BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > DIY Guides/ Discussions
BPM
      02-08-2013, 05:37 PM   #23
Ausdino
Ausdino's Avatar
Drives: 2008 E92 M3
Great writeup. This will make installing the Remus exhaust a lot easier...
cheers
      03-19-2013, 05:41 PM   #24
PhoenixRising
Important text here
24
Drives: 2013 M3 Conv
Can't wait to use this to install the exhaust that's on the way!
2009 AM V8 Vantage Conv - Berwick Bronze, Quicksilver Exhaust
2013 M3 Conv - (RIP) thanks to uninsured a-hole
2004 Porsche 911 C4S Conv
      03-31-2013, 08:55 AM   #25
PhoenixRising
Important text here
24
This was such an easy upgrade thanks to this writeup. Not intimidating at all! I didn't end up removing any bottom covers past the large aluminum plate. The last 2 plate bolts were under a plastic cover but it was flexible enough to get my hand and a wrench in there. I was done in about 90 minutes.
Best part? No leftover bolts! Haha
The Active Autowerke exhaust sounds amazing and the BPMSport stage 2 tune took care of the CEL that was thrown about a week later.
Thanks for the DIY!
      05-11-2013, 04:34 PM   #26
Dominic_M
Dominic_M's Avatar
15
Drives: 08 ///M3 and 2014 535i
Great ... Just what I needed.
2008 E90 M3 SPARKLING GRAPHITE METALLIC
      06-10-2013, 12:38 PM   #27
Transfer
Transfer's Avatar
5260
Drives: Bronco Wildtrak, Tesla MYP
Need help. In pictures 14 and 15 showing the rear bracket, what size screw heads are on there? It's sort of a reverse Torx or something. I can't get it off and need more detail. I tried with a 12 point 5/16" and 8mm and it's crazy tight and started stripping. Anyone know EXACTLY what the bolt head is?
      06-10-2013, 01:17 PM   #28
PhoenixRising
Important text here
24
You're right, it's a reverse Torx. Your local auto parts store will have them. I think it was a 16? I can't be sure, but yeah don't try any other socket other than the correct Torx. You'll round it off.
      06-14-2013, 01:28 AM   #29
Transfer
Transfer's Avatar
5260
For reference, I've determined it's an E10 socket.
      08-17-2013, 05:55 AM   #30
pkimM3r
pkimM3r's Avatar
209
Drives: m3 saloon in granny mode.
Header back is a whole new story. I took off a system on an e92 with ease and then on my car an e90 the undertray wouldnt come off?!
      09-14-2013, 04:45 PM   #31
srtoad4
94
Drives: 2014 CP M5 / 2016 SRT Jeep
Does anyone know the part number for those red urethane hangers by the secondary cats (same ones that are up front)? Can't find a part number for the life of me.
14 Space Grey CP M5 / CCB / Exec / etc
BMS Stage 1 / Charcoal Delete / K&Ns / Catless OEM DP & Borla S-Type Catback
      09-16-2013, 01:42 PM   #32
N1tr0gen
N1tr0gen's Avatar
Drives: M3Vert
Thanks for this write up! Helped me a ton. I do have an E93 and I had to unscrew the big middle bolt and the 2 smaller ones closer to the wheels to give the reinforcement brace enough flexibility to slide the exhaust out, rest is easy!
      09-17-2013, 02:36 PM   #33
psk278
Drives: 08 M3 6MT
This tool will make your life easier when dealing with exhaust hangers:
http://www.amazon.com/Lisle-38350-Ex...st+hanger+tool
      09-18-2013, 05:39 PM   #34
srtoad4
94
oh wow, wish I would have known about that tool before!
For anyone interested, the part number for those red triangular hangers for the axle back portion of the exhaust is 18207544809. They were $25 a piece from my local BMW dealer. New one is on and exhaust is perfect now
      04-09-2014, 12:15 PM   #35
FormulaMMM
FormulaMMM's Avatar
3663
Drives: E90 M3
4 years later, still a useful DIY.
