04-11-2010, 10:31 AM | #1 |
Moderating
418
Rep 2,047
Supercharging Discussion: Boost Pressure vs. Altitude
Nice numbers LV!!
Different cars can be just stronger from factory. We hve seen as much as 40 HP differences. Roman gave me a 95mm pulley for my kit due to my mountain goat altitude of 5000ft! I'm running DCT to so hopefully it will get me close to 5,5psi |
04-11-2010, 12:47 PM | #2 |
Moderator
273
Rep 4,481
A centrifugal type supercharger does not provide absolute boost like a turbocharger, it provides relative boost due to the fact that the speed of the compressor is directly related to the engines rpm. So at 5000 feet your stock car has -2.5 psi "boost pressure" compared to sea level ( 0 psi ). To get out 5.5 psi @ 5000 feet your SC kit needs to make 8 psi boost at sea level. How do you manage those 8 psi once you really leave your altitude ?
04-11-2010, 12:57 PM | #3 | |
Moderating
418
Rep 2,047
I will not go to sea level, I live in the moutains. If I decide to, I will put a bigger 100mm pulley on. Based on what you are saying, I would need a 7psi pulley? Roman I would love a comment... |
04-11-2010, 01:09 PM | #4 | |
391
Rep 3,149
04-11-2010, 03:39 PM | #5 | |
113
Rep 750
The difference being that the air is less dense up here. 17% less dense. So you are increasing the power from a much lower base. And the extra air you are spinning in is also deprived of oxygen compared to sea-level due to the air being thinner and less oxygen rich. So I think Roman will run a smaller pulley due to the engine being nowhere near the limit of power one gets to at sea-level. You are starting with a 50hp deficit so one can run more boost safely up at altitude. |
04-11-2010, 03:51 PM | #6 |
20
Rep 508
your comments are always funny when are you gonna get yours?
04-12-2010, 08:34 AM | #7 |
Moderating
418
Rep 2,047
Being fitted as we speak
Roman should have my ECU in his hands at exactly 10h30 this morning, FedEx says its delivering then. Two days back to me, so Thursday or Friday I can be reporting on far back my scrotum stretches on take off, lol I will report on the altitude, and what size pulley eventually gets me to 5,5PSI. btw what is your altitude at your location, and have you dynoed your car there, and what was the registered boost? |
04-12-2010, 08:47 AM | #8 | |
Moderating
418
Rep 2,047
engine RPM is directly related to blower RPM as its belt driven. At sea level the air is denser and therefore the blower spinning at a particular RPM produces X amount of boost pressure. At higher altitude, the air is less dense, and therefore the blower spinning at the same rpm as it was at sea level, now produces less boost pressure. To compensate for the loss boost pressure, one must run a smaller pulley on the blower, thereby spinning the blower at a higher RPM, to achieve the same boost as it was previously making at sea level. |
04-12-2010, 01:36 PM | #9 | ||
113
Rep 750
But you are also compressing air that is less dense. As air gets thinner the molecules are further apart. So there is less oxygen per square inch at 5000ft than there is at oxygen rich sea-level. Ever wonder why climbers use oxygen masks at the top of Mount Everest? Each breath you take, you ingest the same amount of air you ingest at sea-level. But the air is pretty much useless as the 02 molecules are so sparse it doesn't feed you. Quote:
P2 = P1 (D2/D1) So a 5.5psi charger at 5000ft will produce = 5.5psi(850mbar/1000mbar) = 4.675psi or 15% less boost. So you would need a 15% smaller pulley to make the same boost. But even if you get the same boost, the quality of air is not the same. So actually you will need an EVEN smaller pulley to compensate quantity for quality. But hey, that's just my opinion. It's a great discussion with lots of grey areas si I am open for correction. |
04-12-2010, 01:52 PM | #10 |
My other car is a Scooter'ia
85
Rep 1,303
FINALLY!!! Some discussion and attention on those of us at 5000ft!!
I LOVE IT! Keep it coming. I'd love some definitive conclusion on this before I flip the switch to supercharge.
