03-29-2017, 02:46 PM | #1 |
201
Rep 1,075
Rotors
Does anyone know if the rotors on a 135i can be machined or do they just have to be replaced whenever you change the pads?
2012 135 Convertible 6MT
2017 Acura MDX |
03-29-2017, 03:06 PM | #2 |
3483
Rep 3,722
Usually people do not turn rotors on these cars, but there's a lot to be said on this... If they are thick enough they should be fine, otherwise replace.
"Tobias" 2013 135i ///M-Sport 6MT • Pure Stage 1 • XDI 35 HPFP • 404whp/440wtq |
04-01-2017, 09:06 AM | #3 |
537
Rep 2,825
what makes a 135i rotor different from any other rotor?
if you have enough surface left, refinish them. no use in replacing a perfectly good rotor. |
MightyMouseTech4337.50 |
04-01-2017, 10:08 PM | #4 |
Ex '87 Carrera
248
Rep 1,259
I didn't even bother to get them turned when I did pads. I measured them to be within spec so just installed pads. It took a few weeks for the pads to bed in to the rotors, but they've been fine...
ianc |
04-04-2017, 01:20 PM | #5 |
201
Rep 1,075
On other cars it seems like sometimes they can be cut and other times not.
Honestly I think its a ploy for more money because honestly I never actually check the thickness for myself. I will not do pads without either machining the rotors or putting new ones on though.
2017 Acura MDX |
04-04-2017, 03:21 PM | #6 |
77
Rep 310
The minimum thickness is stamped onto the rotor hats. Just measure them and see if they can take some additional mileage. From what I've read, the rotors usually do have more life in them, but not enough to see end of a 2nd set of pads. Make sense?
2011 BMW 135i M Sport Space Grey - BMS JB4, VRSF 3.5" catless DP, Berk exhaust, BMS intake, ER CP, Eibach Pro-Kit, H&R spacers, black kidneys, Blacklines, LUX angel eyes
2014 BMW X5 xDrive 35d M Sport Mineral White - MPBK w/ F85 rotors & Carbotech pads, ACS Springs/Links, iND reflector deletes, iND black roundels, MP black kidneys, M50D grille inserts 2007 Suzuki GSX-R 750 - too much to list |
Matticus913482.50 |
04-04-2017, 06:10 PM | #7 |
816
Rep 1,199
I've read that German cars tend to have a pad and rotor material combo that sacrifices more rotor and less pad than a US domestic design typically does. Apparently this is part of the reason for the large amount of dust seen on these makes. So our rotors may not last two full sets of pads with turning. If you're changing to the same type of pads and you know the starting thickness of your rotors and what will remain after turning, you can estimate if by the end of the second set if the turned rotor will end up below minimum thickness. If it doesn't, then go for it.
04-04-2017, 07:26 PM | #8 |
5150
Rep 3,241
I've thought about this situation. People may disagree with me but I don't know if turning/machining rotors are actually a good thing. You're taking material off of the rotor which decreases the thickness of the rotor. Depending on how hard you beat on your brakes, this can manifest itself in decreased strength and heat dissipation capacity.
If the surface isn't too buggered up, I tend to just throw new pads on and leave the rotors alone. I would also consider checking the run out of the rotor which I think is as equally important as rotor thickness. |
04-04-2017, 08:13 PM | #9 |
18
Rep 100
so on my Land Rover, replacing rotors was part of a normal pad replacement. I asked about it, and they said that was the tech book requirement, because they made the rotors lighter weight and disposable to increase weight savings. kind of makes sense.
2011 135i DCT
Space Gray Metallic | TR Motorsports 17x8 ET40 Wheels | Koni Yellows | FMIC | Charge Pipe | MHD Stage 1 | Riken Raptor 245/40ZR Tires |
04-04-2017, 10:01 PM | #10 | |
Ex '87 Carrera
248
Rep 1,259
ianc |
04-05-2017, 09:05 AM | #11 |
201
Rep 1,075
I'm sure I'll probably just bend over and let the dealer bone me for new rotors.
