08-06-2018, 02:22 PM | #1 |
20
Rep 43
Wheel cleaning tips?
Any tips for cleaning the barrel portion of the wheel. I use wheel cleaner, dedicated wheel mitt and a long detailing wheel brush and it gets them fairly clean, but i still end up wiping out the barrel with 2 damp rags to get it all out. Even after that, I still see spots of brake dust/rust colored water coming off the rotor.
Photo of my used towel |
08-06-2018, 02:57 PM | #3 |
Restless
1335
Rep 1,031
I would also consider getting low dust brake pads...I didn't do that when I had my M3 but have heard it is a game changer. I did ceramic coat my rims and that helped with the cleaning process quite a bit.
08-06-2018, 04:18 PM | #5 | |
20
Rep 43
08-06-2018, 06:04 PM | #8 | |||
2121
Rep 2,014
This is personally what I use - https://www.esotericcarcare.com/gyeon-q2m-iron/ This is another good brand to consider, Sonax, whom more people are probably aware of - https://www.esotericcarcare.com/sona...-cleaner-plus/ I also use this wheel brush - https://www.esotericcarcare.com/esoteric-wheel-brush/ First, don't ever wash the wheels after driving, the wheels and rotors have to be cool enough to touch with your hand. Rinse them, spray on the wheel cleaner and let sit for 2 minutes (DO NOT LET IT DRY). Once the 2 minutes are passed, agitate with the wheel brush and rinse off the wheel once done, it should be spotless (certainly with a pressure washer). Quote:
Using Acidic wheel cleaners isn't the answer, that's pure nonsense and terrible advice that is only going to lead to more frustration. |
louielouie550.50 derekh2520.00 |
08-06-2018, 06:40 PM | #9 | |
581
Rep 1,055
HRE_Wheels2121.00 |
08-07-2018, 11:12 AM | #11 |
295
Rep 546
Remove the wheels for this first time
clean them with sonax or gyeon, or ironx once clean, wipe with IPA and then coat them remount, torque to factory specs drive it or have a shop do it for you, price will vary on total time needed and coating product used. There are cheap products that you will have to re-apply every year or two, or there are stronger coatings that will last longer and work better |
08-07-2018, 11:18 AM | #12 |
20
Rep 43
I think I figured out the issue. After washing the wheel, rusty/dirty water is accumulating in little spots on the rotor. So when I drive the car, the rotor spins and splashs the dirty water all over the barrel. I dont see anyway to avoid this unfortunately.[IMG]undefined[/IMG]
08-07-2018, 01:42 PM | #14 | |
15
Rep 30
08-07-2018, 01:44 PM | #15 | |
2121
Rep 2,014
Comes in a kit with applicators and all the necessary accessories to get the job done. And it comes with a bottle of the wheel cleaner I use so you can test it out too. Here's details on this one: |
08-07-2018, 02:04 PM | #16 | ||
20
Rep 43
Good call, will try that next time |
08-07-2018, 02:42 PM | #17 |
4955
Rep 3,825
If you have black 437m, it's an ongoing battle. My wheels are coated, I clean and dry with a leaf blower and wipe the rotor surface down with a towel right away to prevent rust from forming. Unfortunately, you can't physically wipe down the back side of the rotor, so it creates fine dust that gets on the rims immediately after. I usually take it for a quick drive then use compressed air on the rims.
derekh2520.00 |
08-12-2018, 09:10 PM | #19 |
2937
Rep 3,286
Drives: 2002 M5;2007 M Coupe;2020 M2C
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel 2007 E86 Z4M Coupe Silver Gray/Black 2021 Kia Telluride (hauler) |
08-12-2018, 10:01 PM | #20 |
@ste4lthedF82
882
Rep 1,498
Drives: 2016 M4 SSII
Get POWERSTOP pads... GAME CHANGER!!!
2016 Satin SSII M4 (Instagram: @Ste4lthedF82)
see my featured mods below... http://f80.bimmerpost.com/forums/sho....php?t=1197842 |
08-17-2018, 05:13 PM | #21 |
5394
Rep 3,738
Drives: 2016 M4 DCT Tanzanite/Amaro
I have two of these from Griots Garage, they reach right between the spokes and clear the rotors, clean the inside of the wheel in a couple minutes.
derekh2520.00 |
08-17-2018, 11:12 PM | #22 |
558
Rep 909
I didn't find the sprays to be worth using. I used a whole bottle of Sonax and still have to clean my wheels with the trusty bucket of water and brush.
I actually found the best way to clean my wheels is to use a bucket of soft water along with this cheap duster that I got from Target [IMG]https://scontent-dfw5-1.cdninstagram...96398336_n.jpg[/IMG] After cleaning, I leave the car parked for a while to ensure everything dries before driving and the wheels stay clean for a while. If you drive while the wheels and rotors are wet then all that brown rusty water will be all over the place. Example of the results
derekh2520.00 The Spectacle0.00 |
