04-23-2024, 08:10 PM | #1 |
Rep 13
Drives: BMW F30 328i
Need Help 2018 F90 M5
I have been having a issue when i get on the gas it starts misfiring.
i ran diagnostic test and turns out its cylinder 5 and 6. Note: my coolant tank did start leaking but caught it quick and replaced. The car runs great no issues until i get on it. then goes into limp mode but resets. i ran endoscope into cylinder 5 and 6 and i will post pics. to me the walls look great, plugs had oil all over them in 5 and 6 and coolant tank i pulled looked brownish but could still see green tint. it looks like the oil is running down from top of cylinder walls. i am thinking head gasket. Unfortunately i should have ran compression test but i didnt. i honestly dont think its the piston seals. car has 60K miles. If someone could help me please. Last edited by California209; 04-23-2024 at 08:16 PM.. Reason: forgot some pictures |
04-23-2024, 08:15 PM | #2 |
2274
Rep 3,300
Just Crying to see such an issue on such low miles. 60k? that is just sad.
Hope you get it sorted out. Mike
2018 M5 and 2019 Porsche Boxster GTS Prior. '94 325is, '97 M3 Lux, '16 M2 |
04-23-2024, 08:21 PM | #3 |
Rep 13
04-23-2024, 08:57 PM | #4 |
5263
Rep 10,642
I would want to rule out the worst post possibilities like a headgasket failure. How long have you owned the car? Are you confident no one added the wrong coolant, which could turn the coolant brown? Has the coolant level been rising? What does the oil look like?
Have you looked at injectors 5 and 6 for signs of coolant residue? What are the codes? What scan tool are you using? Misfiring in 5 and 6? Have you swapped plugs and coils to other cylinders? Did you inspect any other cylinders? No oil running down the cylinder walls? Leak down test on 5 and 6? |
04-24-2024, 08:58 PM | #5 | |
Rep 13