I agree that if the thickness is close then in my experience the dealerships (non-BMW anyway) won't machine them. I've had them tell me that maybe an independent shop will but they won't. But honestly how much rotor actually wears during normal use? I expect the pads to wear but significant rotor wear surprises me?
2017 Acura MDX |
04-05-2017, 12:10 PM | #12 | |
816
Rep 1,199
Why are you letting the dealer do brakes? They'll rape you. You should be buying aftermarket brand (think Ate, Zimmerman, Bosch, Brembo) rotors/pads and installing them yourself or at worst an Independent shop. Brakes are simple. |
04-06-2017, 08:43 AM | #13 |
201
Rep 1,075
Yeah I have a decent shop not too far away from me who I may use instead.
I'll get a quote from the dealer and from that independent guy. I was going to ask him about aftermarket pads and rotors to see if there's something better. Honestly I have neither the time nor motivation to do them myself.
2017 Acura MDX |
04-09-2017, 02:53 PM | #14 | |
Driven Crazy
190
Rep 505
If you are not tracking the car extensively, there is no need to worry about heat dissipation. Cutting the rotor takes off thousandths of an inch. When my daughters $1,500 ice skates are sharpened, he takes off 3/1000 of an inch. Because I used the rotor on a second set of pads, and because I want to error on the side of caution, I have new Bosch rotors and another set of pads on a shelf. I will replace them when the pads are about 2/3 worn instead of 4/5 worn.
'08 128i 6M
04-09-2017, 05:39 PM | #15 | |
5150
Rep 3,241
04-09-2017, 09:18 PM | #16 | |
Driven Crazy
190
Rep 505
Are you saying the rotors should be machined before installing new pads in order to get rid of the deposits on the rotor. Deposits that people call warpage, or actual warping of the metal disc?
'08 128i 6M
04-12-2017, 07:43 PM | #17 |
48
Rep 154
Buying new rotors is not necessary if you maintain your pads and calipers regularly.
It seems most people just drive forever until their brakes start making weird noises. By that time the calipers are sticking or seized, the pads are worn or cocked and stuck and the rotors are gouged by metal on metal. If you remove and clean the pads and lube the calipers, your rotors can easily run 100,000 miles. I've done that on several vehicles. I just bought my 135i last fall. Supposedly all looked after by the dealer. The first thing I did was remove all wheels and calipers and rotors and clean and lube everything. Dealers and brake shops rarely do this carefully and thoroughly. They don't really care. It's not their car. They want you to come back and buy new parts as often as possible. |
04-13-2017, 08:58 AM | #19 |
816
Rep 1,199
My 330's rotors are at about 90K. They're still smooth as silk and I've pad slapped them twice (didn't like the pads I tried). My 128i rotors are in shit shape. Trying to get the replaced under warranty soon haha.
04-14-2017, 12:52 PM | #20 |
48
Rep 154
Yeah, sometimes it's not the owners fault. Acura ILX came straight from the factory with noisy faulty rotors. It took them a while to figure it out. Rotors were cracked. Perhaps another "made in China" savings plan?
04-16-2017, 10:28 AM | #21 |
117
Rep 460
Even on new BMWs, you'll find the rotor surface is rather rough to the point of being grooved. Also the stock pads throw off a lot of dust. The idea is the stock pad has more stopping bite when braking from very high speeds like I guess they do in Germany?
I always remove the stock pads for something that doesn't throw off a lot of dust and mess up the look of my wheels. Are you thinking I'm not concerned with safety? Well I am seldom slowing down from triple digits. I use these for replacement pads: https://www.tirerack.com/brakes/brak...2&autoModClar= These stop my car better than the stock, they throw off very little dust, bed quickly, and don't make any noise. A tip before changing rotors. I never machine rotors regardless of their appearance. You can usually judge wear by examining the lip of each. I slap on the new pads, and if they don't make any noise and stop OK, I'm good to go! BTW, I have a set of stock pads with 50 miles of wear. I'll trade for some wheels. Last edited by Mr Rooty Von Tooty; 04-16-2017 at 10:34 AM.. |
