BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Suspension | Brakes | Chassis
      03-28-2024, 06:49 PM   #441
Redd
3910
Drives: 2010 BMW E92 M3 Dakar Edition
Originally Posted by andrihallik View Post
Just fitted the G series smaller 4 pot Brembo brakes on e92 m3.
Basically bolt-on, only modifications required are
2mm washer,
cut the dust shields from bottom side 2-3cm,
cut the brake pads from bottom side ~3mm.
I used the 7 series G11 740i 2017 unpainted calipers and painted black. Will but some sticker there aswell.
Thank you for sharing this! Any part number for the calipers? Did it require new brake lines?
      04-01-2024, 03:43 AM   #442
andrihallik
Drives: E92 M3 DCT Silverstone II
Right now used the old brake lines that were on the e92. Probably upgrading to braided lines when next brake pad change comes - right now used the same pads that came with the used 7 series calipers, half worn pads for testing.
So far ~400km the wear on the disc is even - on top side of the disc the lip/wear continues from the same spot that the original e92 m3 pads touched so ~1mm from top. On bottom side where the pad was cut they go over the disc little bit so no lip there anymore. With new pads i can use them as template to get correct size pads.
I used G11 7 series 2017 non m brakes. (not painted calipers)
34116891275
34116891276
The M brakes on 7 series are bigger (the two cylinders on front of the caliper have some room). This video is very informative but misses the non painted calipers, exactly the same but not painted.
      04-26-2024, 01:51 PM   #443
PCG.DTCH
How much is the Fish?
PCG.DTCH's Avatar
Drives: BMW E92 M3
Anyone using the CCB-Calipers of a Alfa on a E92 M3?
Didn't know there was a difference between the calipers used on the Steel vs. CCB version of that car.
Steel LEFT | CCB RIGHT
Currently have the FreakyParts calipers on-route, so i'm trying the CCB ones.
But if that isn't possible with 18" wheels, i'm switching to Steel calipers.
      04-27-2024, 07:51 AM   #444
M3SQRD
M3SQRD's Avatar
2288
Drives: E92 M3,G20 330ix,F22 240iX,F82
You mean steel rotors, not steel calipers, correct? What size rotor are you pairing with the Giulia calipers?
CCB calipers tend to be larger (deeper/thicker) to accommodate a pad with a longer radial depth and wider to accommodate the thicker CCB brake rotors. Do you know if there’s a pad available that matches the radial depth of the rotor surface being used and appropriate pad shape and thickness? CCBs tend to have much longer radial depths to help radiate heat. Do you know the piston sizes and have you calculated the piston areas/brake bias of stock vs Guilia calipers?
      04-29-2024, 03:30 AM   #445
PCG.DTCH
PCG.DTCH's Avatar
Drives: BMW E92 M3
Thanks for your Reply,
What i meant was: Using a Alfa caliper, that's used on a Guilia with CCB brakes.
There are some clear differences between the Alfa calipers.
I bought a set, and found out they we're for the CCB-brake system.
Want to pair them with 360mm disks (OEM) because of my 18" E88's.
But i don't think they're going to work.
Sourcing a different set isn't that hard over here (Europe). So i think i'm going that route.
      04-29-2024, 10:31 AM   #446
M3SQRD
M3SQRD's Avatar
2288
With it being a caliper from a CCB setup, it’ll be tough to find pads that work with steel rotors. Also, getting the correct radial depth for a pad to cover the OR and IR of the brake rotor. At a minimum you’d probably have to grind the bottom of the pad to have the correct depth and IR.
I believe the Essex/AP Racing radi-cal 5000R 372 mm F and 365 mm R rotors fit in E88’s.
Good luck with your retrofit!
      05-02-2024, 01:20 PM   #447
chrislacedup
chrislacedup's Avatar
Drives: 2009 E92 M3
34116891275
34116891276
The M brakes on 7 series are bigger (the two cylinders on front of the caliper have some room). This video is very informative but misses the non painted calipers, exactly the same but not painted. https://www.youtube.com/watch?v=QGf_I-4DXhE&t=137s
Hey man I see you are pretty informed regarding these retrofitted calipers coming off a 740i.
I found some local calipers that came off a 2018 X3 that have the exact same numbers on the back of the caliper as the unpainted 740i calipers. I was wondering if you knew if they were the same caliper?
The blue painted set is from the 2018 X3
And the unpainted set is from 2018 740i
Thank you in advance.
      05-02-2024, 04:54 PM   #448
Track/S
Track/S's Avatar
1398
Drives: M2C, M4 GTS
Best brake retrofit are 2NH calipers (they have titanium pistons) with CCB or Steel discs.
CCB for 19wheels
Steel discs 400mm for 19 and 380x36 for 18's.
m3post
