05-01-2024, 09:01 AM | #1 |
104
Rep 89
Noob question - Spacers
I’ve been reading about spacers for the M2CS and I’ve seen mixed reviews. I’m thinking a lot of the negative talk is simply surfacing from bad/unusual experiences and the good experiences go unsaid.
Any recommendations/thoughts on spacers with m2cs on stock suspension and rims (PSS if that matters)? I’m considering the future classic 10mm front/rear with the extended bolts. Do not want to experience any vibrations etc. |
05-01-2024, 10:24 AM | #2 |
3037
Rep 13,778
On stock suspension, you're better off running 5mm spacers with minor to no rubbing. 10mm is a bit aggressive w/o further camber adjustment.
~loud noises~
05-01-2024, 06:44 PM | #3 |
301
Rep 359
I ran 10mm all around on my Comp, and now on my CS with running 2.5 deg camber with Vorshlag camber plates. I have experienced absolutely no issues with the current setup. It certainly makes the CS look aggressive if that's what you're looking for.
05-01-2024, 07:09 PM | #4 |
3037
Rep 13,778
He says stock suspension...I could have said I ran Vorschlags too and ran 15mm fronts and 5mm rears, but for where he's at...5mm is the safer bet..
~loud noises~
05-03-2024, 11:37 AM | #7 |
104
Rep 89
Yea found some pics of 10mm and it looks aggressive like you mentioned. Probably a slight bump with 5mm would do the job. Are you still running the RacesEng stubs/bolts?
05-04-2024, 12:48 PM | #8 |
2197
Rep 2,366
Im running 12mm spacers front / 7.5mm spacers rear with wider 255/275 MPSS tires. Looks awesome (pics in link below).
https://f87.bimmerpost.com/forums/sh....php?t=1865324
BSM ///M2cs, 6spd
05-04-2024, 01:19 PM | #9 |
3037
Rep 13,778
I was. Best Ti kit out there. MRG constantly galled and I had to replace 4 studs in the time I had them, but Raceseng were solid. Never once had any issue. And each time they were always hand threaded prior to following with light impact and torque wrench.
~loud noises~
05-05-2024, 02:14 PM | #10 |
311
Rep 117
My car is lowered and I run 10mm all around from future classic. No issues with vibrations at all. I have a little rubbing at full lock but I’m not usually driving at full lock so it’s ok! 😂
For me, the spacers complete the look and fill out the wheel wells. |
