BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > E90 NBT Retrofit Complete!
      07-15-2021, 04:13 PM   #1
biglardyboy
Drives: E90 335i
Hi All,
I know I’m late to the whole NBT retrofit party, but wanted to share my experience now I have completed this!
Firstly, I have to say a massive thank you to the emulator supplier. Right from me asking many many questions before ordering, through to me being a complete numpty on programming/coding, they have been sensational. I’ve added a picture of the emulator used as I’m not sure I can link directly to their website.
I sourced the rest of the parts from eBay. I met some fantastic sellers during this process, many of whom were big BMW fans and couldn’t do enough to help.
For cables, I mainly used eBay sellers based in China, and apart from the Y cable for the touch controller, I was impressed with the quality (loose wire in the crimp - easy fix).
For me, the hardest part was making up a plug and play loom so the installation would take less time. Fitting the loom in was tight, but after I cut away some of the rear radio plastic cage, there was plenty of room.
I did the install in 2 parts, ran new DAB module/aerial cable and microphone cable in the first part, then once all the parts had arrived, installed everything else. I would say this took about 10-12 hours in total, but I really took my time.
Once coded, the difference between the factory CIC and The NBT is night and day. So much quicker and more modern looking, especially with the touch controller. It feels a more up to date interior even though it’s now 11 years old.
I know that there are alternatives to this now, Android units and MMI modules, but I wanted to go OEM and maybe once I have figured out the Logic 7 echo amp issues, I might investigate an ID6 unit!
Anyway, just wanted to share my experiences!
Thanks for looking.
Mark
Appreciate 4
      08-07-2021, 01:26 PM   #2
BWbimmer
BWbimmer's Avatar
Germany
277
Drives: BMW F36, E36, E93
Where did you start from, CCC or CIC?
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required
      08-07-2021, 05:06 PM   #3
biglardyboy
Drives: E90 335i
I started with a CIC unit.
      08-16-2021, 12:12 PM   #4
ManhattanFlash
Drives: E93 335i N54/DCT
Looks fantastic!
I'm hoping to do the same, move from CIC to NBT. Just bought an MMI to tide me over but do want to go full OEM.
What do you think your overall cost is?
Cheers
      08-16-2021, 03:30 PM   #5
biglardyboy
Drives: E90 335i
I reckon it cost around £800. I collected the parts over serval months as and when they came up on eBay. The emulator was the biggest expense, but worth every penny, especially given the help I got from them and the fact I can upgrade to an ID6 unit in the future.
      08-17-2021, 05:34 AM   #6
ManhattanFlash
That's actually pretty reasonable! I think I'm going to start looking out for the bits, and will probably go with the same emulator since you had such a good experience !
      08-17-2021, 05:42 AM   #7
BWbimmer
BWbimmer's Avatar
Germany
277
Would you share some kind of a parts list? Thanks a lot
Such Fun
      08-17-2021, 08:04 AM   #8
biglardyboy
Drives: E90 335i
1. Microphone Cable:
https://www.ebay.co.uk/itm/224244637809
2. NBT Video Cable:
https://www.ebay.co.uk/itm/254812202800
3. Y Controller cable (for touch controller, if using):
NBT Touch Controller ECU Y Splitter Cable Adapter Fit for BMW F01 F20 F25 F30 sy | eBay
4. Most loop:
https://www.ebay.co.uk/itm/284145495309
5. Bluetooth Aerial:
https://www.ebay.co.uk/itm/294053913803
6. Quadlock Extension cable (if making a pnp loom):
https://www.ebay.co.uk/itm/142511420442
7. Loop Harness Tape (if making a pnp loom):
https://www.ebay.co.uk/itm/360742292255
8. L7 CID High Screen 8.8”:
https://www.ebay.co.uk/itm/114928510354
9. NBT Head Unit:
https://www.ebay.co.uk/itm/224558049764
10. IDrive Touch Controller ECU (If fitting):
https://www.ebay.co.uk/itm/294190104566
11. Touch Controller (if fitting):
https://www.ebay.co.uk/itm/384206898750
12. Emulator
Cannot link to this.
Hopefully all the links work! It goes without saying that if you want the best price, you will have to search second hand sites often and be patient as you can get some great deals. This is why it took me so long to collect all the parts.
Hope this helps.
Mark
Appreciate 2
      08-17-2021, 09:54 AM   #9
BWbimmer
BWbimmer's Avatar
Germany
277
You are a star!
Such Fun
      04-01-2024, 08:55 AM   #10
grahams
grahams's Avatar
Drives: 135i, Clio 172
can I ask how you mounted the touch controller?
I'm working through the same retrofit currently and as the E9X and the F series touch controller have different lugs, bar making a 3d printed part the options aren't clear.
I can physically get it to fit the gap after trimming a small part of the controller trim
thank you
135i 6mt RHD - Birds Bilstein B1, M3 3.15 LSD + LCA + subframe mounts + ARBs, VRSF downpipes + charge pipe, 1m IKMOS, Pilot Super Sport
Clio 172 Turbo Trackcar
      04-23-2024, 04:04 PM   #11
biglardyboy
Drives: E90 335i
thank you
I got a thin bit strip of metal, bent it around the controller and drilled out where it crossed the existing trim mounting screw holes.
Really not pretty, but it works!
