02-24-2017, 09:08 AM | #67 |
1166
Rep 1,931
in for 1 day, no loud clunking.
I have a conservative stance.
www.nybmwcca.org
Current Cars: 1995 M3 Coupe Manual Alpine White 1997 M3 Sedan Auto Cosmo Black Metallic 2018 x3 m40 Auto Grey Metallic |
02-24-2017, 04:32 PM | #68 |
107
Rep 187
Im wondering if your before and after camber is the same because you came in with camber plates already??
Is that the max camber possible with these plates because my camber is already -2.0 after adding the LCAs. And Im looking to gain another -0.5degrees Must of felt good to come out of the shop clunk free |
02-24-2017, 06:35 PM | #69 |
1166
Rep 1,931
i had springs and plates done together. I can tell you its much more aggressive than stock.
I had stock 235 next to mine and my wheels where like / in the wheels well compared to | on the stock. My shop does alot of track cars, and didn't recommend anything more than what i'm running. Can i adjust it more, yea. I haven't really looked, but i would assume i could get it to -3, but it would mess everything else up. Its the perfect drop and ride height. with the springs, not too stanced out. waiting for the warmer weather to put the R comps and track wheels on.
www.nybmwcca.org
02-24-2017, 06:53 PM | #70 |
46
Rep 112
Looks nice, and I bet it drives better. Please update over time your experience with the camber plates.
What is your track setup for wheels and tires? DBinOC |
02-24-2017, 10:18 PM | #71 | |
107
Rep 187
I'm very Interested to know how the track session goes bc I know we are all tires of this happening to our tires (top of pic is outside shoulder. wear triangles are gone - and I run high psi) |
02-26-2017, 01:32 PM | #72 |
1166
Rep 1,931
give nitto 01's a try. Even on stock suspension they wore evenly. I had them heat cycled before delivery from discount tire and was very happy. They have a really nice stiff sidewall and very predictable.
Im trying nitto 01s and nitto 05s this season.
www.nybmwcca.org
02-26-2017, 03:20 PM | #73 |
1425
Rep 3,395
02-26-2017, 10:02 PM | #74 | |
1166
Rep 1,931
With little bumps, you def hear a little clink and clunking going on, but nothing crazy.
www.nybmwcca.org
02-26-2017, 10:10 PM | #75 | |
1166
Rep 1,931
Mperformance rotors, motul 600 fluid, bimmerworld SS lines. Was using EBC yellowstuffs, going to try the PFC08 pads.
www.nybmwcca.org
03-03-2017, 05:59 PM | #76 |
1166
Rep 1,931
so a week in, about 200 miles or so... Still nothing drastic as far as clangs and noises.
www.nybmwcca.org
Dylan861330.00 |
03-08-2017, 05:37 PM | #77 |
1166
Rep 1,931
SO another update...
I installed 12mm front, 15mm rear spacers and any noise that was there is now completely gone. Sounds like stock, rides amazing. So if your on Dinan camber plates without spacers, go get some. Thickness will probably depends on your wheel size, 7.5/8/8.5/9/9.5 etc....
www.nybmwcca.org
03-08-2017, 05:40 PM | #78 | |
1425
Rep 3,395
Since when do spacers SOLVE a NVH issue? |
03-08-2017, 05:47 PM | #79 |
1166
Rep 1,931
my noises i don't think were related to top hat issues.
Im pretty sure the v2 solved that problem. They are also back on the Dinan website for sale.
www.nybmwcca.org
fbsm744.00 |
04-17-2017, 08:29 PM | #81 |
105
Rep 272
I'm a little confused by this too, I wouldn't think a wider track with spacers would fix the clunking noises?
Been dealing with worn OEM top hats on my F31 after installing KW V2's. When I first installed them, I ran them a little too stiff which probably contributed to the premature bearing wear. Since then I have softened the front up, but obviously the damage was done to the bearings. Wasn't sold on many of the other camber plate options, but I am more inclined to trust Dinan. It would be nice to reduce outside edge wear on my Michelin PSS, among other things. As a side note, oem ride height I see on most F3x platform cars has a much higher front than rear, wondering if dropping the front too much might have thrown off their engineering as well. The KW V2's ride great 90% of the time, but over sharp bumps like bad expansion joints on roads, etc it is pretty brutal.
2014 F31 328i xDrive - Alpine White - KW V2 - 19" MORR VS8.2 - BSW Stage 1 - BSW Under Seat Woofer - BimmerTech Amp - Infinity Kappa 100.9w/500W Mono Amp - M-Sport Rear Bumper - M-Performance Diffuser - M3 F80 Style Front Bumper
04-20-2017, 04:27 PM | #82 |
844
Rep 2,384
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
Would I have issues using these with KW Plug and Play coil overs, M3/4 LCA and hotchkis sway bars?
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010 The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35 |
05-16-2017, 03:07 PM | #84 |
105
Rep 272
I'm also curious what users are experiencing, now that these have been out/on for a little while.
05-22-2017, 01:19 AM | #85 |
Rep 5
I just had my V2 Dinan camber plates installed, and the rattling at slow speeds is still present. The noise isn't intolerable, but I'd have to reassess priorities if it gets progressively worse like rwalker has experienced.
I'm getting 18x8.5s in a couple of weeks, so I'll see if the spacer solution that bryan_f22 mentioned will work for me. In the meantime, has anyone solved the rattling? Dinan: any update from your end? |
07-03-2017, 04:14 AM | #86 |
124
Rep 211
A friend of mine has the KW V3 and there was an issue with the 2 nut in the dinan camber kit. The nut didn't fit with the kw's strut.
I have the V2 and will install the dinan camber plates soon. Anyone here have issues with installation of the camber plates with V2? Thanks guys. |
07-03-2017, 03:27 PM | #87 | |
1330
Rep 2,214
07-29-2017, 05:13 AM | #88 |
124
Rep 211
I have sent an email to KW and it is confirmed that KW's V2 and V3 uses a different size top nut than the original top nut (KW Variant 2 and 3 uses M12x1,25 and original is M12x1,5).
Luckily for me, a shop was able to custom make the top nuts which was compatible with the KW V2/V3 and the Dinan camber plates. Otherwise, no other issues apart from mild increase in noises when going on rough roads. So for those who are interested in the Dinan camber plates with aftermarket suspensions, you may need custom made top nuts if your coilovers uses different size top nuts than the original strut. |
