06-30-2021, 07:51 PM | #1 |
360
Rep 430
BMW NBT EVO Upgrade w / Installation
Hey All,
Wanted to post this if anyone wants to switch things up a bit and I can't help but tinkering. My wife bought a new '18 X5 a few years ago and always liked her navigation with carplay built in. It always seemed a little sleaker and was touchscreen as well so started to do my research. A month ago, I decided to go with the INAV system that has a pop up screen (first photo), which is essentially an android device that leverages AUX input to toggle back and forth. I liked it, but it just didn't feel the same as my wife's X5. It's a great option but wanted something a little more and OEM. I did some research and went with an ebay retailer navi and bmw parts who could code the NBT EVO to my VIN as well as manufacturer a touchscreen from another vehicle but modified to fit the F10. Installed last night, fired right up and works perfectly. I was expecting some coding needed post install but all worked out - switched the Sirius over to the new unit in 10 min and good to go. Here are some pics of the install - took about 3 hours all in making sure I connected the right wires including the fiber optic cables and taking my time. Don't worry - I disconnected the negative terminal before I started taking things apart. Towards the end, I reconnected it before screwing everything to make sure things were working properly. |
06-30-2021, 11:47 PM | #2 |
583
Rep 487
Wow, that has to be my next mod for sure.
May I ask where you bought the NBT EVO headunit, name of the eBay seller? I will go for an upgraded headunit, but keep the non-touch screen! Edit: just found the seller, will contact him today. Thanks again for the write-up!!! |
07-01-2021, 12:23 AM | #3 |
302
Rep 1,250
Drives: BMW
That does really look good, what functions aren't working anymore? I would guess any of real traffic or connect drive. Also, what did you pay for it? you can PM me if you don't want to post. Have been debating about this upgrade, but hesitating of losing some of the OEM factions.
07-01-2021, 03:57 AM | #4 | |
583
Rep 487
I'm looking forward to the OP feedback, because I'm ready to pull the trigger. |
07-01-2021, 06:35 AM | #5 | |
360
Rep 430
I'm working through one small issue where my backup camera doesn't work but we believe it's a coding issue and working with the seller to recode the backup camera. Secondly, the kit actually came with a new idrive controller however I'm still leveraging my old ceramic idrive controller. Mine has telephone as the top right button, whereas the new one has "map". So when I hit telephone, the map comes up. Not a huge deal as I can use the idrive to scroll through or just hit the screen to go to apple car play Overall very happy with purchase |
SCD-1983582.50 TinCanSailor644.00 |
07-01-2021, 10:50 AM | #6 | ||
302
Rep 1,250
Drives: BMW
07-01-2021, 11:46 AM | #7 | |
360
Rep 430
07-01-2021, 12:04 PM | #8 |
91
Rep 174
Is there really any added benefits to adding NBT EVO IB6? Other than looking more modern? I want a bigger screen, how did you like the pop up screen size prior to this?
I am probably in the minority here that just wants Carplay and Touchscreen out of an upgrade like this. I honestly don't see the need for live traffic when you have Carplay with Waze, I don't think BMWs live traffic is going to be better than Waze, just an opinion. |
07-01-2021, 01:32 PM | #9 | |||
583
Rep 487
07-01-2021, 01:39 PM | #10 | |
302
Rep 1,250
Drives: BMW
07-01-2021, 01:40 PM | #11 | |
302
Rep 1,250
Drives: BMW
07-01-2021, 04:43 PM | #12 | |
360
Rep 430
If you just want Carplay - you probably could go with a bimmertech MMI interface that can be installed for approx $600 USD (part only). It leverages your same screen and navigation system. If you want a bigger pop up screen - I see manufacturers making 12.3 inch large screens however those look pretty big to me. INAV is a good choice too, which is what I did have, it was a 10.25 touchscreen, with carplay included. I did find some of the switching between carplay and regular usage a little different but still a very good option that I know others on the forum found worked well. |
07-01-2021, 09:51 PM | #13 | ||
302
Rep 1,250
Drives: BMW
07-01-2021, 11:54 PM | #14 | |
302
Rep 1,250
Drives: BMW
