10-17-2022, 01:30 PM | #45 |
889
Rep 1,266
Drives: 2016 M4 GTS
I actually purchased both pieces from a 3rd party. He had them new in box and needed to sell during a part-out.
2021 X5M Comp Marina Bay Blue
2016 M4 GTS Alpine White 2005 M3 Comp Interlagos Blue Instagram: @JustAnothaM4 |
GuyLedouche587.50 |
08-08-2023, 07:00 PM | #46 |
Rep 41
Is it possible, for you to tell me what spring rate that your using in the front and rear and if your using assist spings or helper spings and what rate those are aswell ? I have the ttx and wanted to swap to swift.
Thank you 😊 |
08-14-2023, 10:01 PM | #47 |
889
Rep 1,266
Drives: 2016 M4 GTS
Hey sorry for the late reply. I知 running swift springs at 784/672 with helper springs in front and rear. I知 running full coilover in the rear hence the lower spring rate.
Bobaeappa9.00 |
08-15-2023, 03:48 AM | #48 |
Rep 41
Thank you for the info, I follow you and trying to learn from your build, so much is appreciated !
08-16-2023, 02:07 AM | #49 |
Rep 1
I知 really interested in this 4N kit. Do you have pictures of it installed? What did you end up doing wit the maf harness? Does it look like it would be possible to integrate with the driver side air box?
Thanks |
10-09-2023, 03:33 PM | #50 |
889
Rep 1,266
Drives: 2016 M4 GTS
No, I really don't have any installed pictures. Nothing much to see under the hood. MAF harness is not used during the conversion. Anything is possible with custom engineering to use the oem driver side air box.
