01-30-2019, 09:46 PM | #45 |
2018 M3CS Pittsburgh
602
Rep 758
Drives: 2016 528 , 2018 M3CS 2020 M8
Full stock..and car was not pass break-in..no launch control..and full power was not there..we will be running again..but it's to cold right now..his car is tuned..and catless down pipes..but from a dig it was close..also he just did a vid where he ran against a regular. M3 and that car was left in the dust like it was standing still..so i think it was a pretty good run.
02-18-2019, 09:02 AM | #47 |
1511
Rep 2,136
Drives: 2024 M2, 2022 GT3, 2022 SF90
2024 BMW M2, 2022 Porsche 992 GT3, 2022 Ferrari SF90, 2023 BMW M1000R comp pkg
02-18-2019, 11:31 PM | #48 |
1511
Rep 2,136
just an iphone pic after waxing it again with the new GTS hood
Justin@autocouture202.00 |
02-19-2019, 01:12 AM | #50 |
1511
Rep 2,136
No, that is the lighting inside the garage
02-24-2019, 11:29 AM | #51 |
1511
Rep 2,136
Here an outside pic (again just an iphone pic)
03-02-2019, 06:26 PM | #52 |
719
Rep 785
Drives: F80 M3
Dr. Beasley’s matte coating gave me way better sheen results on my frozen white car than the nano did.
03-07-2019, 11:01 PM | #53 |
1511
Rep 2,136
mmm...not sure I agree with that statement, i have used DB matte coating, it doesn't give you a real coating as the BMW nano wax but if you like it more good for you
03-11-2019, 12:12 PM | #54 |
719
Rep 785
Drives: F80 M3
06-11-2019, 03:00 AM | #55 | ||
1923
Rep 3,908
I finally applied it yesterday (the Swissvax Opaq done in November was still partially on - it seems to hold very well on the paintwork, but not so well on the protective film). So, first impressions: -You can definitely tell that the BMW Matte Nano Wax and the Swissvax Opaque are not the same product (as someone suggested may be the case) - Visually I could/can not tell any difference between the effect of the Swissvax Opaque and BMW Matte Nano waxes. I suspect it could be very much dependent on the colour (you have a more contrasting black underneath, I have silver metallic). I specifically looked under different angles at 2 adjacent panels, one still with the Swissvax (or what was left of it, if anything, after cleaning it with Swissvax Pre-cleaner Opaque), one freshly done with BMW Matte Nano Wax and could not tell any difference. My GF couldn't either - The BMW wax smells really good (not that the Swissvax smells bad) - The BMW wax is definitely more economical. I did the entire car with a fraction of the box, whereas I needed bigger quantity of the Swissvax previously for the same job! The BMW wax comes in a bigger pack as well. So assuming at least similar performance, the BMW one should be better value for money! Obviously I cannot yet report anything about the effect of the wax and its durability, as it was applied just yesterday, but I will, after some time. I am really hoping it performs at least as good as the Swissvax, which lasts easily for 6 months in my environment. Thank you again for the recommendation! I use the opportunity to also ask some questions: - Do you remove the old wax every time before renewing it and if yes – what do you use to do so? - Do you use anything to maintain in in the meantime?
"Large increases in cost with questionable increases in performance can be tolerated only in cars and women."
06-14-2019, 10:53 AM | #56 |
38
Rep 146
This is very informative. Getting a frozen black M4 so its good to see the information, since this is my first frozen car. I have a ton of questions but will research first.
06-15-2019, 01:44 PM | #57 | |
1511
Rep 2,136
No,i dont remove the old wax when applying a new coat, basically the old coat is gone when i apply the new one, you can tell it by touching the surface, it is not longer as smooth as when you applied the wax, i only use Dr Beasleys matte car shampoo in between applications, nothing else, i wash my car every weekend
06-15-2019, 04:19 PM | #58 |
1923
Rep 3,908
Ow, that could explain the relatively short durability of the wax you mentioned earlier. I suspect every wash, no matter how gentle, shortens it's life.
I endeavour to wash as rear as possible, but also before things get messy. I give it a nice shower with just water in-between, as required. I will gladly share my experience with the wax when I collect some It might very well be a placebo, but it could be changing the look a bit after all, depending on the light. It looked very "sleek" in a satin kind of way the other day... Since you mentioned shampoo - have you tried different ones? How did you end up with Dr. B? I have so far only tried Swissvax Opaque, which I am not impressed with at all (too little to no foam, non-slippery, IMO increased risk of scratches) and Chemical Guys Meticulous, which I am very happy with and would recommend. Nice foaming, nicely slipping, good cleaning effect and nice smell of bubble-gum . Just about to buy a big pack of it as my small one is getting low.
06-15-2019, 05:16 PM | #59 | |
852
Rep 1,215
06-17-2019, 08:47 PM | #60 | |
1511
Rep 2,136
Yes i use DB matte body wash as well, i wash it every week
06-17-2019, 08:51 PM | #61 | |
1511
Rep 2,136
I ended up using DB body wash because of what you just mentioned, it makes a good foam, i used to buy swissvax and hated that there was no foam, it felt like i was washing it with plain water so decided to buy DB and i am very happy with it so havent looked for other options
06-18-2019, 04:26 AM | #62 |
1923
Rep 3,908
Ditto!
10-11-2019, 12:07 PM | #63 |
1923
Rep 3,908
edu09
4 months since I applied the BMW Nano Wax (the car has admittedly not been driven for a bit over 1 month out of that). I will soon provide my impression, I am sure it would help others. The reason for writing however is that I remembered you wrote you have used Dr. Beasley's products (for matte paint). Have you specifically used Dr. Beasley`s Matte Paint Sealant? Any thoughts about it? Any of the Dr. Beasley`s Matte products that are worth considering?
10-15-2019, 10:47 PM | #64 | |
1511
Rep 2,136
I use the final finish to clean hard to remove stains, not exactly the use that this product is for but I found it is very good for this purpose, even better results than the paint cleanser
10-16-2019, 02:46 AM | #65 |
1923
Rep 3,908
Thanks. So you do use the Sealant and the BMW nano-wax on top?
I was under the impression you are not too happy with the shine of the sealant? And how do you even do that - you do a complete IPA wipe down every 3 months!? I contacted DB as the Sealant is not presented on their website. There is a Dr. Beasley`s Matte Paint Coating, advertised with 1 to 3 years durability! https://www.drbeasleys.com/matte-paint-coating.html The initial response was a bit ambiguous, that they have renamed the product to better reflect its nature and the sealant is no longer sold (although some distributors have leftovers on stock).... When I asked how come the same product (if identical) now has up to 3 years of claimed durability, whilst previously it had up to 9 months, I was told it is not quite the same, it has been improved... I found the Sealant 50% off, but wondering if it is worth it, based on the above and also based on the shine, which is quite obvious even for the coating (how could they be happy with this results): https://www.autogeekonline.net/forum...-phillips.html
10-16-2019, 11:37 AM | #66 |
1397
Rep 3,152
Nice Eduardo!
