12-06-2021, 12:21 PM | #68 |
273
Rep 659
Minimum vs. Recommended. If you want to put a 225 tire, you certainly don't need an 8.5" wheel, so he could have saved a couple of bucks.
In my head, Tire Rack should have said something like this: Minimum: 225 Recommended: 235 or 245 Maximum: 255 But anyway, I'm just sharing my thoughts.
2023 X3 m40i Brooklyn Grey
2017 X1 sDrive M-Sport 2.0i (repro) - SOLD |
Reefy38.00 |
12-16-2021, 06:04 PM | #69 |
273
Rep 659
12-17-2021, 02:33 PM | #71 | |
273
Rep 659
One final comment, keep in mind that wider tires and bigger wheels will negatively impact the acceleration. That was one of the downsides with mine, even considering I have an ECU tune (270hp+). Don't get me wrong, the good things overpass the bad things. But it's something to consider.
Reefy38.00 |
11-24-2023, 03:11 PM | #73 |
66
Rep 122
Drives: 2017 X1 xDrive28i
12-18-2023, 11:10 AM | #76 |
273
Rep 659
Looking good!
But it definitely needs lowering springs =). Did you buy the Bilstein B12 combo?
12-18-2023, 12:02 PM | #77 |
66
Rep 122
04-11-2024, 04:11 AM | #81 |
194
Rep 648
Drives: 2018 F48 X1 xDrive 18D
How did you put these on? AFAIK 611m is only released as 5x120 bolt pattern and our F48 have 5x112
04-16-2024, 03:11 PM | #82 | |
Rep 57
I had a question, I wanted to paint the ferric grey part of my 566 style wheels (black in color) to make them stand out more easily but Im not sure what kind of paint can I use. Something that is not a spray-can as I only want to highlight/cover the ferric grey parts not the entire wheel (check attachment - photoshopped for end state look) Can the likes of Rustoleum outdoor paint help? do I need to sand, primer, paint and apply clear coat again? I wanted something like a quick fix not an elaborate process |
04-16-2024, 08:06 PM | #83 | |
273
Rep 659
04-17-2024, 08:09 AM | #84 | |
194
Rep 648
04-18-2024, 10:50 AM | #85 |
Rep 57
I will avoid pressure washing. How long would it last? Also since I want the plastidip to cover only the ferric grey portions whats the best way to do that? Assuming plastic dip comes in spray mode only. It's going to be very difficult to mask all the diamond cut / shining silver piece only
04-18-2024, 12:22 PM | #86 | |
194
Rep 648
04-18-2024, 12:43 PM | #87 | |
273
Rep 659
PlastiDip comes in a spray. Masking tape plus some paper will be good enough. You can find instructions on how to apply it on YouTube. You will need to make several passes until it covers completely. If you want it to be glossy, you then have to apply a PlastiDip clear coat.
05-07-2024, 09:18 AM | #88 |
Rep 57
Has anyone put 816m wheels on the pre-lci xline version x1. I’m getting a good deal but not sure how it would look as all the images I see are on the msport version only (similar to attached image).
It would be great if someone can photoshop to see how it would look. I have a 2019 Mediterranean blue xline x1 |
