05-02-2024, 02:50 AM | #1 |
New member
Rep 5
2008 X3 xDrive vibration on acceleration
Car vibrated violently under power at 35mph. Recon was done on driveshaft which solved the issue. I however now have a different vibration between 20 and 25mph which repeats at about 40 to 50mph - only on acceleration.
I balanced the tires with no improvement. The rear tires were 0.5 bar harder than the fronts after some towing, when I did a tire rotation. So I ended up with the front tires at 2.7 bar and the rears at 2.2 bar. The vibration was gone. As soon as I deflate the front tires back to 2.2 bar, so I have the same pressure on all 4 corners, the vibration comes back. Anyone with suggestions on what can be causing this? All 4 tires are regularly rotated and I fitted them about 15,000 miles ago. |
05-14-2024, 09:31 AM | #2 |
1047
Rep 1,564
That's an odd behaviour. What did you end up doing?
2023 BMW X5MC Tanzanite Blue II Metallic
2021 Jeep Grand Cherokee SRT Black 2006 Ford Mustang GT Convertible (show car) |
