BMW X5
      02-04-2024, 09:10 AM   #1
grkmspr
Drives: X6 xdrive35i
ISTA Alternative Diagnosis Software
Hello everybody,
I bought a BMW for the first time after Audi and Mercedes. (X6 E71 3.5i)
By using VCDS in Audi, I was able to perform most adaptations and coding and read detailed error codes. (about $20 on aliexpress)
I could use XENTRY with Open Tactrix in Mercedes. Cable is about 30-40$ on aliexpress
Now it's BMW's turn, I researched and its software is called ISTA if I'm not mistaken, but I couldn't find an alternative software. I would like to ask you to suggest an affordable and secure software that I can do coding, adaptation, testing, etc. for BMW.
! Or an affordable cable that can run ISTA, there are cables around $400-500 on Aliexpress, but they are very expensive.
Since I live in Kazakhstan, I cannot ship from Europe etc., only Aliexpress ships here. i also have thinkcar obd but its only read the codes.
      02-04-2024, 08:35 PM   #2
Fuzzy Master
Fuzzy Master's Avatar
257
Drives: 2020 BMW X5 M50i
Welcome to the forum. This forum is for G05 X5 (2019+). While someone here may know the answer to your question, you would likely get more responses by posting in the forum dedicated to E70 X5s, which is https://www.xbimmers.com/forums/index.php
You could also check out Bimmercode+Bimmerlink as well as Bimmer Utility. I purchased a BM700 direct from Ancel on AliExpress, so that may be a partial solution for you as well.
2020 BMW X5 M50i . Tanzanite Blue II . Black Merino . Extended Shadowline . 742M Black / ART Replica 181
07/2019.55 (since birth Oct.1,2019)-> 11/2019.70 (OTA Aug.11,2020)-> 11/2020.36 (Dealer Nov.25,2020)-> 03/2021.50 (OTA Jun.15,2021)-> 07/2021.85 (OTA Mar.1,2022)-> 07/2022.58 (OTA Dec.9,2022)-> 11/2022.60 (OTA Mar.2,2023)-> 03/2023.50 (OTA May.31,2023)-> 07/2023.35 (Dealer Aug.21,2023)-> 11/2023.50 (OTA Feb.9,2024)
      02-05-2024, 01:52 AM   #3
grkmspr
Thank you, sorry for wrong forum.
xbimmers
