09-01-2016, 11:55 AM | #46 |
BMW Master Tech
587
Rep 850
Drives: E30, E36, E82, E90, F10, F80
Garage List 2015 Aston Martin V ... [0.00]
2010 Lamborghini LP ... [0.00] 1985 Alpina C2 2.7 [0.00] 2017 BMW M3 [0.00] 2008 BMW 128i [10.00] 2013 BMW 135is [0.00] 1992 BMW 325i [0.00] |
Hey now, it's better than seeing the typical "HEY LOOK! HERE'S AN M2 IN THIS COLOR!"
135is #502 of 586
BMW LED Performance Wheel | OEM FULL Carbon Fiber | E9X M3 Gauge Cluster | E9X Exterior Mirrors | E9X M3 Full Suspension | E9X M3 Diff | PT-CAN2 Enabled | Bilstiens | Michelin PSS's | NBT Navigation Retrofit with Touch Pad |
09-01-2016, 12:35 PM | #48 |
44407
Rep 7,227
Congrats Matticus91 and all others who contributed for making the front page. Perfect thread for us 1ADDICTS!
desertman1232215.50 snub-nose 2856.50 |
09-01-2016, 01:15 PM | #49 |
Rep 4
Why nothing on the 1M in this post?
Why is there nothing on the 1 Series M in this post?
Is there another post specifically like this for the 1M? Ty Williams aka NautiTy 2011 1M Valencia Orange Metallic (CA Lic Plate) BMW 1 M |
09-01-2016, 03:38 PM | #51 |
E82 Mudflap Ambassador
2216
Rep 2,219
Drives: '08 128i
Add some info! I know nothing about it - I drive the 128i so I added 128i info.
09-01-2016, 04:28 PM | #52 |
224
Rep 699
Great article, the most crucial things that was missed was the valve cover gasket (Normal for any bmw I6), the coils, and the LPFP. I've owned 4 n54s and have had all of what you mentioned as well as what I mentioned fail.
2021 M2C HS DCT
2007 Wedge 335i E92 FBO, Stage 2 LPFP,VTT STG 2+, VTT Shotgun E50 w/ Inlets MT-SOLD |
09-02-2016, 08:36 AM | #55 | |
1337
Rep 2,095
Drives: '11 135i M Sport
CHECK OUT THIS SICK M3/M4 BUILD! - Wheels and Carbon Bits.... Woohooo so original.
09-03-2016, 04:54 PM | #56 |
89
Rep 166
Guys,
What about the warranty extensions on N54s: Turbos: 8 years or 82K miles HPFP: 10 years or 120K miles BMW recall for the following: Fuel Injectors Battery cable/grounding strap Please correct me if I am off |
09-06-2016, 11:00 AM | #59 |
3483
Rep 3,722
Thanks all for the additional info, I'll be going through the posts later today and adding to the original thread
"Tobias" 2013 135i ///M-Sport 6MT • Pure Stage 1 • XDI 35 HPFP • 404whp/440wtq |
VRG_135838.50 desertman1232215.50 |
09-14-2016, 05:39 PM | #60 | |
289
Rep 556
But, for 3 months starting around January of that year they gave it away for half price Of interesting note the PPK2 lost a couple of horsepower going from the 2012 PPK2 option to the 2013 135is transformation. |
09-21-2016, 11:25 AM | #61 | |
828
Rep 2,232
Dackelone10615.50 |
09-21-2016, 02:27 PM | #62 | ||
44407
Rep 7,227
Dackelone10615.50 |
09-21-2016, 05:54 PM | #63 | |
European Editor
10616
Rep 22,992
I do remember someone dynoing the PE exhaust on a 135i when the cars first came out(N54)... and the PE lost 5hp. Now, I don't think there is a soul around who can tell you they can feel a 5hp loss on a 300 or 400 hp engine! Dack
09-22-2016, 07:47 PM | #64 | |
289
Rep 556
Dackelone10615.50 |
10-02-2016, 06:20 AM | #65 |
Rep 26
Fantastic informative thread...if I read it before I bought my 1er I would have known their was some money to be spent to get it perfect...113000km's
Replaced Injectors x 6 (solved idle wonder problem) Replaced Spark plugs (Must as part of misfire issue) Replaced 3 coils (This + plus plugs resolved the rough Idle / Misfire on idling) Thank Guys!!!
Owned: '74 2002tii, '87 325i shadowline, '98 M3 e36, '07 M3 e92
Current: 2010 135i M-Sport, 6MT, Cobb Intake, Cobb Charge pipe, Cobb Down pipe, BMS JB4, Powerflow Exhaust, Custom Juggernaut map, Coolboost Stage WMI . Waiting list : F87 M2, lbb, 6MT |
10-02-2016, 08:11 AM | #66 |
1545
Rep 3,071
Adding some info.
BMW uses a mileage based maintenance schedule. The car tracks it and you can check what due next using the scroll toggle button on the turn signal stalk - w/ the car on but not moving press BC on turn signal stalk, CHECK shows up, use toggle to scroll through when services are next due. Also menu there for personal settings (locks, turn signal 3x, etc.) Maintenance Schedule [not official BMW but recommended preventative maintenance - user preference] Oil change: 5-6k mi. Oil 0w-40 or 5w-40 (LL-01 BMW spec.) Air filter: 2 yrs / 24k mi. Brake fluid: 2 yrs / 24k mi. Power steering fluid: 2-3 yrs / 30k mi Coolant flush: 3 yrs / 36k mi. Cabin air filter: 4 yrs / 45k mi. Differential: 45-50k mi. Trans. flush/fill: 50-60k mi. Water pump, tstat, rad. cap: 5 yrs / 60k Spark plugs: ** n55 @ 60k; ** n54 or n55 w/ PPK @ 45k mi.; ** n52/n51 @ 80k? Fuel filter: 60k-80k (in fuel tank) Belts/hoses: as needed or 100k mi.
2011 135i w/ DCT | ZSP Sport Pkg | PPK | Ohlins R
Tags |
buyer, guid |