A91 Edition Supra | Armytrix | Rays M3 Saloon | Akrapovic EVO | B&G Sport M3 Saloon | VF540 | Klässen ID M52-R | Akrapovic | Vorsteiner GTS5 | KarbonWerke CSL [SOLD] |
04-12-2010, 02:22 PM | #11 | |
126
Rep 4,144
Without going too much into physics, it's the amount of the O2 that's in the cylinder that decides how much fuel the engine can take since we need to control mixture (A/F ratio). More fuel, more power. Since the volume inside the engine's cylinders is constant (at TDC) the amount of oxygen in the cylinder is then proportional to the density. The density depends on the pressure (altitude) and temperature. Higher temperature or higher altitude means less oxygen in a normally aspirated engine. There's less pressure up there but also less temperature. Pressure of the air is not determining quantity; it is density that is the key factor. This, of course, excludes talk of detrimental effects of too high a pressure or too hot the air. For example, the density of air (standard atmosphere) at sea level is 1.225 kg/m^3. The density at 5000 feet is 1.056 kg/m^3, i.e. you've lost about 14% of the O2 (normally aspirated). Pressure-wise, it's 14.696 psi (1.013 bar) at sea level and 12.228 (0.843 bar) at 5000 feet, or about 17% loss of pressure, but not O2. And that is a loss of 0.17 bar. With forced induction (super charger or turbo charger) you are forcing more air into the cylinders, increasing the pressure, but hopefully not the temperature, so the density of air is higher and hence more oxygen gets into the cylinders so that you can burn more fuel per stroke. To make up for loss of density from 0 to 5000 feet you only need to produce 0.17 bar of boost, assuming temperature is constant. You'll notice a bit more power at sea level than at 5000 feet in an FI engine, but you'll need a dyno or accelerometer rather than your butt dyno to realize it. I hope I got the point across. Sorry for being long-winded. Cheers.
2017 F80 YMB.
04-12-2010, 02:54 PM | #12 |
Moderating
418
Rep 2,047
^^^ thanks for the technical explanation. I was going to quote pressure laws from scuba diving experience but I forgot the exact terminology and didn't want to sound like an uneducated mountain goat lol.
Reinforces my raised points re 02 being 20% of our air regardless of altitude. So bottom line is, spin the blower faster to produce boost equal to sea level. Only down side is noisier blower. On your above point re needing to produce 0,17 bar to counteract the loss in density at 5000ft, it therefore means that you would need to use a pulley that would produce 2,46psi higher than what you want to achieve at 5000 ft. So if you have a VT2 575 kit producing 5,5psi at sea level, you need a pully good for 8psi to achieve 5,5psi at 5000 Last edited by Bob MG; 04-12-2010 at 03:04 PM.. |
04-12-2010, 03:38 PM | #13 | |
113
Rep 750
Maybe you misunderstood me. In one cubic foot foot of air at sea-level. How much oxygen is there? Not what proportion of oxygen, what absolute amount of oxygen is there? So now. Go to 5000ft. I know the proportion is the same. What absolute amount of oxygen is there in one cubic foot of air? Is it the same as at sea-level? Ever wonder why an NA doesn't require as much octane at altitude as it does at sea-level? I think someone has done some dyno testing at altitude and proven it. On each stroke the air that is ingested into the cylinder has less oxygen than the equivalent sea-level car. Hence my point that yes you and Bob are right you need a smaller pulley to make the same boost. We are all in agreement with that. But that "quality" of the extra air is poorer, so you need to add even more boost to get the same oxygen content in. Make sense? Maybe I should have googled it instead of shooting from the hip with my personal experience of forced induction cars at altitude. I must say it's a great discussion as no-one really knows the real truth up here as most research is done at sea-level. So if we can learn, it will be for the benefit of all us mile-highers on this forum. |
04-12-2010, 03:44 PM | #14 |
113
Rep 750
I just realised that we are all saying the same thing. We all agree we need a smaller pulley? And we are all saying the oxygen content is less? I don't follow what we are disagreeing on then? Ersin, I think you are saying the oxygen content is determined by the density not the pressure? Well I think I'm saying the same thing.
