Catless downpipes but keep orignal secondary cats
12-09-2012, 02:11 PM | #1 |
King of the road
18
Rep 202
Hey guys just wondering if anyone one is running catless downpipes but still have there secondary cats in place? would I be able to pass an emissions test with a setup like this ? also would the secondaries be sufficient to eliminate any smell? Ive looked this up already online cant find any sufficient information on this topic ...
Jet Black / Pre lci E90 / 6mt / FBO /
12-09-2012, 04:11 PM | #3 | |
Chartered Accountant
66
Rep 970
12-09-2012, 08:33 PM | #4 |
7
Rep 79
That's what I'm running too, I keep my car in the garage and there was definitely a noticeable smell after put the down pipes on but nothing I can't handle. I don't mind. And I love the added sound.
12-09-2012, 08:44 PM | #5 |
80
Rep 2,396
Drives: '08 E90 335i
Catless DPs + Stock DP-Back Exhasut -- Because you removed the primary cats (Which are the only ones that matter), you will still need a DP Fix to Pass OBD Port Testing. You probably won't pass a sniffer test with just the Secondary Cats in
12-10-2012, 02:42 AM | #6 |
daygo.
Rep 421
good information so only get the dp fix for smog testing?!? i dont want any limp modes or anything like that.
REMUS/AR CATLESS/LS3 SPECTRUM/ COBB/CYBA AIR SCOOPS/SONIC TUNING CARBON FIBER CSL TRUNK
12-10-2012, 10:12 AM | #7 |
80
Rep 2,396
Get a tune (COBB, JB4 or PROcede) so you can maximize your gains & not have to drive around with a CEL. The DP Fix will only let you pass an OBD Test by simulating a "Readyness" status
12-10-2012, 10:36 AM | #8 |
69
Rep 868
I have dps and no sec cats minimal smell but I do see a bit more smoke..... I thought it was condensation but after a wot the other day I saw quite a bit of smoke.
Turbos might be going
JB4 G5 ISO , AR DP's, DO Meth kit Trunk Mount, ETS 5" Intercooler, M6 Rims, ER Charge Pipe, Fordged DV's, MMp relocated inlets, Ebay 4" chrome Tips, Lux Angel Eyes **********11.910 @ 117.09***1.851 60'********** |
12-10-2012, 11:03 AM | #9 |
King of the road
18
Rep 202
any other way to tell if the turbos are going besides smoke ? ive always wondered about what condition mine were in ... but i have stock downpipes and secondaries so the smoke probably wouldn't show ?
12-10-2012, 11:46 AM | #10 | |
62
Rep 2,013
12-10-2012, 11:50 AM | #11 |
King of the road
18
Rep 202
guess mine are behaving then, oil consumpition is in check and havent heard any sirens recently other then the cops haha
12-10-2012, 12:33 PM | #12 |
210
Rep 1,161
I have never seen the catless dp/catted tail section in the shop. I'm really curious as to the smell level compared to fully catless. Anyone done both? Comments?
12-10-2012, 12:45 PM | #13 |
25
Rep 699
Drives: e90 335i f30 330i g20 m340i
I've got catless DPs with stock midpipes and stock catback. On a true cold start in my garage (with the garage door open obviously ) I smell gas easily, because the secondaries haven't warmed up yet. Once they're warm, they reduce the gas smell significantly- you can't smell it from inside the car unless windows are all the way down and you're stopped at a light. Even then I rarely ever notice the smell and it is extremely faint.
12-10-2012, 03:05 PM | #14 |
80
Rep 2,396
12-10-2012, 03:29 PM | #15 |
196
Rep 6,136
12-10-2012, 04:05 PM | #16 |
178
Rep 6,631
That's not necessarily true. If you're under shooting target it could simply mean the turbos can't give you what you're targeting. More common north of 6000 rpm.
E90 LCI N54 6AT
12-10-2012, 04:06 PM | #17 |
178
Rep 6,631
+1 although the turbos may not last forever, siren does not mean catastrophic failure is coming soon.
E90 LCI N54 6AT
12-10-2012, 04:56 PM | #18 |
85
Rep 2,438
The main problem is that secondary cats will clog up. Because primary cats filtering and after they becoming worm/hot burning all kind of sh*t. If you will go just with secondary cats they will not last long...
12-11-2012, 11:13 AM | #19 |
Freude am fahren
71
Rep 1,968
Drives: E90 N54
it will tell you SOMETHING'S wrong, but might have absolutely nothing to do with the snails though. I mean if you're maxing fuel trims then you might not reach your boost targets. I guess you can look at WGDC, right?
Cobb E40 PROtune by Jake@PTF/RR catless DPs/aFe DCI/ETS 5" FMIC/ER CP/Forge DVs/Alpina B3 TCU flash/BMW Perf. Exhaust./BMW Performance Style 313s/M-Tech Rear
12-11-2012, 12:38 PM | #20 |
3442
Rep 79,211
There is a slight difference in smell from full catless to secondary cats still installed. When I had just catless downpipes and I still had secondary cats the smell was barely noticeable but still apparent compared to fully catted.
Fully catless to me is quite obnoxious. I've had a few cars with full catless modifications and I dont think I will ever go back to it. I dont miss pulling up to lights and catching a wiff of fumes. As far as turbo's going out, smoke out the back is a common culprit, elevated Wastegate duty cycles are another, but one would need to ensure their are no boost leaks before blaming the turbo's. Siren noises CAN be a common characteristic on this car. It's a tiny fan blade that spin's 10's of thousands of RPM's, it's going to make some noises. Obnoxious sire noises at light cruising when the car is full warmed up, along with elevated duty cycles to reach boost target and or oil consumption or smoke out the back may be a sign of turbo failure. If your car is running like a champ, don't worry. If you have some smoke out the back it does not necessarily mean your turbo's are on the way out either. Every scenario does not have an A + B = C One must encompass many details before singling out that one symptom = one failure every time. |
12-11-2012, 03:58 PM | #21 | |
2097
Rep 43,350
Your best bet is to start datalogging. If you don't know how to interpret the logs, post em here & we'll be happy to point you in the right direction. |
12-11-2012, 10:05 PM | #22 |
daygo.
Rep 421
Tags |
catless, downpipe, exhuast, n54 |
