04-20-2019, 09:13 PM | #1 |
33
Rep 170
Third Brake Light Cracking
The third brake light lens on my 2013 135i with only 34k on it has started to crack.
I took it into the dealer and asked them if this could be covered under my extended warranty. They were quick to deny my request. What do you guys think? To me, this is definitely not a wear and tear item and shouldn't exhibit cracks so soon. Or am I wrong? Thanks! |
04-20-2019, 10:05 PM | #2 | |
MSgt (ret)
567
Rep 2,116
Drives: VO 1M #739/740
Search will save u $$
04-20-2019, 10:20 PM | #3 |
851
Rep 2,276
This happens to all 1 series. I think your car is too old now to get a free replacement but do search for the bulletin (right here and via google). Mine was replaced once or twice under 1st owner. Mine is cracked now. Stayed that way for years but last year I put a bead of Gorilla glue on it. I also have a new one just in case this cracked one goes really bad.
This 3rd light is unique to the 1 series so eventually new supply will dry up. |
04-21-2019, 07:03 AM | #4 |
1545
Rep 3,071
It depends on what your warranty covers. If it's CPO and bumper to bumper then it might be covered. If it's aftermarket like mine it's probably not covered.
That said the light is pretty inexpensive on Amazon and/or FCP Euro's site. I replaced mine and it was pretty easy to do. $50 for the part and about 30 min of my time. Here is a thread. On page 2 or 3 there are links to a DIY by Dackel. Gd.Dam Third Brake Light https://www.1addicts.com/forums/show....php?t=1496808
2011 135i w/ DCT | ZSP Sport Pkg | PPK | Ohlins R
04-21-2019, 05:16 PM | #6 |
2183
Rep 2,806
I was thinking about buying one put in my spares for when mine breaks. Any guidance on whether BMW genuine or aftermarket like Dorman is the way to go? There is about 2x price difference for the BMW genuine.
E82 / BMWP Springs / Koni Yellows / M front control arms / Adjustable front endlinks / M rear guide rods / Whiteline Poly RSFB
04-21-2019, 09:22 PM | #8 |
2183
Rep 2,806
I found it on ebay and at Parts Geek.
04-21-2019, 10:32 PM | #9 |
1545
Rep 3,071
It's available on Amazonia and other sites. You might even be able to order it at Autozone...
04-22-2019, 09:47 AM | #12 |
Rep 20
Can somebody tell me the size of the 3rd brake light lamp nut? My replacement lamp is oem from ECS and the threading of the post is different from the original. Thanks!
04-24-2019, 12:31 PM | #13 |
851
Rep 2,276
05-02-2019, 06:18 PM | #14 |
23
Rep 110
To improve longevity of the new light, don't crank the nuts all the way down and fully compress the spring. Just compress the spring a little bit so that the perimeter foam creates a seal. I think over torquing the nuts is a major factor in cracking this weak design.
05-02-2019, 08:11 PM | #15 |
33
Rep 170
Can someone confirm if installing a new lens requires new nuts? Or can you just reuse the original nuts? I recall someone mentioning that the threading is different.
05-21-2019, 10:19 PM | #17 |
33
Rep 170
Updating this thread.
Bit the bullet and bought a factory lens. Also bought new springs (because most of the DIY's mention that) BUT my springs were already updated. Not sure if it's because my car is a 2013 (late production) or because it's been changed before. What was even more interesting is that the lens fit perfectly. Others were mentioning that you had to modify the lens to get it to fit. I guess I lucked out with my car so no mods necessary. Pretty straight forward and took very little time. No gotcha's at all. One interesting observation was that the nuts on the original lens were really tight! To a point where I unscrewed the the mount out of the light. I have no idea why anyone would want to tighten it that much. In fact, I could finger tighten the nuts all the way down to the base and then I back off a bit hoping it'll prevent future cracking. Now I just hope it won't leak. I did clean the opening of any residual dirt and dust. Thanks again for all the advice and comments. |
09-27-2020, 01:04 PM | #19 |
12
Rep 25
Anyone figure out a way to prevent or at least prolong this issue? I thought about hitting it with a heat gun prior to install to help it mold to shape.I'm replacing mine after 16 months. Thinking Doorman or China next time around.
09-27-2020, 06:27 PM | #20 | |
BMW Owner Since 1971
2272
Rep 1,417
Drives: 1964 700 Sport Cabriolet
This is what I used which will fit both versions, it is inexpensive, requires no modifications for either version, and cannot be distinguished from the OE part: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 You can see my post on the thread here. I also replaced the springs, but the nuts worked on the new light perfectly |
09-27-2020, 08:32 PM | #21 |
33
Rep 170
I did notice that the nuts on my original lens were really tight upon removal. So on the install I just snugged the nuts down gently and so far no problems.
09-27-2020, 09:57 PM | #22 | ||
Commander ;)
185
Rep 115
https://www.newtis.info/tisv2/a/en/e...lights/PoMpSk4
2009 N54 1er Cabrio
2021 C8 Stingray Z51 2022 Audi Q3 |