If you want bimmertech MMI you can go with generic without paying double or even more the cost, there is huge post on F30 about all those boxes, how to install, version and firmware upgrades. I have one of those in my X5 and it is ok, totally does the job, but doesn't pass wife test. So I am looking for something OEM, if those guys have figure it out, I will totally spend the extra to make the wife happy. |
Beast27359.50 |
07-11-2021, 02:30 AM | #15 | |
Follow the rabbit. 🐇
26
Rep 33
ricardofors68326.50 |
07-11-2021, 07:38 AM | #16 | ||
583
Rep 487
https://www.ebay.de/itm/NBT-EVO-id5-...-127635-2958-0 The seller is called naviandbmwparts, he is very responsive and needs your VIN to answer questions. After doing a ton of research, it's highly recommended to buy the entire setup with NBT EVO ID6 headunit, EVO touchscreen and cable. By using the original NBT screen, blackouts due to voltage conversion and lack of resolution can occur. Also, if you have rear seat entertainment (RSE), it would be required to upgrade the entire system to EVO, meaning screens and rear DVD headunit. Otherwise the front headunit won't be able to communicate with the rear headunit anymore, as they use different systems. Since I have RSE, I opted not to pursue the upgrade for now! |
sdrawkcaB26.00 |
07-11-2021, 08:34 PM | #17 |
360
Rep 430
Minor update...
Had one issue with the installation where my PDC and rear camera were not functioning. After a coding session with the seller, was able to fix to get working again. He coded partmaster 1 to partmaster 2 setting to get it to work. I've done bimmercode so the coding was a bit over my head but glad the whole unit works with integrated carplay and touchscreen navigation. The last option would have been to change some pins on the quadlock adapter which luckily it ended up being plug and play and no re-wiring required. The Seller was very responsive to my needs & questions and recommend if anyone wants to go this route. |
07-20-2021, 09:55 AM | #18 |
294
Rep 503
Wow this is a very information post. I purchased the 10.25 inch iNav earlier this year after seeing your car and its been sitting in the box in my office lol, never installed it yet. Now I need to consider selling this and going with this new solution.
In your opinion, was the only drawback on the iNav unit that fact you had to toggle between the BMW interface and the carplay interface? Any other glitches or things to be aware of?
2016 M5 | Instagram: @black_f10m5
IND cosmetic | M Performance , RKP , 3D Design aero | Eisenmann Race exhaust | AMS catted downpipes | MSR intake | CSF charge coolers | DME Stage 2 tune | KW v3 coilovers | BBS FI | Michelin Pilot Sport 4S |
07-21-2021, 01:13 PM | #19 | |
360
Rep 430
INAV: wonderful product & price point. Pretty straight forward installation but did take some fiddling with the settings to get the screen correct and other small items but no complaints. Touchscreeen was very nice and overall fit looked factory. I did struggle a little with the connection to the phone and this could be my lack of sophistication - my phone stayed connected to the android device for carplay via WIFI but also would never get to Cellular signal unless I would have to turn wifi signal off or be prompted by the phone. Again - could be my issue but wasn't ideal always when traveling as in NBT Evo it's automatically leveraging cellular signal. I even explored getting a separate SIM card to have it in the INAV device to avoid the constant connection setup. NBT EVO - We use my wifes' F15 '18 X5 a great deal for trips and getting around as a family of 4 and it has the EVO so it was easy to constantly compare the operating systems. EVO was much faster than NBT and I enjoyed the navigation between carplay and normal navigation as well as touchscreen. Installation took a little bit navigating the quadlock adapter and ended up with extra connections that weren't needed. Seller was quick to respond to all my Q's and had a few coding sessions to triage the PDC and backup camera issue. Overall - very happy and now feel like my tech setup is complete and more up to date for a seven year old car. |
08-04-2021, 09:24 PM | #20 | ||
22
Rep 64
Drives: 2014 BMW M5 Sakhir Orange CCB
2014 M5 (DCT) Sakhir Orange CCB aka BeastM5de
08-09-2021, 10:59 AM | #21 | |
360
Rep 430
Positives
Negatives:
Hope that helps Last edited by Beast27; 08-09-2021 at 11:19 AM.. Reason: . |
08-29-2021, 08:45 PM | #22 | |
152
Rep 397
Drives: F13 M6
