      04-04-2021, 09:17 AM   #23
Dieselboy
Dieselboy's Avatar
452
Drives: '09 135i
Ohlins Trackday Kit by 3DMsuspension arrived.
-Ohlins DFV Coilovers
-Solid mount bushings for the Subframe and 95A poly for Diff
-Swift Springs: 80/140 Nmm
-Vorshlag Racing Camber Plates
-AKG Spherical Bearing Shock Mount
2009 Widebody 135i ///Build Thread
Instagram: ///TheAxisGarage
If you ride like lightning, you're gonna crash like thunder.
Appreciate 2
tsk941522.00
wdb4736.50
      04-08-2021, 01:04 PM   #24
Dieselboy
Dieselboy's Avatar
452
Drives: '09 135i
Some final calculations prior to ordering wheels. I plan on using the Toyo R888R's with a 265/35 front and 315/30 rear. Using the specifications provided by Toyo I was able to calculate the overall tire width on 10.5" and 12" wide wheels.
Based on my calculations the front maximum tire width will be 11.1" and the rear will be 13.0". I made the tires in CAD and plugged them into my model. I also plugged in 2.8° front camber and 1.8° rear camber. This results in a 2mm clearance from the tire to the inner fender panel in the rear and a 9mm clearance in the front. More room in the front will allow me to run a 275 width if I feel I need to in the future. I am going with the 265 so I can get a small amount of stretch on the 10.1" tread width to preload the tire for better handling and feedback.
It will be interesting to see how accurate my calculations are when the wheels/tires come in.
Front: 265/35 Toyo R888R | R Disk 10.5" width 4mm offset | 2.8° Camber
Rear: 315/30 Toyo R888R | A Disk 12" width -2mm offset | 1.8° Camber
Another factor I considered was the overall tire diameter. The stock setup is 24.77" front and 24.75" rear, so approximately flat. The new setup will increase the height by 0.5-0.7" to 25.30" front and 25.44" rear.
In theory, I believe this will be the widest setup that offers the best handling possible for an e82.
This may seem overkill, but I haven't found any E82's using a clinched widebody for a track oriented car. They all seem to be stanced. Some guys are running 13" wide wheels, but with massive camber angles and tire stretch.
Appreciate 2
houtan707.00
wdb4736.50
      04-10-2021, 02:56 PM   #25
Dieselboy
Dieselboy's Avatar
452
Drives: '09 135i
Decided to start with the rear. Removing the old shocks turned out to be a chore when the top hex portion sheared off so I ground into the rod and used a wrench to hold it while I removed the top nut.
Subframe lowered, ready to put the solid bushes in. Doing the diff may be tricky as I'm trying not to have to remove the diff nut.
      04-10-2021, 03:19 PM   #26
Dieselboy
Dieselboy's Avatar
452
Drives: '09 135i
First bushing out.
      04-10-2021, 04:12 PM   #27
Dieselboy
Dieselboy's Avatar
452
Drives: '09 135i
4 hours to drop the subframe, get the old suspension and bushings out, minus the diff. Not bad. That's it for today, hopefully finish up tomorrow.
wdb4736.50
      04-11-2021, 05:27 PM   #28
Dieselboy
Dieselboy's Avatar
452
Drives: '09 135i
Solid subframe bushings in. That was not a fun job.. now onto the diff bushes.
      04-12-2021, 10:07 AM   #29
Dieselboy
Dieselboy's Avatar
452
Drives: '09 135i
Rear diff bushing is out. Not sure how I'm going to get the front ones out yet since there isn't much support for the cup tool I'm using.
      04-12-2021, 01:25 PM   #30
chris82
chris82's Avatar
827
Drives: 128i
2009 BMW 128i  [9.80]
This is soooooo cool! I cannot wait to see the final stage!
      04-14-2021, 07:45 PM   #31
Dieselboy
Dieselboy's Avatar
452
Drives: '09 135i
That was a tough job, but all the bushings are in. Now for a short vacation, then I'll get the coilovers in when I get back.
Appreciate 2
tsk941522.00
      04-26-2021, 08:02 PM   #32
Dieselboy
Dieselboy's Avatar
452
Drives: '09 135i
I have finally gotten around to installing the rear coilovers. Just waiting on new subframe bolts before I put the rear back together then move to the front.
