MHD "take a look at my log" thread
06-25-2016, 02:52 AM | #89 |
Rep 95
I'm FBO with only stock DVs, on 93 octane. 30000 miles. Wedge custom tuned.
06-25-2016, 06:28 AM | #90 | |
261
Rep 1,093
06-25-2016, 07:53 AM | #91 | |
77
Rep 466
06-25-2016, 02:18 PM | #92 |
Rep 61
Could someone confirm what I am seeing here:
http://datazap.me/u/escapeyourmind/n...12-13-14-24-27 Looks like boost leak (maybe turbos going bad?), and lots of corrections (not sure why). Could probably use new spark plugs. No codes or anything, and fueling seems ok to me. I'm FBO running on 93 octane. ~92k miles. |
06-25-2016, 02:25 PM | #93 | |
97
Rep 804
E90 LCI M-sport/ 6AT/ LSD/ FBO+
06-25-2016, 03:52 PM | #94 |
77
Rep 466
Sorry, I can't really answer that since I have not run with Meth. I seriously doubt you going to get any noticeable gain on stock turbos with Meth versus running your E60 tune from Wedge.
06-25-2016, 06:25 PM | #95 |
480
Rep 485
Replaced the fuel sensor and took a couple logs. Seems to be good, just some timing corrections. Any thoughts here?
http://datazap.me/u/shrike360/run-2-...og=0&data=4-23 |
06-25-2016, 06:34 PM | #96 | |
648
Rep 2,015
335i e92 TPC 19Ts
06-25-2016, 09:45 PM | #97 | |
480
Rep 485
This is the log I took a few months back. Same tune, broken lpfp sensor though: http://datazap.me/u/shrike360/stage-...0&data=4-23-27 |
06-25-2016, 11:25 PM | #98 | |
2897
Rep 3,729
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
06-25-2016, 11:33 PM | #99 |
2897
Rep 3,729
Could be your DVs. Look into Turbosmart or Forge upgraded DVs.
06-25-2016, 11:44 PM | #100 |
480
Rep 485
06-25-2016, 11:45 PM | #101 | |
2897
Rep 3,729
Time for a LSD??
06-27-2016, 07:34 PM | #103 |
Rep 22
06-27-2016, 09:37 PM | #104 |
72
Rep 627
Hey Guys, I've been running V5 stage 2+ 91 octane for a while now, and it has been great. I decided to try the 93 octane map, and now seeing quite a bit of timing correction. Will someone please take a look and tell me if these values are safe, or should I go back to the 91 octane tune? Also, can you tell if your clutch is slipping from a log? It seemed in 3rd of 4th gear I could barely notice some slipping...
http://www.datazap.me/u/flyinb501/lo...a=8-9-10-12-21 Last edited by flyinb501; 06-28-2016 at 08:29 AM.. |
06-28-2016, 01:40 AM | #105 |
32
Rep 357
Hey guys how's my log looking? I'm running 93 octane with 3 gallons of e85. http://www.datazap.me/u/ricky85/log-...og=0&data=4-24
07-01-2016, 04:21 AM | #106 |
50
Rep 173
Logs
I'm on a stock 2009 MT 335i with the stage 1 91oct tune (version 6.1). So I've been getting some intermittent misfires, specifically they only happen in 6th gear going up a steep hill under WOT around 85-90 mph. Tried a lot of things and took the car to a couple of different shops and still can't figure out what's wrong!
Replaced coils, plugs and rear oxygen sensor but the misfire is still there intermittently. Annoyingly when I went to log tonight, it didn't misfire a single time, maybe it was because of the low night time temps (60F in Cali). Thought I'd post the logs anyway, maybe you guys will notice something. I'm new to logging so I did a few, just in case: 3rd gear pulls (on flat ground): Run 1 Run 2 Run 3 Here is a sixth gear pull going up a steep hill, where I tried to recreate the misfire: Sixth gear pull |
07-01-2016, 04:32 AM | #107 | |
2897
Rep 3,729
07-01-2016, 11:31 AM | #109 |
2897
Rep 3,729
Are you misfiring on the same cyl consistently? Logs appear to be within reason (but I didn't do a deep dive). I just reviewed it high-level.
Common causes you've already addressed such as coils and plugs. Your AFR appears to be in check so that rules out injectors and o2 sensors. The only thing I can really think of is poor octane. California 91 is pretty junk (I'd know, I lived there before they stationed me abroad.) Perhaps you can try adding 2-3 gallons of E85 and see if it happens again...
07-01-2016, 11:51 AM | #110 | |
50
Rep 173
