09-12-2014, 03:48 PM | #23 | |
129
Rep 917
2011 135i M Sport 6MT LeMans Blue | Active Autowerke Gen II axle back | Berk d******* | N54 gutted mids | FuelIt Walbro 450 fuel pump | Pure Turbos Stage 2 | 3.5bar TMAP | Pure Turbos inlet pipe | BMS intake | BMS oil catch can | ETS intercooler | ETS charge pipe | BMS JB4 w/ ISO firmware | BMS backend flash stacked on PPK | Eibach springs | Whiteline rear subframe bushing inserts | cosmetic tidbits
09-12-2014, 04:27 PM | #24 | |
European Editor
10628
Rep 22,992
09-12-2014, 04:50 PM | #25 |
137
Rep 952
You may be out of luck for the 6MT. Bulletin only shows that it's applicable for the DCT equipped cars.
13 X1 35iX, 98 Z3 2.8, 01 M Coupe, 96 Z3 1.9 DASC, 95 318ti, 13 smart fortwo
09-12-2014, 05:10 PM | #26 | |
44623
Rep 7,227
09-12-2014, 07:38 PM | #28 |
Rep 13
Wow, the same thing happened to me. I just had my car serviced (135i DCT), and right when I drove away from the dealer I knew something felt different. I didn't mention anything about lag or software updates.
The pedal was definitely more responsive. I looked at my invoice sheet and it had my car listed as a 135is?! Immediately I wondered if they somehow gave me the 135is tune instead. I'll see how it sounds at WOT. |
09-12-2014, 08:41 PM | #29 |
BMW Master Tech
587
Rep 850
Drives: E30, E36, E82, E90, F10, F80
Garage List 2015 Aston Martin V ... [0.00]
2010 Lamborghini LP ... [0.00] 1985 Alpina C2 2.7 [0.00] 2017 BMW M3 [0.00] 2008 BMW 128i [10.00] 2013 BMW 135is [0.00] 1992 BMW 325i [0.00] |
If your referring that your car comes up on the front page of the repair order as a 135is, that's all user defined and doesn't come from the key read. You could write in M3 and it wouldn't matter. Some dealerships still use "is" to signify that it's a coupe believe it or not.
I'm sure the programming changed the software in the DME, but it's not possible to get the PPK for free. Trust me. I've tried.
135is #502 of 586
BMW LED Performance Wheel | OEM FULL Carbon Fiber | E9X M3 Gauge Cluster | E9X Exterior Mirrors | E9X M3 Full Suspension | E9X M3 Diff | PT-CAN2 Enabled | Bilstiens | Michelin PSS's | NBT Navigation Retrofit with Touch Pad |
09-12-2014, 08:46 PM | #30 |
153
Rep 964
Drives: BMW 135is | #341/586
your car sounds exactly like my car!!! loving it!
2013 BMW 135is Coupe | Dinan Stage 3 | M3 Subframe Bushings | Dinan Monoball Joints | Dinan Toe Links | 1M Strut Bar | MPS AS/3 - VMR 710's 18x8.5 ET45 / 18x9.5 ET50 | MPSS - BMW 313's 18x7.5 / 18x8.5 | Min Grey, Savanna | Prem, Tech | DCT | Beast #341/586 |
2021 BMW X7 M50i | Alpine White | Children Hauler |
09-12-2014, 10:34 PM | #31 | |
2304
Rep 12,570
Drives: Z4 M, X5, GX460
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.07] |
09-13-2014, 03:23 PM | #33 | |
137
Rep 952
09-13-2014, 03:24 PM | #34 |
137
Rep 952
09-13-2014, 03:34 PM | #35 |
13572
Rep 8,189
And could you please check if there is anything for the good ole 6MT? The throttle response is bad and if there was really a SW update that would even get me the pops n burbles, I would be a happy, happy man.
09-13-2014, 04:18 PM | #36 |
European Editor
10628
Rep 22,992
There is nothing for the 6MT cars. The software update IS the reason why your throttle response is so bad! BMW gives us new SW that keeps the wastegates open until 3,500 rpms and the anti-tuner sw which makes tunes harder to run/work. Only solution is the PPK or a real SW tune.
09-13-2014, 05:12 PM | #37 | |
13572
Rep 8,189
09-13-2014, 05:19 PM | #38 |
Rep 229
Drives: 135i.N55.6SPD.M-SPORT
Let me know what you find out. I have a manual as we'll but LOVE those noises!
TauK-n Tky 1. at a time///
09-13-2014, 08:12 PM | #39 |
Rep 150
So I've read bmw will update your software w/out notice or request?
I talked to my advisor today about getting updates. he said even if there is an outstanding update he wouldn't recommend it unless it was really needed/last resource. He said his las customer who requested it had his dme crash and had to be replaced. Sounds like bullshit to me! Do I need to talk to a different SA? What's the standard procedure here? |
09-13-2014, 11:41 PM | #40 | |
Rep 229
09-14-2014, 06:48 PM | #41 |
44623
Rep 7,227
I guess what I meant was do you think you would've gotten the same sounds without your mods? In other words do you think that the same software update would sound the same on a stock 135i?
09-15-2014, 09:26 AM | #42 |
178
Rep 765
09-15-2014, 05:23 PM | #43 |
137
Rep 952
Yes, so far so good on that issue as well. It had been getting pretty bad there over the last few weeks.. It's a world of improvement.
09-15-2014, 09:20 PM | #44 | |
Proud AARP member in good standing
29
Rep 635
Anyone have the actual printout if SIB 12-15-14 and the release date?
2012 135i DCT, Lemans Blue/black leather, PPK1, PE, Stoptech Sport rotors and Sport pads, unhealthy crackles and burbles and an aging demonic driver. |