      05-10-2021, 11:57 AM   #33
Dieselboy
Dieselboy's Avatar
452
Drives: '09 135i
Supply chains are really a mess right now and everything seems backlogged. Still waiting on word from Japan on my wheels. At least I got the Pure stage 2 High Flow turbo's ordered, probably a few weeks for delivery so I'll get the front end up in the air and start taking things apart.
      05-14-2021, 05:59 PM   #34
StevieJ2
87
Drives: 135i
did you get your wheels figured out? I can get you in touch with a wheel manufacturer that can cut almost anything from t6061 at a fraction of the price from most other companies.
      05-17-2021, 07:03 PM   #35
Dieselboy
Dieselboy's Avatar
452
Drives: '09 135i
Still waiting on a response from Japan. I'm pretty sure guys on the e90 forums are running these. What wheel manufacturer?
So I've had this Setrab 50-920-7612 oil cooler and IR 185F thermostat sitting on my shelf for a few years and I'll finally be making a custom mount for it. My plan right now is to place it on the diver side in series with the stock cooler.
      05-19-2021, 03:44 PM   #36
denholms
Drives: 2011 BMW 135i
Very nice!
Been considering a widebody kit as well, but may be waiting for someone to put me into the wall too :P Admire your work thus far!
      05-19-2021, 06:22 PM   #37
twinturbovan
207
Drives: 2009 BMW 135i M Sport Vert
Dang that looks good! I cant wait to see it all painted. Are you having the widebody molded or just bolted on? Would look amazing molded to the car!
      05-20-2021, 08:33 AM   #38
Dieselboy
Dieselboy's Avatar
452
Drives: '09 135i
Thanks, appreciate it!
Thanks. I am going to keep it bolted. The car will be used on the track and having the ability to remove body panels makes it much more practical.
Still no delivery date from Pure for the turbos, but I will get the car jacked up and begin the fun process of pulling the old twins out soon. Unfortunately, with a fleet of Italians, there are no shortage of projects going on.
Appreciate 3
tsk941522.00
SKI-R159.00
      05-20-2021, 02:59 PM   #39
tsk94
tsk94's Avatar
1522
Drives: E92 M3, E82 128i, F82 M4, E36
That is indeed a fleet!
      05-21-2021, 09:20 AM   #40
wdb
dances with roads
wdb's Avatar
4737
Drives: '07 E86, '02 996, '95 Seven
Impressive thread, even more impressive build, most impressive technical chops! I'm just poking my nose under the E82 tent and getting a feel for things. This is truly inspiring.
A question if I may: why stay with the stock diff? My understanding is that 128s in the US are all open diffs, other than perhaps the 1M.
      05-21-2021, 10:58 AM   #41
Dieselboy
Dieselboy's Avatar
452
Drives: '09 135i
Thanks! The 135i is a challenging platform, but it has a cult following for a reason. If you're not one that can/will wrench on the car, or if you're hung up on the things that BMW got wrong (Rubber bushes, open diff, thermal issues, water pumps, etc..) then I wouldn't recommend the E8X. I was shopping for a 997 Turbo last year and decided that if I dump $20-$25k into the 135i it will be a monster, plus I love a challenging project. Although, financially, the Turbo would have been a muuuch better decision since their values are going through the roof.
Open diffs are really just a cost savings measure from OEM. I'm actually in the LSD Group Buy so I'll be upgrading to the M factory Helical Differential.
wdb4736.50
      05-21-2021, 05:57 PM   #42
wdb
dances with roads
wdb's Avatar
4737
Not to mention that 997s are a dime a dozen. They make, what, 30,000 911s a year or something.
      05-25-2021, 02:52 PM   #43
WhoIsJaime1M
WhoIsJaime1M's Avatar
Drives: Bmw 135i
Build looks wicked, can't wait to see more.
      05-26-2021, 02:09 PM   #44
BMWWorld
235
Drives: E90
2008 BMW 135i  [0.00]
Wow great build👌🏽
I'm eager to see the finished product🔥
Any info on the chasis mounted brackets for the wing? Would it fit a CSL style trunk?
1addicts
