12-17-2022, 06:47 PM | #243 |
Dom
1080
Rep 1,719
The final update on Charlotte is that I added some JDM goodness! I've always loved TE37's and when I found out that the TE37SLs were going EOL, I had to grab a set. I wasn't going to settle for the standard F8x spec so I worked with Thomson over at System Motorsports to buy two new sets for the ultimate spec. I bought a set for e9x and f8x so that I could end up with a 10.5/11 et20/34 spec. I sold the square set to a member here so it all worked out well.
It's not for everyone and that's ok. Mag Blue is and always has been my favorite color of TE's and I'm stoked that I could make this happen. |
WedgeSalad289.00 MooMooM21825.00 happyjack1657.00 frenzy75778.00 Carrera2RS204.00 Bruuuce349.00 aatlas201.00 WordOnRoad313.00 Talx85.00 |
12-19-2022, 04:54 PM | #245 |
240
Rep 224
12-20-2022, 12:28 PM | #250 |
Dom
1080
Rep 1,719
That's something for you to decide for yourself. It will shave some weight I'm sure. Will it be worth it for most? Not sure. I got one because I flat out wanted to.
05-26-2023, 10:30 AM | #254 |
Dom
1080
Rep 1,719
Been a while and not that much has changed. Here are some shots for your viewing pleasure. Enjoy.
Oh and I picked up these... Last edited by ebisu8; 05-26-2023 at 10:35 AM.. |
F87Tomei268.50 iam2slow78.50 aparedes302.00 trainerjon49.50 WedgeSalad289.00 white2abbit1125.00 Garrettwilly9.50 aatlas201.00 |
10-05-2023, 03:29 PM | #255 |
101
Rep 87
Sick build! I’ve been digging around looking for info on the do88 intake. On paper they look awesome. Closed system… trusted and available filters. What are your thoughts on them? Also can you open the tops without taking the carbon f bracket off?
10-10-2023, 09:47 AM | #257 |
-Frank
504
Rep 691
such an insane build.. There's ZERO things I would change if I built this car myself.. Nicely done sir!
2005 M3 - SilverGrey/MT - SOLD
2013 E92 M3 ZCP AW/IR-BLK 2022 Ram 1500 Laramie Night Edition - leveled/34s IG: @_frank_stone_ |
ebisu81079.50 |
10-16-2023, 04:13 PM | #258 | |
1558
Rep 2,505
2019 M2 Competition- October 2, 2018 ED
2011 BMW M3 Sedan Alpine White Picked up via ED 9/27/2011 & Redelivered 11/23/2011 **SOLD** |
04-04-2024, 05:21 PM | #260 | |
39
Rep 180
how does the OEM seat belt connector attach to the Schirmer Seat Rails? |
04-11-2024, 12:18 AM | #261 |
165
Rep 114
ebisu8
It’s finally twigged after reading your thread. We met last year (or maybe the year before) at ring. You follow my misses (missmelt_) on insta and I’m the better other half Car looks so good, you need to get it out to ring. We are out there again this July for the same TD you saw us on. |
ebisu81079.50 |
04-14-2024, 05:18 PM | #262 | |
Dom
1080
Rep 1,719
