02-22-2024, 01:30 PM | #23 |
84
Rep 48
Drives: 08 135 6MT vert
As you might imagine based on the miles, it’s a DD. Spends all day at work outside, but is garaged at night and weekends (and the occasional snow events😉.
GoRomeo1008.50 |
03-30-2024, 05:27 PM | #24 | |
1009
Rep 3,898
Drives: 330i, 135i
03-31-2024, 12:31 PM | #26 |
1009
Rep 3,898
Drives: 330i, 135i
Wow that looks pretty intensive work for me 😂 Thabks for sharing. I will look into that. 👍
03-31-2024, 12:44 PM | #27 |
Nothin to see here
48
Rep 37
It doesn't have to be if you have just a small area that needs resealing. For me, the more I tried to crop out the old failed sealant, the more failed areas I found. I finally ended up removing all sealant to the point that the glass was loose in the roof so I could clean everything really well. I used the center (orange) glass clamp just to position the window and add a little upward force. Then a small flat hook at the driver's side top to bring that side down about 5mm or so. This got the glass in the perfect position. Then it was just seal, clamp, and trim off excess. Looks fine. I'll get a shot of the finished product. Really not terribly difficult and cost 60 bucks for everything. I had the large glass clamp from another project. If/when it fails I'll probably do one more round of the same before replacing the top. The rest of the top is in great condition and operates perfectly so I wanted to at least try this method. The tops been up and down about a dozen times since the repair and so far so good. The Florida summer will be the real test though.
GoRomeo1008.50 |
03-31-2024, 01:54 PM | #28 |
Nothin to see here
48
Rep 37
Not perfect by any means, but keeps the water out and looks OK. I figure if it holds for a year I'll be happy.
03-31-2024, 03:31 PM | #29 |
1009
Rep 3,898
Drives: 330i, 135i
Hellshalfacre48.00 |
03-31-2024, 03:34 PM | #30 |
1009
Rep 3,898
Drives: 330i, 135i
I wonder what I can use to press down the area. Maybe leave it overnight! I notice every time I open the top, that area takes a hit and it cracks opens up the cut 🥹😏
03-31-2024, 03:39 PM | #31 |
Nothin to see here
48
Rep 37
Thanks. It's called 3M Window Weld. There are some other similar products, but that one had the best reviews. It's available at most parts stores, Amazon etc. The clamps are on Amazon as well if you decide to go that route.
GoRomeo1008.50 |
03-31-2024, 07:13 PM | #32 |
1009
Rep 3,898
Drives: 330i, 135i
Yeah I am watching a video on YouTube. Mine its got a small opening about 2” long only so I think I can tackle this project soon. ☝️☺️.
04-15-2024, 08:47 PM | #33 | |
1009
Rep 3,898
Drives: 330i, 135i
The black glue Residue is supposed to come off using a blade once it dried out. |
04-15-2024, 08:53 PM | #34 |
Nothin to see here
48
Rep 37
Nice! I taped the glass adjacent to the bead and pulled it off after about an hour, then trimmed any excess off with a utility knife once it dried. My repair is still holding up well but it's only been a couple weeks. We did have some heavy rain and no issues so far. Hope yours comes out great.
GoRomeo1008.50 |
04-15-2024, 08:58 PM | #35 | |
1009
Rep 3,898
Drives: 330i, 135i
04-16-2024, 09:26 PM | #36 | |
1009
Rep 3,898
Drives: 330i, 135i
04-17-2024, 07:58 AM | #37 | |
Nothin to see here
48
Rep 37
GoRomeo1008.50 |
04-17-2024, 05:15 PM | #39 |
1009
Rep 3,898
Drives: 330i, 135i
I feel so bad for OP. We hijacked this thread. I hope he found a fix for his roof not opening issues. OP??? I mean its been more than 3 yrs. 🤔
04-19-2024, 04:41 PM | #40 |
Nothin to see here
48
Rep 37
