BMW M2 Forum > Regional Forums > AUSTRALIA > ASD bypass harness
      07-13-2020, 10:42 PM   #1
BMWF87Melb
201
Drives: VW Golf
ASD bypass harness
Hi all,
Has anyone purchased and installed the ASD bypass harness (https://technicpnp.com/product/asd-bypass-harness/) and had this installed in Melbourne?
If so - how much did shipping you back for the harness and where in Melbourne did you get this installed?
Thanks!
      07-14-2020, 01:57 AM   #2
Dec540
136
Drives: M2 LCI
Is there a specific reason you're looking at going down this path over coding it out with the like of bimmercode?
specka71.00
      07-14-2020, 02:01 AM   #3
BMWF87Melb
201
Drives: VW Golf
Maybe it's my ignorance on the topic but not entirely comfortable with tinkering with anything coding wise.
I've also read some coding out ASD can leave some static noise from the speakers.
      07-15-2020, 01:47 AM   #4
OzWoz
OzWoz's Avatar
75
Drives: 2017 M2, 6MT
Interested in this, as I'm planning on getting a Fabspeed sportcat and ASD doesn't play nice with aftermarket exhausts or downpipes.
My basic research suggests that the the harnesses sold after 2016 have mostly reported no hiss. The beauty of Bimmercode (apart from the many other changes you can make), is that you can try coding out the ASD and see if it works. If it doesn't, get the harness and you'll still have a versatile tool in Bimmercode to tailor your car.
      07-15-2020, 05:35 AM   #5
MR RIZK
MR RIZK's Avatar
758
Drives: AW M2C
I was just about to post for a group buy on this not to get a discount but split the shipping. It appears to be USD$35 just shipping for one unit and still the same for a few. Shame u are in Melbourne as would be happy to split the shipping.
From what I have read the harness does not eliminate the hiss, it is to do with the low voltage output of the deck but I wanted to try anyway as the hiss pisses me off.
If any Sydney peeps want to join my order PM me as i will intend to order this week.
Previous Rides: 13' 135i, 08' 130i, 03' HKS Turbo'd 350z, Modded GC8 WRX, NA MX5
      07-15-2020, 06:15 AM   #6
BMWF87Melb
201
Drives: VW Golf
From what I have read the harness does not eliminate the hiss it is to do with the low voltage output of the deck but I wanted to try anyway as the hiss pisses me off.
Damn.. pity you're in Sydney
Yup I got quoted $35USD for shipping.. a bit steep.
Can I ask what's your reason to get the harness?
      07-15-2020, 06:17 AM   #7
BMWF87Melb
201
Drives: VW Golf
Sorry I know I could do a bit of a search.. but does the use of bimmercode void warranty?
      07-15-2020, 07:29 AM   #8
MR RIZK
MR RIZK's Avatar
758
Drives: AW M2C
As mentioned a last ditch effort to see if it gets rid of the hiss that is inherent in the system.
To your other question there is no straight answer. Some will say "anything you change" you have voided but the reality is that you are changing an audio setting from on to off via an in built setting so the chances of voiding is slim to none. But hey I'm no lawyer.
      07-15-2020, 07:31 AM   #9
BMWF87Melb
201
Drives: VW Golf
As mentioned to see if it gets rid of the hiss that is inherent in the system.
Cools thanks. You got an aftermarket exhaust on your car?
      07-15-2020, 07:33 AM   #10
MR RIZK
MR RIZK's Avatar
758
Drives: AW M2C
Nope oem with ASD coded off
      07-15-2020, 05:12 PM   #11
Caduceus
342
Drives: 2008 135 (sold), 2017 M2
I got the harness a couple of weeks after my M2 was delivered in Nov 2016. Bimmercode wasn’t available at the time so the only solution was a hardware fix.
Install is quite easy to DIY. There’s no wires to cut or splice. Just some trim clips to remove and a harness to plug in.
I can’t hear any static hiss at all. It’s a good mod because ASD is rubbish and the OEM exhaust sounds great by itself.
      07-15-2020, 05:19 PM   #12
BMWF87Melb
201
Drives: VW Golf
I'm not the most handiest around with my car.
Is it fairly straightforward to do? Did you follow instructions given on the forum as I wouldn't have a clue where to plug the harness into!
      07-15-2020, 05:26 PM   #13
Ahhchu
Drives: F87
https://www.2addicts.com/forums/show....php?t=1202389
Here's a fairly detailed post on the process. Your thread got me interested so I did a bit of digging around.
      07-15-2020, 05:30 PM   #14
BMWF87Melb
201
Drives: VW Golf
Legend - thanks for this! Looks fairly straightforward.
      07-16-2020, 04:52 AM   #15
specka
71
Drives: M2 LCI BSM
2017 BMW M2 LCI  [0.00]
+1. That's what I did, no static or anything from speakers (just went and checked in the garage to be sure)
To me this is the simplest method, I can vouch for it as well as the other handy items you can code (disabling auto start stop being the one that stands out, also disabling headlight washers)
Good Luck.
M2 LCI - DCT - BSM | BM3 Stg 2 | Eventuri Intake | Fabspeed Sportscat | Wagner Evo 2 FMIC | Ohlins R&T | Rays | Recaro Sportster CS
      07-16-2020, 08:55 AM   #16
BMWF87Melb
201
Drives: VW Golf
Good Luck.
Thanks for the inputs on the topic. Do you have an aftermarket exhaust and do you still leave asd coded off?
      07-20-2020, 09:53 AM   #17
specka
71
Drives: M2 LCI BSM
Good Luck.
I have the Fabspeed sportscat and stock catback which sounds awesome. ASD was off both before and after its fitted, better in both scenarios.
      07-20-2020, 11:58 PM   #18
BMWF87Melb
201
Drives: VW Golf
Don't find the car too quiet with ASD off with the OEM exhaust?
      07-21-2020, 12:00 AM   #19
BMWF87Melb
201
Drives: VW Golf
Thanks for that - you mentioned ASD off was better even with the stock exhaust. You didn't find things too quiet? That's my concern - once I switch off ASD, I'll need to then go get an aftermarket exhaust! I'm already thinking MPE and I've only had the car one month :s
When covid restrictions are over - hopefully get the chance to hear the MPE more in person from our community forum members. Lots of Melbourne owners here on the forum have the MPE for the OG M2?
      07-21-2020, 05:06 AM   #20
LuNguyen
Drives: M2 Competition
I've got the Akra slip on on the competition and initially coded out ASD. I added the harness and thought it sounded cleaner again with less hiss but how much of that is placebo effect who knows. The install is easy you'll be able to do it. I have a set of trim removal tools for these jobs too.
      07-21-2020, 04:54 PM   #21
BMWF87Melb
201
Drives: VW Golf
How do you find the akra exhaust on the m2c?
      07-21-2020, 08:33 PM   #22
LuNguyen
Love it. It's not cheap of course. However, I wanted to get rid of the low hanging muffler look and I opportunistically had it installed at the same time that I had my car in for wrap.
I know the S55 sound has a bad reputation but I think with the akra it sounds great. I still think the flat six is the best and that will be the direction I eventually move again.
m2
