2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes Bilstein B6's SUCK???? Yes!!
      11-20-2023, 06:25 PM   #1
rvt1000
Drives: 2070 M240ix
Need to replace front struts on my '17 240ix. Wanted to upgrade over stock to take care of the instability over expansion joints etc. Article I read said the Bilstein B6's were the upgraded shock that still kept the other functions and variable damping.
Now that they are installed it's like sport mode all the time. I feel zero difference between eco, comfort or sport.
Anyone else running B6's how do yours feel?
Edit: put a few more miles on it and it feels slightly better. But still not much difference in modes and mostly if pushing a corner. Still harsh for eco or comfort mode. (Sorry about the overdramatic verbag before)
They do feel like an upgrade and if they breakin a bit they should be an upgrade. Thoughts?
      11-21-2023, 06:43 AM   #2
YYZF22N55
YYZF22N55's Avatar
23
Drives: 2014 M235i
I’m running b16s and they feel like an upgrade over m suspension
      11-21-2023, 07:20 AM   #3
Dom147
92
Drives: 2014 BMW 228i, 2017 BMW M240i
2017 BMW M240i  [0.00]
You mention they retain variable damping. Did you buy the B6 Damptronics?
      11-24-2023, 02:13 PM   #4
jb-slow
111
Drives: m235i
I have the b6 damptronics on my car, they are stiffer across the board, and I'm pretty sure they lifted up the ride height a bit. They're fantastic on track though.
      11-25-2023, 01:53 PM   #5
Matthewricha
43
Drives: M235i
I have the B4 damptronics on my M235i and they too are rather harsh. A lot more NVH, especially over high freqency road imperfections. However the car handles really well. Can get tiresome at times. Mine definately raised the ride height by about 8-10mm. Sometimes in Sport mode I can feel the rear rise slightly.. not by much though
      11-26-2023, 10:58 PM   #6
Rich.Wolfson
Thaumaturge
181
Drives: 2014 M235i
I replaced the OEM Damptronic shocks at 90,000 miles with the Bilstein B4s. I would have done them sooner but the shocks were hard to find. I labored whether to get the B6s but I find the B4s perfect in every way. No noticeable NVH and no ride height change.
Just my experience.
///Rich
      11-27-2023, 02:47 PM   #7
Matthewricha
43
Drives: M235i
Just my experience.
///Rich
Interesting! you look to have the same car as me. I do have M Performance springs on the front which are stiffer than M Sport but also 19inch 624M Alloys so not much sidewall give. Do you run 18 inch wheels? Having said this I went directly from OE Dampers to B4 with the same springs and wheels so the only difference was the B4's and they definately made the ride harsher. Guess this is a subjective subject.
      12-10-2023, 01:34 PM   #8
M3SQRD
M3SQRD's Avatar
2300
Drives: E92 M3,G20 330ix,F22 240iX,F82
The B6 are a high nitrogen pressure monotube damper. The nitrogen pressure provides a lifting force on the valve stack so you’ll see a 1/2-1/3” increase in ride height.
      12-10-2023, 01:39 PM   #9
Matthewricha
43
Drives: M235i
The passives maybe, but the B6 damptronic shocks are twin tube..when I compared my OE shocks to the B4 damptronics the spring cup on the B4's were tapered differently to OE which results in the very small height difference.
      12-10-2023, 04:45 PM   #10
M3SQRD
M3SQRD's Avatar
2300
From the literature I’ve read about b6 and b6 damptronic dampers is they’re all high pressure nitrogen monotube dampers.
      12-10-2023, 05:29 PM   #11
Dom147
92
they reused the same description of the damptronics and the regular B6's. The damptronic are indeed twin tube which is evident by the thinner shaft.
      12-10-2023, 05:51 PM   #12
M3SQRD
M3SQRD's Avatar
2300
Here’s the link the B6 product page and a screen cap pic of the b6 features
https://workshop.bilstein.com/en/products/bilstein-b6/
Here’s the BW description of the F22 B6 dampers:https://www.bimmerworld.com/Suspensi...Drive-EDC.html
Directly from Bilstein’s website (third bullet from bottom):
      12-11-2023, 06:53 AM   #13
M3SQRD
M3SQRD's Avatar
2300
The Subaru front dampers are a twin tube design buy the rear dampers are still a high gas pressure monotube design. So some brands do use twin tube; however, BMW is using F and R monotube designs.8
      12-12-2023, 12:07 AM   #14
M3SQRD
M3SQRD's Avatar
2300
Increase in ride height is fixed and is due to the high nitrogen gas pressure Bilstein runs in the monotube dampers. The gas pressure creates a lifting force on the damper valve stack.and will raise the car from 1/2-1/3” but it doesn’t change with different edc/sport settings.
      12-12-2023, 12:10 AM   #15
M3SQRD
M3SQRD's Avatar
2300
So please show documentation where bmw b6 passive and damptronic dampers use a twin tube design. If not please stop spreading misinformation regarding bmw b6 dampers.
      12-12-2023, 02:16 AM   #16
Matthewricha
43
Drives: M235i
I am not spreading misinformation. I contacted Bilstein Leicester UK about three years ago to clarify a few things on the product and they stated they were twin tube. There was a marketing error carried over from the passive shocks. The installation instructions also show you must use an external bumpstop on the front shocks, which if was a monotube shock would have an internal bumpstop and wouldn't need an external one. The TUV certificate also states these are twintube - unfortunately bilstein removed this from the web a while back. This has been discussed at length on the UK sites, such as babybmw. Also a large thread on these here:
https://f30.bimmerpost.com/forums/sh...296041&page=17
The M3/M4 B6 Damptronics ARE monotube however, which are different part numbers obviously.
https://web1.carparts-cat.com/defaul...04&14=4&12=130
look up 23-250734, 23-250727 & 20-250744
Dom14792.00
      12-24-2023, 01:22 PM   #17
XutvJet
5582
Drives: 2011 Cayman Base, 2016 M235
My current suspension is quite the Frankenstein setup. I have OEM dampers with Dinan springs in the front and Bilstein B6 Damptronics, shorter E series bumpstops, and Eibach Pro Kits in the back. I didn't like the Dinans in the back as their linear rate was too soft and created more squat and crashing into the stops. The Dinans were also really low in the back even with their ride height increasing spacer. The Eibachs are stiffer, progressive rate, and sit about 1/2" higher than the Dinans with the height increasing spacer.
I had B6 Damptronics in the front for about 2 weeks. They were terrible. They were harsh in all mods, crashed over bumps, clunked (common B6 issue), and raised the front end a full 1/2" (known issue). I told FCP Euro that I wasn't happy with them and they said to send them back for a full refund including shipping their dime. The B6s in the rear have been great for 3 years. I've always felt the rear axle on these cars just weren't damped and sprung right. The B6s and Eibachs fix much of it.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
2addicts
