BMW X5
      01-03-2023, 07:35 PM   #45
dentprotony@gmail.com
417
Drives: 2018 f85
OP how are your brakes holding up ? What are you running for rears ?
      01-03-2023, 08:33 PM   #46
417
Drives: 2018 f85
OP sorry to steal your thread, i am wondering if someone would be interested in this upgrade, i spent 3 months getting the brackets for these calipers ready. These kits work with f90 rotors, and come with powerstop low dust no noise pads. Figured id ask on here , i made a thread with 0 views. Again OP sorry to steal your post for a second
      01-11-2023, 10:34 PM   #47
Longboarder
Longboarder's Avatar
3437
Drives: 2016 BMW i8
Curious about the remarks here about the X5M brakes and the full MSport brakes on the G05. I have both ('21 X5M and '22 G05 MSport 40i with red caliper Msport brakes) and while they may look the same, the real M brakes are sooo much better on initial bite, dissipation of heat and prevention of fade. I have to be careful when I hop back and forth in these because braking distance is sooo much further in the G05 Msport, and they will fade very quickly. The real M brakes are insane and you can slam/threshold brake over and over and over and they will not fade, but your brain might fade from the G's and your eyeballs may pop out of their sockets.
Try that on the G05 Msport brakes and you will think the pads are made of chocolate. The Msport brakes seem to be for looks only and I would never drive them aggressively for any period of time.
So for anyone contemplating the upgrade for the G05, I can assure you the performance improvement is massive.
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S
1979 Porsche 911 Turbo (930)
a couple others
IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w
      02-04-2023, 11:49 AM   #48
DKNICK
66
Drives: 2019 GO5 X40i
These will fit on a G05?
      02-05-2023, 07:24 AM   #49
417
Drives: 2018 f85
Correct, these are f90 brakes with custom brackets that are made to fit a standard x5. If interested please email me, i am looking for someone to final test fit these, thanks
      06-06-2023, 05:37 PM   #50
blau3er
1160
Drives: F31 30d
Just confirmation that the F95 X5M calipers do indeed bolt right up onto the G20 (and rest of the G series range such as G30 G11 G15 G01 etc....)
      06-13-2023, 08:27 AM   #51
417
Drives: 2018 f85
Will the brake rotor install as well or caliper only ?
      06-13-2023, 09:14 AM   #52
blau3er
1160
Drives: F31 30d
Yes, as per the pics. F95 disc and caliper.
Bolt on fitment. The only thing being that the disc retaining screw hole does not line up with the hole on the non-M hub.
Wouldn’t be an issue when bolted down though!
      02-14-2024, 11:36 AM   #53
rantarM3
205
Drives: E90 M3
After reading this thread it seemed like this would be an awesome upgrade for my X5. But after further investigation, I've determined that there is an additional difference between the X5M and non-M G05, that swayed me away from this alternative.
The hub on the M vehicles have steel studs (3 in the case of the X5M) protruding from the hub face. The non-M G05 does not have these. Presumably, the M models have these because of greater braking forces, and the engineers must have determined that they were necessary.
So on the non-M G05 the disk stays in place through clamping force and 5 lug bolts, whereas the X5M additionally has three steel studs. I posted this to add information to the thread for those contemplating this mod.
      02-14-2024, 03:21 PM   #54
blau3er
1160
Drives: F31 30d
That would be a non-issue. All recent M cars from F gen onwards have the dowel pins you refer to.
For example, I am running 400mm M brakes on a F31 without the dowels on the hubs and never once had any problem. There are high power M-lite cars, such as M760i, X5 M50i etc running big power on heavy cars that use hubs without the dowels.
      02-14-2024, 03:22 PM   #55
blau3er
1160
Drives: F31 30d
Also, as a side note.
I have previously posted that the F95 X5M fronts are bolt on fitment to pretty much all G series models.
I have now also verified that the 380mm rear set up of F95 X5M is bolt on to G2x rear hubs.
      02-14-2024, 04:58 PM   #56
rantarM3
205
Drives: E90 M3
IIRC, my E90 M3 has the dowel pins; I'd have to pull a wheel off to confirm (not that it matters).
