the lights work. I am stuck, it wants to turn over but wont. I wasnt able to pull any codes either when I scanned it with the BAV tool.
any ideas?
      08-12-2014, 02:31 PM   #2
BOOSTLEE
BOOSTLEE's Avatar
34
Drives: E92 335i, Ducati 996
any ideas?
check the IBS sensor (page 8), you may have screwed it up when replacing the battery, this thing is very sensitive
File Type: pdf BMW e90 Voltage Supply & Bus Systems.pdf (1.34 MB, 381 views)
      08-12-2014, 02:35 PM   #3
kisho
Quiet till poked
99
Drives: E90 325xi
2006 325xi  [9.50]
This was the problem with mine. I went as far as buying a new battery to find out that all I needed to do was pull the IBS plug out.
      08-12-2014, 02:39 PM   #4
mad1337nes
Drives: 07 335
seconded on the IBS. Make sure you plugged all the blue things back into the correct places
      08-12-2014, 03:28 PM   #5
colin_e90
57
Drives: 2016 M235i
Ibs or starter
      08-12-2014, 03:43 PM   #6
d1saster
Bulgaria
60
Drives: F15 N55 & E93 N51
If the IBS is not plugged or bad the car shouldn't have any power or I'm wrong? OP stated the lights work, can crank, just can't start. OP can you turn instruments on, go to hidden menu and see what voltage the car is reading?
      08-12-2014, 03:55 PM   #7
BOOSTLEE
BOOSTLEE's Avatar
34
everything will be on lights, accessories, ect. ect.
car just won't start when you push the button; mine is unplugged, if I plugged it back in, my car won't start either
      08-12-2014, 05:03 PM   #8
3s4u2
Beamer Mantic
3s4u2's Avatar
82
Drives: 2006 325i Prem
Might be your starter, they don't always give you warnings!!!
2006 325i
2006 M5
2008 X5 4.8i
2014 X5 50i M-Pkg
      08-13-2014, 07:58 PM   #9
TheTal0n
TheTal0n's Avatar
51
Drives: 2006 330i
No idea what it was i went back into the DME box to see if i messed anything up and when i put it back together it started, haha..weird.
      08-13-2014, 08:10 PM   #10
GreaseJunkie
17
Drives: 2006 E90 330i Black Sapphire
What's your mileage? My 330i's starter went at 84k. It started with an occasional no start once or twice a month. Then it started doing it every morning. But the part was only about 160, and it was a whole lot easier than I imagined it was gonna be
      08-13-2014, 08:44 PM   #11
3s4u2
Beamer Mantic
3s4u2's Avatar
82
That is some excellent news, still could be your starter!
2006 325i
2006 M5
2008 X5 4.8i
2014 X5 50i M-Pkg
      08-13-2014, 10:31 PM   #12
TheTal0n
TheTal0n's Avatar
51
Drives: 2006 330i
Yeah I scanned it and I cant pull any codes! Im going to scan again tomorrow.
      08-13-2014, 10:32 PM   #13
TheTal0n
TheTal0n's Avatar
51
Drives: 2006 330i
I am at 81K I heard the job isnt that easy so Im not sure if I can pull of a such a task.
      08-14-2014, 01:25 AM   #14
pruettfan
1622
Drives: 2017 M2, LBB, DCT, Exec
My starter lasted 197,000 miles (mostly highway so not a lot of starts I guess). Mine was a bit of a pain in the ass to change because I ended up having to change the entire oil breather system that had succumbed to the heat over those miles and became brittle. I ended up having to essentially redo the job because I forgot to plug in the tank vent valve sensor. It was much easier the second time. Hopefully there will not be a third.
      08-14-2014, 02:28 AM   #15
AceOnShake
AceOnShake's Avatar
39
Drives: E90
It was probably a loose connection to the terminals. Happened to my E30 and couldn't figure it out ended up jump starting it thinking it was the damn starter. I would get power and then dead. I went checked the batter and looked good but then moved it and lights turned back on. I unscrewed everything and was some corrosion so took a screwdriver and just filed away. Never an issue again.
Starter is PAIN! I would never take that on myself.
      08-18-2014, 08:14 PM   #16
TheTal0n
TheTal0n's Avatar
51
Drives: 2006 330i
Wow, how many miles do you have now?
I think it might be, the cords above the Engine cover clippedinto the cabin air filter?
