      05-23-2018, 11:27 PM   #23
tree233
15
Drives: 2006 130i hotrod
Originally Posted by fe1rx View Post
Clearly the M3 tension arm is more concerned with wheel control than NVH.
Hi fe1rx,
Thank you for the research!
Can you please confirm that the OE & M3 tension arms are the same geometry, and the only difference being the bushing?
Also do you know how much wider the M3 control arm is? I'm keen to know how much the front track will increase by.
Cheers!
      11-08-2023, 04:19 PM   #24
fe1rx
1425
Drives: 135i, 328i, Cayman S
Why BMW struts are so hard to disassemble
Anyone who has tried to disassemble an OE front strut has cursed the fact that the shaft retracts itself back into the strut body as you compress the spring. The net result is that it is hard to get all spring tension off the top hat, and thus very hard to get the strut and spring back together again.
The reason for this is that OE struts have a rebound spring internally that prevents the strut from fully extending. Aftermarket struts, as a rule don't have this feature so are easier to assemble. The attached image is from a 3-series strut, but the design appears to be typical. In the center of the picture is the rod guide and seal with the cylinder cut off. The cylinder appears in the right side of the picture. It is much smaller than the outer body of the strut because the strut is a twin-tube design.
Appreciate 2
asbrr544.50
Brian_10.50
      02-20-2024, 07:05 AM   #25
rackhenry
rackhenry's Avatar
12
Drives: BMW 128, Porsche Cayman
Great writeup and analysis. The data is really helping with my track build.
2011 128i
2011 Cayman
2007 Cayman S -Sold - no regrets
2007 Exige - Sold - Double Dang it!!
1990 M3 - Sold - Dang it!
1addicts
