M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > BMW M5 (F10) General Forum
      07-19-2011, 10:50 PM   #111
Powerslide
1099
Drives: 2018 F80 ZCP
BTW - would a rear-drive car with either a: 1) manual transmission; 2) automated manual, i.e., MDCT; or 3) modern 8-sp auto (such as on Lexus ISF) normally have about a 20% drivetrain loss? If not, what would be the standard "approximate" drivetrain loss percentage for these transmissions assuming RWD?
      07-21-2011, 02:30 AM   #112
swamp2
swamp2's Avatar
611
Drives: E92 M3
Originally Posted by Kinzer S13GT View Post
This cylinder head design, is superior to the 1st gen S63. And the engine as a whole, is worlds apart from the outgoing S85. (not to say its a poorly designed engine, lol! BMW PTG can make 800+hp on a naturally aspirated S85 ) This engine is just doing so much more to move more air, and more (or less) fuel, to make power twice as efficiently as that engine. Actually as far as volumetric efficiency is concerned, its probably running at an average of 75-85% of its max potential volumetric efficiency. Depending on conditions. Whereas the S85 was sitting around 40-60%! BMW builds the most ridiculous engines, then dials their output down to 5' before selling it to us civilians! Their capabilities are always underrated!
Your comments on volumetric efficiency are either incorrect or poorly stated. VE is a function of rpm at a given throttle (typically tested/calculated at WOT). Thus folks typically refer to peak VE as "VE" or supply a rpm dependent curve. Thus there is not really an "average" VE except perhaps a time averaged one specific to how each driver might be driving. So if you are claiming the S85, a wonderful breathing machine, can only hit a (peak) VE of 60% that is absurdity. Even the "lowly" Z3 M Coupe can reach over 100% peak VE. Although I do not have the data handy, I am positive that the S85 (and thus S65) also reach over 100% peak VE. Comparing VE across FI and NA engines is pretty well meaningless just like comparing hp/l for FI vs. NA is.
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK |
| Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors |
| Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels |
| XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit |
      03-04-2012, 11:18 PM   #113
BmwM5.F10
New Zealand
Drives: BMW M5 F10
Apparently BMW is putting the M5 engine in the new M6 coming out soon, its a good engine but I think the M6 deserves a bigger V10 engine
      03-05-2012, 01:55 AM   #114
BMW0412
85
Drives: M5
i just wish they wont use this engine to x5m and x6m in the future
      03-09-2012, 08:20 AM   #115
AlpWhite11
67
Drives: 335i
Why is that? M5 and M6 has shared the same engine. And the n63tu sounds excellent so far. I don't think we'll be severing any 10 cyl engine from BMW in a LONG while, if ever again. The trend now is smaller displacement + forced induction.
      01-01-2017, 09:35 PM   #116
MnMnM
MnMnM's Avatar
14
Drives: 2018 X5 M, 2013 M3
Originally Posted by shaq diesel View Post
It's economies of scale.
If this engine architecture turns out to have great real-world reliability, all they'll have to do in 3-5 years is bump up the boost/tuning to keep up with the competition. If they can just play that game to keep in the HP wars that means they'll get a lot of years out of this basic engine architecture, which means a lot of design/construction savings down the road. It also means they'll have that much longer to design and test its eventual replacement.
A much better path financially than building the motor at peak power now and having to completely redesign in to 3-5 years to keep up with the competition.
Shaq diesel is bang-on correct. Look at the date of his post.
Here it is now 2017 and we've had stock @ 560HP, CP @ 575HP, Jarhe 30 @ 600 HP and now rumours of the F90/G30 or what ever it's called will be 600HP+ all with assuringly the same basic configuration. I'd predict this engine @ 650HP+ before the production ends.
My 2 bits
      01-07-2017, 10:44 AM   #117
JMD
MGySgt
JMD's Avatar
640
Drives: See Garage List! ;-)
2010 M5  [10.00]
2016 BMW 340xi M Sport  [9.00]
2019 X5 50i M Sport  [5.50]
2010 535xi  [0.00]
2013 M5  [0.00]
2012 X5 M  [0.00]
....Yeah! There is no way going from 1.2 bar to 1.5 bar only makes for a 5Hp diff. If one did the math on the difference,...then that same diff you should reflect there about the additional increase in power. My math is showing a 20% increase in boost!
So, if BMW wants us to believe that a 20% increase in boost yields only 5 more Hp,...then that's what we will believe.
Someone pls check my math!
JMD
      01-16-2017, 08:14 PM   #118
MnMnM
MnMnM's Avatar
14
Originally Posted by BBS View Post
Thats incorrect. Any pressure the turbo feeds in the inlets are positive. Meaning that are 1.5 bad above 1kpa atmospheric. So 1.5 bar is still 22psi above the normal 14.5psi
BBS is correct.
Atmospheric pressure has no bearing on the turbo specification. Bar is a unit of pressure measurement. The M5 turbos create 1.5 bar (~22psi) above atmospheric pressure.
It doesn't matter if you are sea level or 5000'. Cylinder pressure will be the same at maximum turbo output. The engine won't respond as well during spooling of the turbos at higher altitude due to air density and oxygen levels but it should theoretically make rated HP once they are fully spooled.
My 2bits
      01-16-2017, 08:39 PM   #119
MnMnM
MnMnM's Avatar
14
It's all smoke and mirrors
      01-16-2017, 10:33 PM   #120
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
I do agree the this platform might be able to generate 650 HP but then we need to see if DCT is getting redesigned or they want to use the Auto transmission. Something like the one installed on X5M/X6M
Current : 2020 F92 Black Sapphire M8 - ZF8
Gone : 2018 F80 Mineral Gray M3 - 6MT
Gone : 2016 F82 Austin Yellow M4 - 6MT
Gone : 2013 F13 Sakhir Orange M6 -7DCT
Gone: 2013 F13 Alpine White 650i -ZF8
      12-03-2017, 08:22 PM   #121
gestut
Drives: 2015 M5
this article says the opposite , bmw increased the compression and lower the boost by .1 bar = 1.1 bar
who is right ?
http://www.bmwblog.com/2011/09/22/bm...-of-the-beast/
      03-30-2018, 03:52 PM   #122
BMWsean
Drives: x6 5.0
VE efficiency
I was thinking the same as most cars I check VE on generally do better than 90% or I be looking for an issue.
      10-18-2023, 08:34 PM   #123
TTV8M
TTV8M's Avatar
124
Drives: '23 AMG GLE53, '10 X6M
2023 AMG GLE53  [0.00]
2010 BMW X6M  [0.00]
2008 Mini Cooper S  [0.00]
Originally Posted by 3XTR3M3 View Post
I don't understand what bar is but I reversed the math to figure out what 1.2bar is on the S63 and it came out to about 18psi. Is that about right? The M5 is running 4psi more than the X6M?
Might make sense as the m5 being a racing sedan and the X5/x6 being a big arse SUV.
Wouldn't the SUV need more torque for itself vs a lighter sedan?
m5post