I agree that there probably isn't any issue as it would be very surprising to see five lug bolts shear because of the missing dowels.
My X5 has the X-line brakes and I was looking at the M Performance BBK (34-11-2-458-883), which has the 395 rotors. From what I can tell, the calipers are larger and have larger pistons as well. But the X5M retrofit is another option, but only if it costs less in the end.
We'll see.
      02-15-2024, 03:27 PM   #57
rantarM3
205
Drives: E90 M3
It occurred to me that the front rotors on the M Performance BBK are the same size as the X5M rotors being used on these conversions. Other than the M Performance rotors being single-piece (and heavier because of that), can anyone think a reason why pairing them with the X5M calipers and pads would be a bad idea?
      02-15-2024, 05:44 PM   #58
blau3er
1160
Drives: F31 30d
Yes, the M Perf BBK is a total waste of money on a X5 that is already optioned with the M Sport braking system.
I know you mentioned that your car does not have the M Sport brakes, but as you have posted the calipers and disc sizes are identical between M Sport and M Perf.
I have blank 395mm rotors here and I am happy to take photos and show you those mounted with F95 6 piston calipers.
There would be no issue with using that combo and you would have the set screw line up without any issue that way. If you wanted you could even go with the M Perf 395mm dimpled and slotted rotors.
      02-18-2024, 10:45 AM   #59
417
Drives: 2018 f85
Is there any way you could measure the weight of these 395 blank rotors ? I am curious to compare the weight of an x5m rotor vs a blank disk. Thanks
      02-19-2024, 01:43 PM   #60
rantarM3
205
Drives: E90 M3
I was starting to source parts for this upgrade but found out that the M Performance brake kit requires coding. If you already had the Sport brakes, there should be no coding required. But because I have the tiny basic brakes, I would need coding and doubt any dealer would code my car with the X5M brakes on there. And with the LCI having closed the door to coding, it's not something I can get someone outside a dealership to do. Quite sad, indeed.
      02-22-2024, 05:11 PM   #61
rantarM3
205
Drives: E90 M3
Just posting some info on rotor sizes between various configurations (pulled from AIR with valid VINs).
Basic LCI brakes have 348X36 front and 345X24 rear discs.
M Sport brakes have 374X36 front and 345X24 rear discs.
M Performance brakes have 395X36 front and 398X28 rear discs (dimpled).
M60i Sport brakes have 395X36 front and 370X24 rear discs.
X5M brakes have 395X36 front and 380X24 rear discs (drilled).
Discs on all but the X5M are fixed bimetal, while the X5M has a floating-type disc.
      02-29-2024, 08:34 PM   #62
417
Drives: 2018 f85
Heres an install video for one of my customers i done a couple weeks ago
https://youtu.be/aV3EebA8SRc?si=RLWpXzRIVXeJKJnr
      03-01-2024, 01:30 AM   #63
blau3er
1160
Drives: F31 30d
Not totally accurate as M Sport brakes on G05 are 395mm.
      03-06-2024, 12:05 PM   #64
rantarM3
205
Drives: E90 M3
I used a VIN (5UX13EU06R9V60728) from an M Sport 40i with the sport brakes in TIS and it provided the following part numbers for the front rotors: 34-11-6-875-283 and 34-11-875-284.
Per TIS, these are 374X36.
blau3er1160.00
      03-06-2024, 04:55 PM   #65
blau3er
1160
Drives: F31 30d
Sounds like the US gets a bum deal then, as all EU cars with the M Sport brakes (regardless of engine variant) get the 395mm up front!
EDIT: upon further investigation, this appears to be an LCI thing. It would appear that BMW have possibly downgraded the LCI to only use 374mm on certain engine variants (when optioned with the M Sport brakes), whereas pre-LCI got 395mm regardless of engine variation. Even the 25d (in pre-LCI form) got 395mm!
Interesting find!
      03-07-2024, 09:28 AM   #66
rantarM3
205
Drives: E90 M3
Interesting find!
I guess they had to find the money for the hybrid powertrain somewhere! I could see BMW doing something like that to reduce costs on some components to make up for additional costs on others.
xbimmers