A few notes to add based upon my first DIY stock muffler removal yesterday –
Yes, you can fit a shallow ratchet + 18 mm socket to get these.
It’s useful to have a small flathead to lift/pry the clips off of the bolts once you remove those 18 mm nuts as well. Mine were pretty snug.
The rear hanger is indeed held up by E10 reverse torx bolts. Suggest getting that specific socket (cost me $2.99).
10” extender is perfect.
I didn’t go the jack route. Instead, put some padding up at the front of the muffler, grabbed it by the tips (that’s, tips), and jostled a bit. Front section dropped down onto padding and then I lowered the muffler down slowly with man power. When I removed all of the bolts, nuts, etc. it acted like it wasn’t going anywhere. The rear side hangers with the long bolts were holding it in place quite well, actually. So I think it’s optimistic to support it with the jack, remove everything, then simply lower the jack. Not saying going that route is wrong, or won’t work, but I would have found the jack to be more in the way than anything. Maybe others have removed everything and it dropped like a rock, in which case a jack would be nice.
56” race ramps worked well. A bit more clearance at the front end of the muffler would have been nice, but no real complaints. Didn’t impede.
Hit everything with Liquid Wrench the night before, and everything came off without issue.
Whole process took about 1 hour and I’m a mechanical idiot.
Car sans mufflers is absurdly loud, especially on cold start. My DCT is in a storage unit currently and I thought it was going to collapse.
M4 GTS, GT3, C63 S | E90 M3s, E39 M5
      04-18-2014, 03:32 PM   #36
r1762
r1762's Avatar
40
Drives: 2010 E90 M3
Thanks for the write up just did my exhaust last week!
      05-25-2014, 07:32 PM   #37
MTM
83
Drives: 2009 M3
So glad this DIY is here. I just finished the job and am quite happy with how easy it was. The only strange thing is I never encountered the E10 reverse torx bolt...
      06-15-2014, 11:01 PM   #38
sadiq
Drives: 2008 E90 M3, 2007 A-M Vantage
This DIY was a life saver. Just want to add one detail to the "It's easier to just remove all of the hangars from the car, rather than muscle the red poly bushings off of the catback while lying on your back" step. Removing those bushings is REALLY hard... unless you have WD40 (or the right tool, mentioned above). I tried for a good 30-40 minutes to get it off with leverage, bare hands, and several flat head screw drivers (like an idiot). A couple of sprays of WD40 and all the bushings pulled off with only moderate bare hand effort.
While the above posts also reference an E10 reverse torx socket, I never felt the need, as the standard (5/16", i think) socket hooked in with no problems.
      06-16-2014, 08:00 AM   #39
C-ARchitect
281
Drives: Miniature Ferrari
Just an FYI for anyone attempting this, 2010+ models used E10 reverse torx for the rear hangers. 2008-2009 use standard nut.
      06-16-2014, 08:51 PM   #40
FormulaMMM
FormulaMMM's Avatar
3663
Drives: E90 M3
E10 for me on both my '08 and '09.
      06-16-2014, 10:44 PM   #41
C-ARchitect
281
I stand corrected, perhaps E10 reverse torx has been an E90 thing from the start.
      06-17-2014, 07:06 AM   #42
FormulaMMM
FormulaMMM's Avatar
3663
Drives: E90 M3
No problem. If M engineers were a courteous crew, it would have been a standard nut, but they enjoy torturing DIY'ers.
      06-17-2014, 10:09 PM   #43
Petros
62
Drives: M3
I agree. This car seems to be specifically designed to be a serious PITA for anyone who tries to work on it themselves. I've owned and worked on several cars in the past, and this is the least fun to work on by a great margin.
      06-30-2014, 01:06 AM   #44
Musker18
Drives: 2008 e92
This helped me a bunch. Thank you!
m3post
