Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > How to / can you fit lci e90 kidneys on pre-lci
      01-28-2010, 11:55 PM   #1
irq5
irq5's Avatar
South Africa
23
Drives: F30 328i, M-Sport, 8AT
2013 BMW 328i  [0.00]
Question How to / can you fit lci e90 kidneys on pre-lci
Hi All
Have searched and haven't found a definitive answer:
I just want to know if it would be possible to fit the new lci kidney grills on my pre-lci e90?
I would imagine that you'd need to do some modification on the hood to remove the mustache mounts. Has anyone done this yet?
And then lastly, are the mounts for the new lci grill the same as the mounts for the pre-lci?
Thanks!
      01-29-2010, 12:08 AM   #2
JayKay335i
Egypt
189
Drives: ///M323 DCT
Sure. Retrofit a LCI bumper and hood.
      01-29-2010, 12:12 AM   #3
irq5
irq5's Avatar
South Africa
23
Can you retrofit without changing the bumper though?
      01-29-2010, 12:23 AM   #4
evotwelve
72
Drives: AW E90
from what i have seen around, no you can't without wasted body shop time and money. easiest way is to do a lci hood and bumper.
      01-29-2010, 12:28 AM   #5
irq5
irq5's Avatar
South Africa
23
Originally Posted by evotwelve View Post
from what i have seen around, no you can't without wasted some body shop time and money. easiest way is to do a lci hood and bumper.
Well, I imagine modifying the hood shouldn't be too much hassle, right? As long as the kidneys fit my current m-sport / m-tech bumper, I don't mind spending the money at the body shop...
      01-29-2010, 02:56 PM   #6
SV Concepts III
375
Drives: BMW Duh
You will need to replace the bumper and modify the hood to make it work. The hood modification would require cutting the metal, you would be better off purchasing an LCI hood and doing a complete conversion.
      02-01-2010, 12:24 AM   #7
irq5
irq5's Avatar
South Africa
23
Ok - guess I'm not going to get away with this the easy way. I'll have to see how much my bonus in March allows and decide whether I can afford it or not...
      08-17-2010, 10:58 AM   #8
moto_noob
Drives: '06 e90 325i
so, if you get the lci hood and kidney grills, you just need to modify the front bumper at the shop correct?
      08-17-2010, 11:10 AM   #9
MassBimmer
MassBimmer's Avatar
No_Country
309
Drives: 2023 i4 M50
2009 BMW  [9.24]
No, you need the LCI bumper
      08-17-2010, 03:03 PM   #10
JDLM
JDLM's Avatar
73
Drives: 2009 335i Sedan
They changed it enough that new parts are needed
      08-21-2022, 08:21 PM   #11
san40k
21
Drives: 2008 E90 335i N54 6MT
If you're handy and/or adventurous, you can fit LCI kidney grills to pre-LCI hood and bumper.
You will need to bend pre-LCI hood under kidney strips (unpainted/hidden section of the hood and it's reversible)
and use dremel (or equivalent) to basically cut "channel" in lci grills for bent hood.
Finally zip ties or self taping screws will be needed, since pre-LCI bumper doesn't have matching clips.
It's a tedious multi hour process, but i like the result, finally no kidney strip.
BB_cuda768.50
      08-26-2022, 02:19 PM   #12
BB_cuda
BB_cuda's Avatar
769
Drives: 2011 335D Msport, 2013 X5D
san40k, Nice work! I'm also a bit of a trail blazer. Don't let them tell you no!
      10-17-2022, 02:29 PM   #13
Joeroyce
Drives: 335i e90
san40k
Any chance i can contact you about how to make thay fitment work?
      11-11-2022, 09:36 PM   #14
MWagen
Drives: 328is
But, is it possible to get an LCI bumper (preferable M Tech) that does not have the US spec side markers? The lack of them is the only thing that redeems the pre LCI bumper for me and I wouldn't want to have to add them.
      11-12-2022, 12:56 AM   #15
Serf27
Serf27's Avatar
2856
Drives: 335i
I have seen them for sale before.
It is a cleaner look. I normally paint over them. Completely shaving them off is another option if you can’t find one.
      11-12-2022, 04:07 PM   #16
MWagen
Drives: 328is
Is BMW still blocking the export of euro spec parts to NA? Probably wouldn't matter if I tried explaining that the car was not originally equipped with side markers and the bumper cover will not be installed on an LCI model. Though I suppose it would likely be cheaper to just buy the NA spec or get lucky and find a good used M-sport bumper and have those provisions filled in... Maybe I'm just imagining things but it seems like there's a lot more pre-lci cars for sale, and for much cheaper, at least in the condition I want. I just really don't like the early grills, haven't since the model launched.
      05-11-2023, 12:23 AM   #17
san40k
21
Few more pics to hopefully answer some of the questions.
I found the angle of the hood bend by gradually bending it with pliers to place it where it doesn't touch the front face of the new grill.
Given the tools it might be easier to cut that hood flap completely or half way to avoid so much plastic cutting and fitting. I spray painted hood flaps, they were not uniformly black under original plastic grille strips.
Tags
e90 lci kidney grills