04-12-2010, 04:04 PM | #15 | |
Moderating
418
Rep 2,047
Air is air, same composition at ALL altitudes. (20/80 Oxygen/Nitogen) The second you compress air to a certain pressure, provided temps are the same, then the amount of USABLE O2 is the same at both altitudes. Hence the denser the air, the higher partial pressure of O2 in it, and the more fuel you can burn. But its academic, your technical knowledge of pressure laws are not up to par, but your understanding of tuning is When you go scuba diving and breath compressed air at depth, the partial pressures of O2 and Nitrogen, increase by one atmosphere per 10 meters you go down. Nitrogen becomes toxic as you approach depths of greater than 40 meters, hence why commercial divers dive with air mixtures, that substitute Nitrogen and or reduce it. All relates to partial pressure. Last edited by Bob MG; 04-12-2010 at 04:15 PM.. |
04-12-2010, 04:05 PM | #16 | |
126
Rep 4,144
I don't really follow why you need to add even more boost over that of overcoming the pressure loss due to higher altitude. Cheers.
2017 F80 YMB.
04-12-2010, 04:09 PM | #17 | |
126
Rep 4,144
Yes, a smaller pulley will give you more boost, we all agree. I was just pointing out that some things that you said were confusing. Cheers.
2017 F80 YMB.
04-12-2010, 04:31 PM | #18 |
808E90
235
Rep 4,047
These last few post have been a good read ... I'm just glad I'm at sea level
LTMW FTL . Karbonwerks LCI Trunk . Vorsteiner Poly Front Lip . NA Motorsports LUX H8 . RECARO Pole Position Seats . BMW Performance Pedals . BMW Performance Performance Grills . BMW Painted Fender Grills . BBS 19x9.5 19x11 LMs . Michelin PS2 265/295 . H&R Sport Springs . Wheel Mate 45/55MM Stud Kit . BBS Red Lug Nuts . ESS VT1 Supercharger . Akrapovic GT4 Exhaust
04-12-2010, 04:32 PM | #19 |
113
Rep 750
Ok I feel ye'. The density vs pressure thing means we were saying the same thing in a roundabout way.
Bottom line, we need more O2. I think how much more is what we need to decide on. |
04-12-2010, 05:37 PM | #20 | ||
113
Rep 750
Sea-level 5.5 psi of compressed air has much more oxygen. Like Ersin so eloquently said (which is what I was trying to say), is that the density changes up here. So yeah 5.5 psi is 5.5 psi. But it's not as dense. You are compressing air which is less dense to 5.5 lbs of boost. Quote:
But what is the discussion about again? |
04-12-2010, 09:03 PM | #21 |
Moderator
273
Rep 4,481
We are all getting older but I can recall we discuss about supercharging at altitude .
Back to Bob's scuba-diving: If you fill a bottle @ sea level up to 220 bar you will get 220 bar of pressured air with 20% oxygen and 80% nitrogen. Filling the same bottle at 5000 feet you will get also 220 bar of pressured air with 20% oxygen and 80% nitrogen, you just have to apply a higher compressor pressure ( + 2.5 psi ) to achieve the 220 bar in the bottle. Turbocharging: The ECU calls for 5.5 psi. Thus spinning of the turbos is not directly related to the engine revs the turbos will provide absolute 5.5 psi at sea-level or absolute 5.5 psi at 5000 feet. In the latter the turbos will have to produce relative 8.0 psi due to less dense air. To be able to provide the same absolute boost pressure at different altitudes the wastegate is used. So 5.5 psi absolute boost pressure at sea-level and 5.5 psi absolute boost pressure at 5000 feet. Supercharging: The Supercharger is driven by the crankshaft and has no wastegate. So it provides always the same relative boost at a specific rpm. Using a 8.0 psi pulley will provide 8.0 psi absolute boost at sea-level or 5.5 psi absolute boost at 5000 feet. That's the difference compared to turbocharging when we look at boost only. BOV's / DV's: Blow off valves or diverter valves are used both on turbo- and supercharged systems. They don't control boost pressure, they just blow off the boost spike in the air intake manifold when you close the throttle ( 8 throttle bodies in case of the S65 ). The difference between BOV's and DV's is where they vent to. Anything missing ? Cheers, Eugen |
04-12-2010, 10:30 PM | #22 | |
Moderating
418
Rep 2,047
^^^Hi buddy, yes please comment on these two fundamentally flawed statements
